Full Version: Guidelines for Reviews
I'm happy to stick reviews that are written in the following format. You can find the text to copy and paste at the bottom.
You can see a completed example here.
Ambilight Clone
Manufacturer: XX
LEDs (per strip): XX
LEDs (total): XX
Zones: Optional
Processor: XX
Model Name: XX
Replacement for: [State whether or not this is a replacement for an existing device. e.g. you have replaced a Lightpack with a custom build]
Custom build: Yes/No
Television Information
Manufacturer: XX
Diagonal Size (inches or CM): XX
Aspect Ratio (16:9 is the standard): XX
Set-up
Try and describe how you found the hardware installation process. Was it simple, or did it take some time and adjustments?
Software
Operating System: XX
Back-end software: XX
Software Link (URL): http://XX
Kodi Add-ons, Integration, and Performance
Add-on(s) used: XX
Link to Add-on: http://forum.kodi.tv/XX
Recommended Add-on Settings: XX [e.g. throttle=100]
Performance: [is the Ambilight clone responsive? Other comments are welcomed here, a detailed description would be helpful]
Order Details
Store: XX [you can put a link, please observe the forum rules
Cost (GBP, EUR, USD): XX
Delivery Information: XX [e.g. It took two weeks to arrive]
Media
If you have a YouTube link or images, this would be an ideal place to put them.
Conclusion
Entirely optional.
Source to copy and paste for the above:
[size=large][b]Ambilight Clone[/b][/size]
[b]Manufacturer[/b]:
[b]LEDs[/b] (per strip):
[b]LEDs[/b] (total):
[b]Processor[/b]:
[b]Model Name[/b]:
[b]Replacement for[/b]:
[b]Custom build[/b]:
[size=large][b]Television Information[/b][/size]
[b]Diagonal Size[/b] (inches or CM):
[b]Aspect Ratio[/b] (16:9 is the standard):
[size=large][b]Set-up[/b][/size]
[size=large][b]Software[/b][/size]
[b]Operating System[/b]:
[b]Back-end software[/b]:
[b]Software Link[/b] (URL):
[size=large][b]Kodi Add-ons, Integration, and Performance[/b][/size]
[b]Add-on(s) used[/b]:
[b]Link to Add-on[/b]:
[b]Recommended Add-on Settings[/b]:
[b]Performance[/b]:
[size=large][b]Order Details[/b][/size]
[b]Store[/b]:
[b]Cost[/b] (GBP, EUR, USD):
[b]Delivery Information[/b]:
[size=large][b]Media[/b][/size]
[size=large][b]Conclusion[/b][/size]
