I am currently looking into a box, that will follow these requirements:
- 3Gb of RAM or more
- Android 5 or more
- Google Play support
- Kodi support (of course!)
I also want to buy it from a Canadian website.
"3Gb of RAM or more"
Why exactly do you think you need this ?
(2016-01-18, 00:12)feathers Wrote: [ -> ]Why exactly do you think you need this ?
I am planning on doing some gaming, and as a Android Tablet user, I know that games
can lag.
NVIDIA Shield would be my pick if you are planning on gaming. It's probably the best Android box overall and has good support. Only downside is it's expensive but you get what you pay for.
The NVIDIA Shield is a good product, but it's a bit too much for my budget.
But I will keep this on mind, thanks!
(2016-01-18, 01:24)FelixINX Wrote: [ -> ]The NVIDIA Shield is a good product, but it's a bit too much for my budget.
You get what you pay for... long run Nvidia shield is a great purchase.
