Hello together,
I have installed the last Kodi 17 Alpha and discovered, that the WMC-Addon is not in place.
Can you say, when it will be integrated in Kodi 17.
PS: Yes I now, that the current Version 17 is very unstable, but I'm snoopy.
Jeez, I am not even on Kodi 16 yet
Heiko123
I don't know, that is up to the kodi team. But I do know it comes with the windows version of kodi17 - at least when I downloaded it a few days ago.
ooh, I installed the last build from 28.01.2016,
but I dont find wmc-addon.
See the picture:
http://img4web.com/view/U2ED3B
And the bug is ,if I actived one of it, after restart all addon are disabled again.
I just installed Krypton to check and PVRwmc is NOT in the 1-28 build, probably some sort of build failure.
I guess I got it longer ago than I thought, this was the one I downloaded:
KodiSetup-20160117-5dc02e2-master.exe
Looks like the older builds cannot be downloaded, can you post the zipped Pvrwmc directory from your install somewhere? Hopefully it will work.
(2016-01-29, 04:13)krustyreturns Wrote: [ -> ]Here it is:
https://drive.google.com/file/d/0ByNnAMY...sp=sharing
Doesn't work, wrong api version
22:24:12 T:8536 ERROR: PVR - Add-on 'PVR WMC Client' is using an incompatible API version. XBMC minimum API version = '4.2.0', add-on API version '4.1.0'
Do you need to bump something to get it building again??
Just for completeness, the linked thread and PR is about upcoming changes that are not yet merged (thus not in the nightlies)
There was another API change in Krypton which HAS been merged and it's this one that we need to update to, in order to be back in the nightlies
https://github.com/xbmc/xbmc/pull/8896
