I'm trying to code a fret board and i'm stuck
I need to order key[1] with key[0]
EFGABCD
BCDEFGA
GABCDEF
DEFGABC
ABCDEFG
EFGABCD
any help please
key = ('EBGDAE','EFGABCD','1221222')
for i in range(len(key[0])): # = 'EBGDAE'
for s in key[1]: # = 'EFGABCD' I need to change the order here
print s,
if s != 'B':
if s != 'E':
print '#',
print
debug output
E F # G # A # B C # D #
i need this
B C # D # E F # G # A #
G # A # B C # D # E F #
D # E F # G # A # B C #
A # B C # D # E F # G #
don't need
C # D # E F # G # A # B
F # G # A # B C # D # E
I need to order key[1] with key[0][i]
EFGABCD
BCDEFGA
GABCDEF
DEFGABC
ABCDEFG
EFGABCD
any help please
print s,
if s != 'B':
if s != 'E':
print '#',
print
debug output
i need this
don't need
for s in range(len(key[1])):
if key[0][i] == key[1][s]:
print 'key[0][i] = ',key[0][i],' key[1][s] = ',key[1][s]
debug output
key[0][i] = E key[1][s] = E
key[0][i] = B key[1][s] = B
key[0][i] = G key[1][s] = G
key[0][i] = D key[1][s] = D
key[0][i] = A key[1][s] = A
can someone take a look at these pictures Please and tell me whats happening
25 ControlImage(x,y,1,60, RootDir + 'fill.png')" 'fill.png'=1x1 white pixel
screenshot in xbmc_pc note fret 8 13 20 width should be 1 "ControlImage(x,y,1,60, RootDir + 'fill.png')" 'fill.png'=1x1 white pixel
screenshot in xbmc here the width looks right but it fades to the bottom
picture from my phone of the tv picture is poor quality but it shows what is wronge plus the lines look way to thick
thanks
# ControlImage(x, y, width, height, filename[, colorKey, aspectRatio])
can some one tell me why aspectRatio default stretch fill.png produces colour bleeding
when aspectRatio default stretch fill.gif doesn't
is it do with colorKey 0x??FFFFFF if so how do i stop a 1x1 white pixel from bleeding the colour
i whan to use png's but i need strait lines
# fill.png = 181 bytes (1x1 white pixel)
look here fill png
ControlImage(x,y,1,60, RootDir + 'fill.png'))
# fill.gif = 807 bytes (1x1 white pixel)
look here fill gif
ControlImage(x,y,1,60, RootDir + 'fill.gif'))
thanks
it depends on how you create the png.
In photoshop, I notice if I change the opacity for the level it screws up, but if i create the level with fill at the opacity I want it works fine.
I'm no photoshop expert, so I hope that helps.
thanks Nuka1195 for you reply
it works well with a 1 pixel gif but not with a 1 pixel png
png seems to render half white half transparent even if the png is set to no transparency
if i use a png with 2 white pixels it works
thanks
