I was wondering if someone would be able to make an add on for Pocket Casts (podcast app for Android/iOS/web).
It would be great to be able to keep podcasts in sync across devices and listen to them on Kodi when at home.
I would also appreciate this, an pocket casts app would be awesome!
Nicky
Another +1
It would be great to be able to "share" a podcast from pocketcast in the smartphone to kodi, and have kodi parse the URL that pocket-cast sends and start playing it back /queue it.
With yatse in the smartphone, I noticed that the URL reaches kodi but kodi doesn't know how to parse it
(2016-10-20, 00:14)originalgabriel Wrote: [ -> ]Looks like someone started it, but hasn't touched it for several months
https://github.com/sirl1on/plugin.audio.pocketcasts
Cool! Checking back on this after a long while. Glad someone's started it. Just have to figure out how to finish it.
Still hoping it can be done.
Thanks for the heads up.
(2016-11-04, 16:25)milkman dan Wrote: [ -> ] (2016-10-20, 00:14)originalgabriel Wrote: [ -> ]Looks like someone started it, but hasn't touched it for several months
Looks like they hit "alpha" stage, but I can't seem to find a repo to install it; I sent them an email to see if I can help test in order to speed up development.
sooo how to install it from github?
(2017-04-29, 19:02)Ewoks Wrote: [ -> ]sooo how to install it from github?
Follow the link in post #7 above, then click on clone or download, then click on download zip. Then install from zip in Kodi.
ah install from source zip is possible? didn't know that at all.. thanks
does it work for you ? For me I have login error check your credentials whereas I am sure they are good.
sorry for very late answer... YES it works...
do you have an idea why i doesnt work for me ?
What do have installed ? Any dependencies ?
