2007-08-18, 22:55
2007-08-18, 23:07
Yup rev9920, dosen't do it for avi files on HDD or LAN, just tvlinks.
(using TVLinksPM3 btw).
2007-08-18, 23:25
Never mind. Just did a clean install of XBMC, working beautifully now. And I can play MKVs again!
Thanks for your help, was probably some junk left over from the last upgrade.
2007-08-19, 20:10
Hey guys, anybody still have problems watching some links.
I have trouble with links hosted by t6.com, Stage6 and www2.tv-links.co.uk.
I have the latest XBMC by Tech installed, along with ltest TV links script. All installed from fresh.
Hope you can help.
Cheers
Hope you can help.
Cheers
2007-08-23, 01:26
ANy updates on this script?
I have a problem with some videos just cutting out after 20mins+
I also downloaded one episode of Farscape (Season one DNA episode) and it only downloads 25mb
I checked and it is all on there... It looks liek the links are sort of preview links... can this be fixed?
I am using the new version of tv-links and new version of xbmc
2007-08-23, 02:16
I have problems with episodes suddenly cutting off at random parts. I have to load it again, and patiently try to forward to the part that it cut off and continue from there. I reckon it happens about 80% of the time.
2007-08-23, 10:03
hassan Wrote:I have problems with episodes suddenly cutting off at random parts. I have to load it again, and patiently try to forward to the part that it cut off and continue from there. I reckon it happens about 80% of the time.
I think a lot of us are getting this problem.
Only seems to be certain sites though, like Veoh and myspace. Someone mentioned earlier that unless you are logged into Veoh, you can only watch the previews, maybe some of the other sites are the same...?
It is quite annoying, and apart from a few links not playing, is the only thing keeping this from perfection.
Whoever is working on this these days, best of luck.
2007-08-23, 17:46
Yes this is what I am getting. I checked the links and it has a /preview/ link in it so this is why it is no tworking.
Is there a way to fix this?
2007-08-23, 18:02
the veoh preview thing is only for some videos that are 40mins or more, they require you to download it and they only stream teh first 5 minutes of the video on the site
2007-08-23, 20:26
hassan Wrote:the veoh preview thing is only for some videos that are 40mins or more, they require you to download it and they only stream teh first 5 minutes of the video on the site
I have tried downloading the videos using the TV-Links (Other version) but I can only download 25MB of the show.
Is there a way to logn to the site using the script so we can get the full show.
It is frscape I am tryng to watch... The DNA pisode season on.
2007-08-23, 21:19
I have done some digging around an seen that it is not the videos but the Veoh website. Any videos over 40mins only play the first 5mins. The only way around it is to use the veoh downloader but that only works on Windows.
So is there a way to make the site think XBMC with TV-Links is the downloader?
Without this it will never happen.... It sucks as I do not own a Windows computer all mine are Linux (DSL-N and Ub)
Not sure if it can be done sadly but I guess you guys are the ones to ask.
2007-08-27, 02:14
that isn't the main reason it stops though, I mean, it does the same thing on other videos hosted on tudou as well.
When i said you have to download the video, I meant download it using the veoh downloader on windows.
2007-08-29, 08:58
2007-08-30, 02:48
People interested in TVLinks and Joox should have a look at the new python plugin folder feature in the latest T3CH svn. With this, you can browse TVLinks, Joox and Apple Movie Trailers as if they were on your HDD, from the normal video browser, not the scripts GUI. Watch this video:
http://www.youtube.com/watch?v=7M-MK3FnKOk
After showing XBMC's XORed trainer engine feature, it shows the TVLinks and AMT plugins.
Get the plugins from this thread:
http://forum.xbmc.org/showthread.php?tid=28031
2007-08-30, 12:33
Thanks for the info.
