Hi
i have Multichannel Audio saved as FLAC (5.1)
I am using Openelec with Kodi v17.
However when playing it only gives back Stereo.
In the Audio Settings , i had it put to Optimized. When i change to Best Match , it switches to Multichannel PCM and it does the 5.1 However , than the mp3's for example are also displayed as Multichannel 5.1 . If i turn off Kodi , the music is played as Stereo again.
After switching than to Optimized, it shows than also as Multichannel PCM. It kind of "hangs" somehow.
Could this be ? Is there another setting i need to change ?
You should post your
Debug Log and please reread the description of what Optimized does. Even if it still displays 5.1 Multichannel for your Mp3 - you only have music on 2 speakers. Optimized is meant to not constantly change the output format in order to make gapless playback possible.
Best Match should not at all show this issue, cause it opens the output device new every time track / stream changes, therefore the
Debug Log is needed.
So do the following:
Turn on debuglogging. Switch to Optimized (don't enable Stereo Upmix <- as this will clearly produce 5.1 from your 2.0), play the flac and the mp3, post the
Debug Log
stop kodi
start kodi
Turn on debuglogging. Switch to Best Match (don't enable Stereo Upmix <- as this will clearly produce 5.1 from your 2.0), play the flac and the mp3, post the
Debug Log
I did the logging now , but as always now it worked. As well with Optimized and with Best Match.
but here is the logfile :
http://sprunge.us/JhNX
in here is the error now.
http://sprunge.us/ThMc
playing a 5.1 flac file on Best Match outputs stereo. When switching to Optimized it gives 5.1
A log without a movie scan running would make it readable quite well :-)
You try Adele flac files, right? I only see 6 channels openened in the logs.
We could argue about this one:
Quote:DEBUG: CSMBFile::Open - opened smb://DISKSTATION/Music/Alben/P/Dark Side of The Moon (Quadrophonic 4.0 - 96kHz)/04 - Pink Floyd - Time.flac
14:58:51 T:139717247256320 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR,FC,SL,SR
14:58:51 T:139717247256320 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR,FC,SL,SR,UNKNOWN1 (ALSA: FL FR FC RL RR UNKNOWN)
Nothing wrong in your log - all fine. There was never a 6 channel input and a stereo output opened.
Adele did switch to 5.1.
Anastacia went back to 2.0
then, Dark Side of the Moon. That's the one where it didn't switch.
