Full Version: Tvh client missing
I installed kodi (openelec) on a new bought NUC today. I was planning to move the old one to the bedroom. After installing the tvheadend client I checked if it was working. It was..... After a reboot the TV addon is not working anymore.
When I try to 'clear data' or disable the TV in Tv-settings, Kodi just freezes completely.
When I disable the plug-in and uninstall it, reboot and enable the tv in the settings, it works again. Until the next reboot and the problem repeats. Everything on the old NUC works normal when I switch it back in place, so my first guess is the problem is not with the tvheadend backend.
log:
17:29:21 T:139973746751360 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:29:21 T:139973746751360 NOTICE: -----------------------------------------------------------------------
17:29:21 T:139973746751360 NOTICE: Starting Kodi (15.2 Git:02e7013). Platform: Linux x86 64-bit
17:29:21 T:139973746751360 NOTICE: Using Release Kodi x64 build
17:29:21 T:139973746751360 NOTICE: Kodi compiled Nov 1 2015 by GCC 4.9.3 for Linux x86 64-bit version 4.1.12 (262412)
17:29:21 T:139973746751360 NOTICE: Running on OpenELEC (official) - Version: 6.0.0, kernel: Linux x86 64-bit version 4.1.12
17:29:21 T:139973746751360 NOTICE: FFmpeg version: 2.6.4
17:29:21 T:139973746751360 NOTICE: WARNING: unsupported ffmpeg version detected
17:29:21 T:139973746751360 NOTICE: Host CPU: Intel® Core™ i3-5010U CPU @ 2.10GHz, 4 cores available
17:29:21 T:139973746751360 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
17:29:21 T:139973746751360 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:29:21 T:139973746751360 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
17:29:21 T:139973746751360 NOTICE: special://home/ is mapped to: /storage/.kodi
17:29:21 T:139973746751360 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
17:29:21 T:139973746751360 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:29:21 T:139973746751360 NOTICE: Local hostname: OpenELEC
17:29:21 T:139973746751360 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
17:29:21 T:139973746751360 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
17:29:21 T:139973746751360 NOTICE: load settings...
17:29:21 T:139973746734848 NOTICE: Thread FDEventMonitor start, auto delete: false
17:29:21 T:139973746751360 NOTICE: Found 1 Lists of Devices
17:29:21 T:139973746751360 NOTICE: Enumerated ALSA devices:
17:29:21 T:139973746751360 NOTICE: Device 1
17:29:21 T:139973746751360 NOTICE: m_deviceName : hdmi:CARD=HDMI,DEV=0
17:29:21 T:139973746751360 NOTICE: m_displayName : HDA Intel
17:29:21 T:139973746751360 NOTICE: m_displayNameExtra: HDMI #0
17:29:21 T:139973746751360 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:29:21 T:139973746751360 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
17:29:21 T:139973746751360 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
17:29:21 T:139973746751360 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
17:29:21 T:139973746751360 NOTICE: Device 2
17:29:21 T:139973746751360 NOTICE: m_deviceName : hdmi:CARD=HDMI,DEV=1
17:29:21 T:139973746751360 NOTICE: m_displayNameExtra: PIO VSX-923 on DisplayPort #1
17:29:21 T:139973746751360 NOTICE: m_channels : FL,FR,LFE,FC,BL,BR,BLOC,BROC
17:29:21 T:139973746751360 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_AAC
17:29:21 T:139973746751360 NOTICE: Device 3
17:29:21 T:139973746751360 NOTICE: m_deviceName : hdmi:CARD=HDMI,DEV=2
17:29:21 T:139973746751360 NOTICE: m_displayNameExtra: HDMI #2
17:29:21 T:139973746751360 NOTICE: Device 4
17:29:21 T:139973746751360 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
17:29:21 T:139973746751360 NOTICE: m_displayName : HDA Intel PCH
17:29:21 T:139973746751360 NOTICE: m_displayNameExtra: ALC283 Analog
17:29:21 T:139973746751360 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:29:21 T:139973746751360 NOTICE: m_sampleRates : 48000
17:29:21 T:139973746751360 ERROR: CSettingGroup: unable to read setting type of "pvrmanager.syncchannelgroups"
17:29:21 T:139973746751360 WARNING: CSettingCategory: unable to read group "1"
17:29:21 T:139973746751360 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
17:29:21 T:139973746751360 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<video>
<latency>
<delay>0</delay>
<refresh>
<min>23</min>
<max>24</max>
<delay>175</delay>
</refresh>
</latency>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
</advancedsettings>
17:29:21 T:139973746751360 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:29:21 T:139973746751360 NOTICE: Default DVD Player: dvdplayer
17:29:21 T:139973746751360 NOTICE: Default Video Player: dvdplayer
17:29:21 T:139973746751360 NOTICE: Default Audio Player: paplayer
17:29:21 T:139973746751360 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:29:21 T:139973746751360 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:29:21 T:139973746751360 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:29:21 T:139973746751360 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:29:21 T:139973746751360 NOTICE: Loaded playercorefactory configuration
17:29:21 T:139973746751360 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:29:21 T:139973746751360 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:29:21 T:139973736199936 NOTICE: Thread ActiveAE start, auto delete: false
17:29:21 T:139973655262976 NOTICE: Thread AESink start, auto delete: false
17:29:21 T:139973746751360 NOTICE: Running database version Addons19
17:29:21 T:139973746751360 NOTICE: ADDONS: Using repository repository.xbmc.org
17:29:21 T:139973746751360 NOTICE: ADDONS: Using repository repository.openelec.tv
17:29:21 T:139973646870272 NOTICE: Thread RemoteControl start, auto delete: false
17:29:21 T:139973746751360 NOTICE: Setup SDL
17:29:21 T:139973746751360 NOTICE: Checking resolution 18
17:29:21 T:139973746751360 ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:38, error_code:5, request_code:18 minor_code:0
17:29:21 T:139973746751360 NOTICE: Using visual 0x20
17:29:22 T:139973746751360 NOTICE: GL_VENDOR = Intel Open Source Technology Center
17:29:22 T:139973746751360 NOTICE: GL_RENDERER = Mesa DRI Intel® HD Graphics 5500 (Broadwell GT2)
17:29:22 T:139973746751360 NOTICE: GL_VERSION = 3.0 Mesa 10.6.9
17:29:22 T:139973746751360 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
17:29:22 T:139973746751360 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_stencil_texturing GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_derivative_control GL_ARB_pipeline_statistics_query GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control
17:29:22 T:139973746751360 NOTICE: CWinSystemX11::SetFullScreen - calling xrandr
17:29:22 T:139973613340416 NOTICE: Thread PeripBusCEC start, auto delete: false
17:29:22 T:139973604947712 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
17:29:22 T:139973746751360 NOTICE: Running database version Addons19
17:29:22 T:139973746751360 NOTICE: Running database version ViewModes6
17:29:22 T:139973746751360 NOTICE: Running database version Textures13
17:29:22 T:139973746751360 NOTICE: Running database version MyMusic52
17:29:22 T:139973746751360 NOTICE: Running database version MyVideos93
17:29:22 T:139973746751360 NOTICE: Running database version TV29
17:29:22 T:139973746751360 NOTICE: Running database version Epg10
17:29:22 T:139973746751360 NOTICE: start dvd mediatype detection
17:29:22 T:139973615728384 NOTICE: Thread DetectDVDMedia start, auto delete: false
17:29:22 T:139973746751360 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
17:29:22 T:139973746751360 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
17:29:22 T:139973746751360 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
17:29:22 T:139973746751360 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:29:22 T:139973596555008 NOTICE: Thread JobWorker start, auto delete: true
17:29:22 T:139973746751360 NOTICE: UpdateLibraries: Starting video library startup scan
17:29:22 T:139973319718656 NOTICE: Thread JobWorker start, auto delete: true
17:29:22 T:139973311325952 NOTICE: Thread LanguageInvoker start, auto delete: false
17:29:22 T:139973746751360 NOTICE: initialize done
17:29:22 T:139973746751360 NOTICE: Running the application...
17:29:22 T:139973596555008 NOTICE: PVRManager - starting up
17:29:22 T:139973294634752 NOTICE: Thread PVRManager start, auto delete: false
17:29:22 T:139973286242048 NOTICE: Thread PVRClient start, auto delete: false
17:29:22 T:139973269456640 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 192.168.249.50:9982
17:29:22 T:139973311325952 NOTICE: -->Python Interpreter Initialized<--
17:29:22 T:139973746751360 NOTICE: starting zeroconf publishing
17:29:22 T:139973746751360 NOTICE: Webserver: Starting...
17:29:22 T:139973746751360 NOTICE: WebServer: Started the webserver
17:29:22 T:139973746751360 NOTICE: starting upnp client
17:29:22 T:139973746751360 NOTICE: ES: Starting event server
17:29:22 T:139972715738880 NOTICE: Thread EventServer start, auto delete: false
17:29:22 T:139972715738880 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:29:22 T:139972715738880 NOTICE: UDP: Listening on port 9777
17:29:22 T:139972707346176 NOTICE: Thread TCPServer start, auto delete: false
17:29:22 T:139972690560768 NOTICE: Thread AirPlayServer start, auto delete: false
17:29:22 T:139972841563904 NOTICE: Thread JobWorker start, auto delete: true
17:29:22 T:139973319718656 NOTICE: VideoInfoScanner: Starting scan ..
17:29:22 T:139973319718656 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
17:29:22 T:139973746751360 ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:120, error_code:5, request_code:18 minor_code:0
17:29:22 T:139973311325952 NOTICE: ## OpenELEC Addon ## 0.6.8
17:29:23 T:139973269456640 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 192.168.249.50:9982
16:30:54 T:139972715738880 ERROR: Previous line repeats 2 times.
16:30:54 T:139972715738880 NOTICE: ES: Client from 192.168.249.5 timed out
16:31:26 T:139973746751360 NOTICE: PVRManager - stopping
16:32:29 T:139972715738880 NOTICE: ES: Client from 192.168.249.5 timed out
16:37:14 T:139973746751360 NOTICE: Storing total System Uptime
16:37:14 T:139973746751360 NOTICE: Saving settings
16:37:14 T:139973746751360 NOTICE: stop all
16:37:14 T:139973746751360 NOTICE: stop player
16:37:14 T:139973746751360 NOTICE: PVRManager - stopping
Any ideas??
Have you tried to enable 'Asynchronous EPG transfer' in the settings for the addon?
Hi tredman, I don't understand why but it seems to work. Thanks a lot
