2016-01-15, 15:08
Hi. One of user my addon have problem with Image package.
He using openelec:
and get error:
It is a pice of my addon code:
addon.xml:
What is a problem?
He using openelec:
13:49:29 7.824651 T:140141752924224 NOTICE: Starting Kodi (17.0-ALPHA1 Git:61e14b1). Platform: Linux x86 64-bit
13:49:29 7.824670 T:140141752924224 NOTICE: Using Release Kodi x64 build
13:49:29 7.824691 T:140141752924224 NOTICE: Kodi compiled Jan 12 2016 by GCC 5.3.0 for Linux x86 64-bit version 4.4.0 (263168)
13:49:29 7.824833 T:140141752924224 NOTICE: Running on OpenELEC (Milhouse) - Version: devel-20160112225428-#0112-g6b32250 [Build #0112] 7.0, kernel: Linux x86 64-bit version 4.4.0
and get error:
13:50:53 90.577278 T:140139041027840 DEBUG: >>>> Movielib <<<< The _imaging C module is not installed
import xbmc
import xbmcaddon
import os
from PIL import Image
from PIL.Image import core as _imaging
import cStringIO
import json
import urllib
try:
image = Image.open(file)
if image.mode != 'RGB':
image = image.convert('RGB')
h = image.size[1]
if h > 10:
if (h > height):
image.load()
image = image.resize((width, height), Image.ANTIALIAS)
image_bin = cStringIO.StringIO()
image.save(image_bin, 'JPEG', quality=int(q))
output = image_bin.getvalue()
image_bin.close()
except Exception as Error:
debug.debug(str(jsonGetResponse))
debug.debug(source)
debug.debug(str(Error))
addon.xml:
<requires>
<import addon="xbmc.python" version="2.14.0" />
<import addon="script.module.pil" version="1.1.7" />
</requires>
What is a problem?
