This thread is for discussion related to the Intergalactic FM audio add-on. The source is maintained at
https://github.com/intergalacticfm/plugi...galacticfm
At the moment we are waiting that this plugin gets upgraded in the default repository for Kodi.
Currently the playing now information is not yet available on the server, but will be in about two weeks. At that time also the missing icon will be fixed. Stay tuned.
See also
http://forum.kodi.tv/showthread.php?tid=257201 for discussion on the video add-on for Intergalactic FM TV.
Looking forward to the update, Pander! I'll be sure to check out Intergalactic FM TV too!
Ah, I will also setup the link to these threads from within the plugins. (Note to self.)
Hi Pander,
for some days now the addon is not working anymore.
A few days ago something with the m3u playlists has changed (sorry, no log anymore there)
Right now it more seems like connection errors:
23:52:10 T:12248 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for http://95.211.225.124:1935/live/mfm/playlist.m3u8
23:52:10 T:12248 DEBUG: CCurlFile::GetMimeType - http://95.211.225.124:1935/live/mfm/playlist.m3u8 -> failed
23:52:10 T:12248 DEBUG: CurlFile::Open(00187F38) http://95.211.225.124:1935/live/mfm/playlist.m3u8
23:52:20 T:12248 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
23:52:20 T:12248 ERROR: CCurlFile::Open failed with code 0 for http://95.211.225.124:1935/live/mfm/playlist.m3u8
23:52:25 T:12248 DEBUG: Error, could not open file http://95.211.225.124:1935/live/mfm/playlist.m3u8
23:52:25 T:12248 ERROR: VideoPlayerCodec::Init: Error creating demuxer
23:52:25 T:12248 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://95.211.225.124:1935/live/mfm/playlist.m3u8
23:52:25 T:12248 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
23:52:25 T:12248 DEBUG: CApplication::OnQueueNextItem: play state was 1, starting 1
23:52:25 T:12248 DEBUG: CApplication::OnPlayBackStopped: play state was 1, starting 0
23:52:25 T:12248 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.intergalacticfm/ifm1]
23:52:25 T:12248 DEBUG: Playlist Player: one or more items failed to play... aborting playback
23:52:25 T:12248 DEBUG: ------ Window Init (DialogConfirm.xml) ------
23:52:25 T:16304 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
23:52:25 T:16304 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
23:52:25 T:12248 DEBUG: Window DialogConfirm.xml was already loaded
23:52:25 T:12248 DEBUG: Alloc resources: 3.53ms
23:52:25 T:12248 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://mirrors.kodi.tv (easy=14858E00, multi=11553400)
This will forcefully clear you cache and solve the problem
exit kodi
rm -rf ~/.kodi/userdata/addon_data/plugin.audio.intergalacticfm
start kodi
Normally, cache will fix this by itself.
(2016-05-16, 17:55)Pander Wrote: [ -> ]This will forcefully clear you cache and solve the problem
exit kodi
start kodi
Thx for the response @
Pander,
unfortunately
http://intergalacticfm.com/channels.xml is not existing and the xml parser tries to parse a 404 html site.
Would be really great if you could find a solution, I love the addon and the music!!!!
