About an hour ago all was working fine, now when I launch Kodi for the first time it wont load anything. For example Backup. I tried reinstalling multiple times, factory resets and different mirrors. Well and now obviously I cant download it at all online. Wtf
Same thing but i guess keyeing those repo one by one would be a temporary fix...
Which repository has an actual backup/restore tool??
Kodi's wont load at all. Halow has one but for some reason cant find a link that works..
The mirror redirector on mirrors.kodi.tv went offline, however that doesn't mean you can't download the zip's from any of our mirrors individually.
That should only influence
new installations and/or
new addon installations however.
Add-ons which you had installed and ran previously should not be influenced.
I'm very interested if you have an add-on that you had installed previously which did not work anymore. Which one was that ? - it might be using our infrastructure incorrectly.
This is for a new installation that I am trying to get my setup over to.
In that case, yes - when the mirrors are down you can't install any addon's from the official repo.
the file is missing on the mirrors.
19:03:58 T:140345144755968 ERROR: CCurlFile::Open failed with code 404 for
http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5
19:03:58 T:140345144755968 ERROR: Open - failed to open source <http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5>
19:03:58 T:140345144755968 ERROR: CRepositoryUpdateJob[repository.xbmc.org] failed read checksum for directory 'http://mirrors.kodi.tv/addons/krypton/addons.xml.gz'
(2016-01-29, 18:38)Kib Wrote: [ -> ]In that case, yes - when the mirrors are down you can't install any addon's from the official repo.
Still cant install any addon's from the official repo. Kodi was working and it seems right now I can still download it but not the addons?
i wanted to chime in on this issue.
from my end it appears this repo folder --> %mirrorurl%/xbmc/addons/isengard
is missing the md5
19:19:47 T:4644 ERROR: CCurlFile::Open failed with code 404 for http://mirrors.kodi.tv/addons/isengard/addons.xml.md5
19:19:47 T:4644 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.kodi.tv/addons/isengard/addons.xml.md5>
19:19:47 T:4644 ERROR: Failed to fetch checksum for directory listing http://mirrors.kodi.tv/addons/isengard/addons.xml for repository repository.xbmc.org.
hope that helps.
edit: looks like it's missing from the helix and jarvis folder too.
(2016-01-31, 02:25)jasonbwarren Wrote: [ -> ]i wanted to chime in on this issue.
is missing the md5
hope that helps.
nope, working fine:
e700e0900c7721b804c68e9fa5e1eb8e addons.xml
things are getting worse for me over here.
last night after a clean install Kodi would not acquire it's self update and populate it's repo. (see above for my snippet)
today this is happening.
14:03:53 T:7364 ERROR: CCurlFile::Open failed with code 404 for http://mirrors.kodi.tv/addons/helix/addons.xml.md5
14:03:53 T:7364 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.kodi.tv/addons/helix/addons.xml.md5>
14:03:53 T:7364 ERROR: Failed to fetch checksum for directory listing http://mirrors.kodi.tv/addons/helix/addons.xml for repository repository.xbmc.org.
so it's pointing to helix now?
i'm sad
It seems there are some problems still. After clean install of the krypton build I can't find some addons to install which are available in the repo. Repo update completes without errors but the missing addons don't appear.
