2016-01-16, 04:03
root@omv:~/xbmc# ./bootstrap
autoreconf -vif .
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force
autoreconf: configure.ac: tracing
autoreconf: configure.ac: not using Libtool
autoreconf: running: /usr/bin/autoconf --force
configure.ac:32: error: possibly undefined macro: AC_DEFINE
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure.ac:33: error: possibly undefined macro: AC_MSG_RESULT
configure.ac:96: error: possibly undefined macro: AC_MSG_ERROR
configure.ac:98: error: possibly undefined macro: AC_MSG_WARN
configure.ac:544: error: possibly undefined macro: AC_PROG_LIBTOOL
configure.ac:585: error: possibly undefined macro: AC_MSG_NOTICE
configure.ac:817: error: possibly undefined macro: AC_COMPILE_IFELSE
configure.ac:818: error: possibly undefined macro: AC_LANG_SOURCE
configure.ac:1009: error: possibly undefined macro: AC_CHECK_LIB
configure.ac:1112: error: possibly undefined macro: AC_RUN_IFELSE
autoreconf: /usr/bin/autoconf failed with exit status: 1
make: *** [configure] Error 1
is my aclocal/autoconf/automake broken?[/code]
