Full Version: Smartflix
Addon to support smartflix.
I Haven`t found a addon so you can use smartflix inside kodi.
Is these something somebody who have time and skills have started on?
Is it possible todo it?
Have you considered a smart DNS solution? It costs a few £/$/€ a month and lets you watch Netflix in pretty much every region.
(2016-01-10, 19:59)UsefulG Wrote: [ -> ]Have you considered a smart DNS solution? It costs a few £/$/€ a month and lets you watch Netflix in pretty much every region.
Thank you for your advise, do you have som information about my question?
I use UnBlockUs which has a website where you log in, change the region you are in to another one and then you can watch Netflix from pretty much anywhere.
(2016-01-10, 22:12)UsefulG Wrote: [ -> ]I use UnBlockUs which has a website where you log in, change the region you are in to another one and then you can watch Netflix from pretty much anywhere.
I see, its work but not so smoth..
How can I setup so I`m only using unblock when I`m using netflix abb in Kondi, and when I`m not I`use my default DNS?
I don`t want to send the normal traffic from my media computer through UnBlockUs.
