2016-01-22, 11:25
2016-01-22, 12:47
are you using the correct format for multiple animations?
http://kodi.wiki/view/Animating_Your_Ski...ation_Tags
if you can't figure it out, please share the code you're using.
none of us are mindreaders :-)
2016-01-22, 14:13
omg, how could I forget about that... >.<
there is an error in this code segment, and I dont know where it is. :x
<animation type="Visible" condition="Window.IsActive(Home)" reversible="false">
<effect="slide" end="-500,0" time="200"/>
<effect="zoom" start="100" end="200" center="auto" time="2000" delay="200" reversible="true"/>
</animation>
</animation>
2016-01-22, 18:32
omg, found the error, I'm so dumb omg >.<
forgot to write "type" in the effect tag
2016-01-22, 18:54
I have another question, after doing the slide and zoom animation how do I do to make stay at the ending point?
For example:
Starting point- http://prntscr.com/9tfc2f
Ending point- http://prntscr.com/9tfdbm
For example:
