(2017-03-30, 23:54)marcelveldt Wrote: [ -> ] (2017-03-29, 00:08)Fake Healer Wrote: [ -> ]Marcel, I'm not sure if you have been notified of an issue where the header is not being displayed correctly. I'm using Netflix View 2 and when I'm trying to display the title+clock or weather+clock or anything for that matter on the Home Screen only, it's getting doubled. See the screen shot below...
Which version number of the skin? I've just tested but I can't reproduce this behaviour.
Titan Skin vs 3.7.56 > Kodi 17.1 Krypton is what I'm using. That's weird it's only me. It's happening on both Official and Beta versions. I thought because it was Beta something was a miss but it happens on the Official as well. The Official version is running on Amazon Fire Stick and the Beta is on my PC or the other way around I forgot
Anything else you can think of or what I could do before I reset and start over? Which is not that big of a deal.
What's happening I found is that on the Homepage and I go into the Menu, the header that is in the middle shifts over to the right. It's like the middle header(Which shouldn't be there) follows the menu for some weird reason
(2017-03-31, 00:12)marcelveldt Wrote: [ -> ] (2017-03-29, 20:49)Mario S. Wrote: [ -> ]I found a little bug see picture below !!
Which version of the skin are you using? It should already be fixed
Okay thanks you are fast
Is there any way to get Titan to show Australian Movie ratings?
Currently just setup Titan beta with Krypton 17.1 on a T95Kpro machine. Titan is set to Modern Low Horizontal. My issue is whenever I select a show to play it seems to lag and the "now playing..." hangs on top of the screen for a while before actually playing. Is there anyway to disable this and have it start playing right after the connection to the source is established?
Also, when I go to stop a program it also lags. Once I press stop it seems to take 10 or more seconds before it clears.
Any help would be appreciated. I have used Titan in the past and loved it.
Don't know if this has been addressed, but I upgraded to 3.7.59 and I had to redo all my custom colors and widgets.No big deal but was just curious. Thanks Sal.
(2017-04-02, 15:17)scalfa Wrote: [ -> ]Don't know if this has been addressed, but I upgraded to 3.7.59 and I had to redo all my custom colors and widgets.No big deal but was just curious. Thanks Sal.
Re downloaded the new repo now you can add new menu and sub menu...
sal
Hello guys
I have a simple question, how to hide watched movies from widgets?
Tnx
(2017-04-02, 18:14)Simonj82 Wrote: [ -> ]Hello guys
Tnx
Go to the skin helper widget addon settings and you'll see it there.
Hi Marcel, I'm using the classic for the media codec info style and they are overlapping in the latest beta
(2017-04-03, 01:04)aptalca Wrote: [ -> ] (2017-04-02, 18:14)Simonj82 Wrote: [ -> ]Hello guys
Tnx
I tryed like this:
System>skin setting>supported addons>skin helper widgets (1.0.26).
On Setting - skin helper services widgets i have enabled ( HIDE WATCHED ITEMS IN VIDEO WIDGETS) and stil is showing all movies (watched and non watched)
my widget is from exsodus > people watching
tnx for any help and advice
(2017-04-03, 14:07)aptalca Wrote: [ -> ]Reboot after the change
Nothing work for me
. I am using libreelec on my raspary 3......
Hi I am having a crazy issue with backgrounds. Too hard to describe so I made you a video.
Did it on the fly with phone sorry for quality but you will see the issues.
Thank you
hello, I'm having trouble. I downlaoded the skin and i cant find where to change the OSD for playbakc back to slim. I remember setting it but now have no idea how to get it back. your help is very much appreciated.
