Actually you can add automatically in a movie set a film, if in the option there is activated the correct settings..."Add Movie automatically to Collections"
Example a Folder called Movies.
Into the folder is example 2 Movies Folder Called:
- Hotel Transylvania 1 (2012).
- Hotel Transylvania 2 (2015).
Into the Folder are the .ISO Files.
I add then into Movies folder from Ember Media Manager.
Then I go to Sets add New Set.
Add the Information.
It places onto the Sets.
But then it going wrong, when I try to Scrape from it then the information does knothing.
How can I fix this?
(2016-01-28, 19:26)DJHulp Wrote: [ -> ]Can you please tell me how to change the NFO & Artwork Offline from it.
https://www.themoviedb.org/translate/tv/...anguage=nl
The TMDB ID: 45782?
I always handle my sets manually, don't like how TMDB put movies together
In Set tab, right click and select create new set from context menu, call it what ever you like
Select the movies that you want in your new set (push it to the left side)
When you hit OK the movies nfo get updated with correct set info
For set images you have to download them manually outside of Ember and select them one by one
How can I place the Videos / Boxset into Kodi?
When I try it I only see into the Movies Tab from Kodi the Movies, not the Box Sets.
Thank You it works
, but only one problem is there away to add more folders for Searching to the BoxSets.
Example I have two External Drives with Movies.
I want to Place one folder with Boxsets from the Movies on that Drive.
But also search onto the Second Drive with a another Folder.
Is there away to let him Search both Drives at the same time?
Problem Solved!
Just leave it onto Enable: "Enable searching of a common parant folder".
And Search for it.
Also I forget to add the function on: Libary Settings -> Movies Box Set Enabled.
Thanks For The Awesome Help!
IS THERE AWAY TO ADD DISCS INTO SETS?
(2016-01-29, 15:14)DanCooper Wrote: [ -> ]Yes, you can add it in Ember under Expert settings: <setname>-discart.png, but it's not supported by MSAA.
But how can I scrape it then, I tryed it with Xtra Fanart, but it doesn't find the Boxsets Disc?
I tryed disc.png - 222-disc.png & 222-discart.png.
i have a fair few movie sets scanned into both my kodi installations, as you can see here, and i'm 99.99% sure kodi doesnt support a movieset discart....if i'm wrong, i would love to know how to do it.
i think it is skin dependant
