2017-03-10, 23:05
(2017-03-09, 01:02)Joe123 Wrote: [ -> ]This is me clicking on Colombo and widgets dropping down to bottom covering up everything
This will be fixed in the next update. Are you running the beta version of the skin ?
(2017-03-09, 07:32)gadabout1 Wrote: [ -> ]***Cosmetic alignment problem on "Widget Rows -> Multiple widgets-multiple rows" "widget label alignment" problem when scrolling down to next widget
******Simple confluence-style homescreen vertical*******l
(2017-03-09, 10:19)Lyvean Wrote: [ -> ]Hey all. A small question because it is driving me crazy. What on earth is that "recordings" tab that appears on the main screen and it is just empty? There is an entire row that has the title 'recordings' that is empty and then, for example, my TV progress starts. TV progress is a bit chopped in the screen for that reason also.
Is this a bug or am I missing something obvious?
(2017-03-10, 18:45)malkair Wrote: [ -> ]How to show "ARTIST - ALBUM" labels on home screen music widget instead of default label ?
(2017-03-10, 20:42)badkarmaboy Wrote: [ -> ]Since enabling user profiles I have to reload the skin (Titan Beta 3.7.50) after a reboot or cold start, otherwise the skin setting labels and several sub-menu labels are empty. Looks like it's only affecting labels driven by Titan, not the built-in ones. They work, but no label is displayed. After issuing skin reload everything is present.
(2017-03-10, 23:20)mikeB2210 Wrote: [ -> ]When I try to add a movie as an Emby Favorit it does not adding the movie to the emby favorites.
Can you have a look at this. If you need more information, let me know.
(2017-03-10, 23:12)marcelveldt Wrote: [ -> ](2017-03-10, 20:42)badkarmaboy Wrote: [ -> ]Since enabling user profiles I have to reload the skin (Titan Beta 3.7.50) after a reboot or cold start, otherwise the skin setting labels and several sub-menu labels are empty. Looks like it's only affecting labels driven by Titan, not the built-in ones. They work, but no label is displayed. After issuing skin reload everything is present.
It's a known bug in Kodi Krypton.
For your secondary profile, make sure to set the Font just once.
Settings --> Appearance --> Skin --> Font
Somehow on seondary profiles it's set to empty
import xbmc
xbmc.executebuiltin('XBMC.ReloadSkin()')
xbmc.executebuiltin('XBMC.RunScript(script.skinhelper.service)')
12:41:09.892 T:1152 DEBUG: Skin Helper Simplecache --> Initialized
12:41:09.892 T:1152 DEBUG: Metadata and Artwork module --> Initialized
12:41:09.892 T:1152 NOTICE: Skin Helper Service --> Animated Art: lookup imdbid by title and year: (The Dark Knight - 2008)
12:41:10.051 T:1152 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: could not convert string to float: NA
File "Kodi\addons\script.skin.helper.service\resources\lib\context_animatedart.py", line 42, in <module>
imdb_id = get_imdb_id(WIN, ARTUTILS)
File "Kodi\addons\script.skin.helper.service\resources\lib\context_animatedart.py", line 31, in get_imdb_id
imdb_id = metadatautils.get_omdb_info("", title, year, content_type).get("imdbnumber", "")
File "\Kodi\addons\script.module.simplecache\lib\simplecache.py", line 285, in decorated
result = func(*args, **kwargs)
File "\Kodi\addons\script.module.metadatautils\lib\metadatautils.py", line 217, in get_omdb_info
result = self.omdb.get_details_by_title(title, year, content_type)
File "\Kodi\addons\script.module.metadatautils\lib\helpers\omdb.py", line 42, in get_details_by_title
return self.map_details(data) if data else {}
File "\Kodi\addons\script.module.metadatautils\lib\helpers\omdb.py", line 150, in map_details
result["rottentomatoes.userrating.percent"] = "%s" % (try_parse_int(float(value) * 10))
ValueError: could not convert string to float: NA
12:41:10.067 T:5432 DEBUG: ------ Window Init (DialogNotification.xml) ------
12:41:10.085 T:1152 WARNING: CPythonInvoker(118, \Kodi\addons\script.skin.helper.service\resources\lib\context_animatedart.py): the python script "\Kodi\addons\script.skin.helper.service\resources\lib\context_animatedart.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class XBMCAddon::xbmcgui::Window,class XBMCAddon::xbmcgui::Window,class XBMCAddon::xbmcaddon::Addon,class XBMCAddon::xbmcaddon::Addon,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmcgui::Window,class XBMCAddon::xbmcgui::Window,class XBMCAddon::xbmcgui::Window
12:41:10.085 T:1152 INFO: Python script stopped
(2017-03-06, 01:04)marcelveldt Wrote: [ -> ](2017-03-05, 16:05)Mario1979 Wrote: [ -> ]Hi, is it possible to show up the cd cover immediately when switching through the movie covers with the Titan skin?
The CD covers always took about 1-2sec and i want them to be shown immediately.
Which view(s) ? I've just tested a few and in all cases the discart was shown instantly.
Maybe your system is not powerfull enough ?
(2017-03-11, 15:54)stravic Wrote: [ -> ]Is there a repo I can add to get the beta skin rather than downloading the zip eveerytime a new beta is put out?
Quote:How to install the beta version?
1) Download the zipfile for my beta repository https://github.com/marcelveldt/repositor...-1.0.1.zip
(2017-03-11, 00:16)ashish1t Wrote: [ -> ]I am trying to add items to the submenu but the "Add" option is unclickable in settings (nothing happens). Also cannot add new main menu item on main menu (the "Add" button is not working). I am using the vertical layout (submenu options is enabled). This issue has started since I upgraded to 17.1 from the 17 Krypton version. Please assist. Many thanks
