2016-01-15, 19:16
So,I know that v17 is in it's early phases, but having a few minutes on my hands I decided to give the Krypton test build a try (kodi-20160112-61e14b1-master-armeabi-v7a.apk) on my SATV and found that vids with Atmos tracks were pretty much unplayable.
The audio would cut out (mostly out) and the video would drop frames.
Only settings that aren't default:
Adjust frame rate: on start/stop
Speaker channels: 5.1
Pass-through and all supported pass-through options selected.
Test file: http://www.mediafire.com/watch/375fdip5o...s_test.mkv
Debug log: http://xbmclogs.com/p2tixjyd7
This is pretty much the same thing that was happening with Koying's earlier PT test builds.
Also, with DTS tracks if I jumped the Chapter foward the audio/video would go out of sync, skipping back would put the audio back in sync. I don't have a debug log for this, but can get one if needed.
fritsch has been working on some test builds to fix PT issues.
How to help:
UPDATE:
Use nightly builds for testing: http://mirrors.kodi.tv/nightlies/android/arm/
How to help:
- Say if this was also an issue in regular builds or not.
- A debug log (wiki)
- The build date (in the download URL or in system info on Kodi)
- Details about your system (OS version, hardware specs, etc)
- Steps needed to reproduce the issue (play a movie, go to a file list, use an add-on, etc)
- The more details, the better.
UPDATE:
