Full Version: Question for Star Wars: Rebels
I'm trying to scrape Star Wars: Rebels in TheTVDB and can't figure out the right naming convention. The first episode is considered a Special along with a bunch of other specials. It's called "The Spark of Rebellion" and on the DVD it was broken into two parts. The next bunch of episodes are nomral s1e1, etc. Any suggestion on how to handle this? Thanks.
http://www.thetvdb.com/?tab=season&serie...0285&lid=7
Here you can see an example of naming which should work:
c:\TV Shows\Star Wars: Rebels\Season 0\SW Rebels 0x07.1.mkv
c:\TV Shows\Star Wars: Rebels\Season 0\SW Rebels 0x07.2.mkv
PS: Change folders etc depending of your current setup
Wink
Will give that a try later. Thanks!
