Full Version: Execute user tasks for Kodi events (callbacks ver2)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
It looks like Smartthings doesn’t work with Callbacks anymore? Is there a workaround?
Hi, I'm trying to get the callbacks to with the a Vero V (osmc). I'm struggling as my Python skills are extremely basic though I could get the Text Command facility to run the Python and generate errors. I thought I'd try a simple script I've called basheg2.sh:
echo 'hello' > /home/osmc/test.txt
However when I use the Test Command facility in the Events Settings (having set up a Task for "on Scan Started" - there's no evidence anything is running.
I've tried de-installing the Add-on and re-installing with no luck.
Is there a chance de-installing isn't clearing everything out and there's a manual way to ensure everything is removed ?
