(Caution: Noob-question)
i'm new to kodi, python and coding in general. I installed zags hello.world script and started playing with the addon.py. I managed to trigger a bash-script within the addon.py:
import os
bashCommand = "/bin/bash /home/pi/script.sh"
os.system(bashCommand)
So i was able to kill kodi.bin by simply adding
#!/bin/sh
killall kodi.bin
to script.sh.
However, if i try to mount an sshfs-filesystem via script.sh, nothing happens
echo password | sshfs -o allow_other -o password_stdin [email protected]:/ /media/ssh/
the sshfs-script is executed correctly by the addon.py when i run the python-script outside of kodi.
I run Kodi 15.2/Raspbian jessie on a Raspberry Pi 2
Thanks for your help!
ob
Does sshfs need to be run as root?
(2016-01-18, 15:13)el_Paraguayo Wrote: [ -> ]Does sshfs need to be run as root?
No, with raspbian default user "pi", it runs without sudo. But maybe it's a permissions problem. Unfortunately, i cannot test the script with user "kodi" scince i have no idea how to log in as "kodi" via terminal. Is this even possible on raspbian?
Permissions was my guess. No experience of sshfs though. Does Kodi run as a different user? if so, who owns /mnt/ssh/ and what are the permissions?
(2016-01-18, 16:11)el_Paraguayo Wrote: [ -> ]Permissions was my guess. No experience of sshfs though. Does Kodi run as a different user? if so, who owns /mnt/ssh/ and what are the permissions?
This is the output of ls -l
drwxr-xr-x 2 kodi pi 4096 Jan 6 21:43 ssh
Kodi runs indeed as a different user, named "kodi" which was autogenerated while installing kodi via apt-get.
EDIT: i just noticed, that, right after i ran the script in kodi, df -h gives the following output:
df: ‘/media/ssh’: Transport endpoint is not connected
Do you get any error output in your kodi.log file when you run the script?
(2016-01-18, 19:50)el_Paraguayo Wrote: [ -> ]Do you get any error output in your kodi.log file when you run the script?
No, however, here's the debug-log output:
19:03:00 T:1599075248 INFO: initializing python engine.
19:03:00 T:1599075248 DEBUG: CPythonInvoker(6, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): start processing
19:03:00 T:1835889584 DEBUG: PushCecKeypress - received key b duration 359
19:03:00 T:1599075248 NOTICE: -->Python Interpreter Initialized<--
19:03:00 T:1599075248 DEBUG: CPythonInvoker(6, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): the source file to load is "/home/kodi/.kodi/addons/script.hello.world-master/addon.py"
19:03:00 T:1599075248 DEBUG: CPythonInvoker(6, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): setting the Python path to /home/kodi/.kodi/addons/script.hello.world-master:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat
19:03:00 T:1599075248 DEBUG: CPythonInvoker(6, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): entering source directory /home/kodi/.kodi/addons/script.hello.world-master
19:03:00 T:1599075248 DEBUG: CPythonInvoker(6, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): instantiating addon using automatically obtained id of "script.hello.world" dependent on version 2.14.0 of the xbmc.python api
19:03:01 T:1599075248 INFO: CPythonInvoker(6, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): script successfully run
19:03:01 T:1599075248 INFO: Python script stopped
19:03:01 T:1599075248 DEBUG: Thread LanguageInvoker 1599075248 terminating
Maybe try using subprocess instead of os.system to catch the output of the sshfs command and print it so it shares in the log.
(2016-01-20, 20:17)Lunatixz Wrote: [ -> ] (2016-01-19, 10:38)el_Paraguayo Wrote: [ -> ]Maybe try using subprocess instead of os.system to catch the output of the sshfs command and print it so it shares in the log.
+1
Can you tell me how to do this? I tried
subprocess.Popen('echo password | sshfs -f -o allow_other -o password_stdin
[email protected]:/ /media/ssh >> /home/kodi/log.txt', shell=True)
log.txt is beeing generated, but stayed empty.
Something like this:
from subprocess import check_output, CalledProcessError
try:
cmd = "echo password | sshfs -f -o allow_other -o password_stdin [email protected]:/ /media/ssh"
subproc = check_output(cmd, shell=True)
print "SSHFS executed successfully. Output: {}".format(subproc)
except CalledProcessError, e:
print "SSHFS execution failed. Output {}".format(e.output)
It's ugly code and I don't recommend using "shell=True" normally but this is just for debugging.
(2016-01-21, 21:40)el_Paraguayo Wrote: [ -> ]Something like this:
try:
Thanks for the code!
As far as i can see, there is no output. Here's the related part of my kodi.log
11:20:30 T:1574355888 INFO: initializing python engine.
11:20:30 T:1574355888 DEBUG: CPythonInvoker(62, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): start processing
11:20:30 T:1574355888 NOTICE: -->Python Interpreter Initialized<--
11:20:30 T:1574355888 DEBUG: CPythonInvoker(62, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): the source file to load is "/home/kodi/.kodi/addons/script.hello.world-master/addon.py"
11:20:30 T:1574355888 DEBUG: CPythonInvoker(62, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): setting the Python path to /home/kodi/.kodi/addons/script.hello.world-master:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat
11:20:30 T:1574355888 DEBUG: CPythonInvoker(62, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): entering source directory /home/kodi/.kodi/addons/script.hello.world-master
11:20:30 T:1574355888 DEBUG: CPythonInvoker(62, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): instantiating addon using automatically obtained id of "script.hello.world" dependent on version 2.14.0 of the xbmc.python api
11:20:30 T:1835705264 DEBUG: PushCecKeypress - received key b duration 531
11:20:34 T:1574355888 NOTICE: SSHFS execution failed. Output
11:20:34 T:1574355888 INFO: CPythonInvoker(62, /home/kodi/.kodi/addons/script.hello.world-master/addon.py): script successfully run
11:20:34 T:1574355888 INFO: Python script stopped
11:20:34 T:1574355888 DEBUG: Thread LanguageInvoker 1574355888 terminating
pi@raspberrypi:/home/kodi/.kodi/temp $
I set sshfs to verbose-mode by adding -d
OK. But at least we can see that it is failing. So that's progress!
Let's tweak the code slightly. Try this:
from subprocess import check_output, CalledProcessError, STDOUT
try:
subproc = check_output(cmd, shell=True, stderr=STDOUT)
