2016-01-17, 20:03
I've been using Kodi for months with no real issues, but yesterday I noticed I was getting messages in the GUI that said
It does seem to process some of the show/directories I have, but it is slower than normal and stops on certain shows as well. I took to the forums, so here is what I've tried so far.
- Create advancedsettings.xml file
- Added the below to the advancedsettings.xml file
- Moved the advancedsettings.xml file to /Users/[me]/library/application support/kodi/userdata
- Restarted Kodi and my Mac
I've been running this on a mac mini with a VPN, so I've turn that on/off and changed the server connectino with no success.
I turn on logging, and it looks like a timeout, but I can make a normal call from my browser to the URL that is in the log with no issues. I also tried to check other internet connection issues. I can download and install new add-ons, but I can't get the 'Bravo' plugin app to stream video. If I switch from TVDB to XEM, I get the same issue as well. Both of those add-ons do not have an options to updating them either.
I have no clue what has changed and I haven't made any changes to the Mac since this started, so any help is appreciated. Thanks!
Mac Mini (Late 2014)
El Capitan (10.11.2)
Kodi 15.2
Log:
Quote:Couldn't download information Unable to connection to remote server. Would you like to continue scanning?
<advancedsettings>
<network>
<disableipv6>true</disableipv6>
<curlclienttimeout>90</curlclienttimeout>
<curllowspeedtime>90</curllowspeedtime>
</network>
</advancedsettings>
Kodi 15.2
Log:
Quote:12:35:49 T:123145318477824 DEBUG: Get: Using "UTF-8" charset for XML "http://thetvdb.com/api/GetSeries.php?seriesname=Arrow&language=en"
12:35:49 T:123145318477824 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results><entity><title>Arrow</title><language>en</language><url cache="257655-en.xml">http://thetvdb.com/api/1D62F2F90030C444/series/257655/all/en.zip</url><id>257655</id></entity><entity><title>The Black Arrow</title><language>en</language><url cache="252373-en.xml">http://thetvdb.com/api/1D62F2F90030C444/series/252373/all/en.zip</url><id>252373</id></entity><entity><title>Broken Arrow</title><language>en</language><url cache="70767-en.xml">http://thetvdb.com/api/1D62F2F90030C444/series/70767/all/en.zip</url><id>70767</id></entity></results>
12:35:49 T:123145318477824 DEBUG: GetVideoDetails: Reading movie 'http://thetvdb.com/api/1D62F2F90030C444/series/257655/all/en.zip' using The TVDB scraper (file: '/Users/brianharnett1/Library/Application Support/Kodi/addons/metadata.tvdb.com', content: 'tvshows', version: '1.8.3')
12:35:49 T:123145318477824 DEBUG: CurlFile::Open(0x1178de220) http://thetvdb.com/api/1D62F2F90030C444/...all/en.zip
12:36:30 T:123145318477824 ERROR: CCurlFile::FillBuffer - Failed: Failure when receiving data from the peer(56)
12:36:30 T:123145318477824 ERROR: CCurlFile::Open failed with code 0 for http://thetvdb.com/api/1D62F2F90030C444/...all/en.zip
12:36:30 T:123145318477824 ERROR: Run: Unable to parse web site
12:36:30 T:123145318477824 DEBUG: VideoInfoScanner: Scanning dir '/Volumes/pny256/TV/Arrow/' as not in the database
12:36:30 T:123145318477824 DEBUG: VideoInfoScanner: Skipping dir '/Volumes/pny256/TV/Ash vs Evil Dead/' due to no change
12:36:30 T:123145318477824 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/Volumes/pny256/TV/Awkward/'
12:36:30 T:123145318477824 DEBUG: FindMovie: Searching for 'Awkward' using The TVDB scraper (path: '/Users/brianharnett1/Library/Application Support/Kodi/addons/metadata.tvdb.com', content: 'tvshows', version: '1.8.3')
12:36:30 T:123145318477824 DEBUG: scraper: CreateSearchUrl returned <url cache="cache-Awkward-en.xml">http://thetvdb.com/api/GetSeries.php?seriesname=Awkward&language=en</url>
12:36:30 T:123145318477824 DEBUG: CurlFile::Open(0x117371960) http://thetvdb.com/api/GetSeries.php?ser...anguage=en
12:37:17 T:123145318477824 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 504
12:37:17 T:123145318477824 ERROR: CCurlFile::Open failed with code 504 for http://thetvdb.com/api/GetSeries.php?ser...anguage=en
12:37:17 T:123145318477824 ERROR: Run: Unable to parse web site
