2016-01-17, 17:23
i'm new to this forum and new to Kodi.
I have installed Kodi 15.2 on my iMac retina 5k running os X El Capitanand loaded add-ons etc.
Everything seems to work ok except the sound which drops out every couple of minutes for a few minutes then cuts back in again. It seems to be independent of the stream too. I can change streams and if the sound is working at the time it still works and visa versa if the sound isn't working. Another sound issue which may be related, is that the gui sounds don't happen when you press a button, there is a delay of 20 seconds or so.
any suggestions much appreciated
