Full Version: Clean & Prep your Build <Windows ONLY>
For those who Customize thier Build (skin, etc) and update often...
This is a set of VBscripts that will take a compiled build (it will not compile it for you) and rename and/or delete files you want so you do not overwrite your custom XMLs on your XBOX.
I update my builds weekly and this saves me 10 minutes easily.
edit the .BAT file your your own use, leave everything else alone or you may break it Wink
Link for Script on XBMCscripts.com
ENJOY!
