Hi
Currently using MQ6 with Isengard and want to start using Jarvis. Anyone had any feedback on how MQ6 4.2.0 is working with Jarvis?
You will be better off using Skin MOD - AEON MQ6 new moded version 3.3.0.1 (Now 3.3.07) same thing but enhanced way past 4.2
And still being improved....no updates for 4.2 period.
TRY THIS!
http://forum.kodi.tv/showthread.php?tid=253368
(2016-02-01, 05:00)melons2 Wrote: [ -> ]You will be better off using Skin MOD - AEON MQ6 new moded version 3.3.0.1 (Now 3.3.07) same thing but enhanced way past 4.2
TRY THIS!
But this is only for Isengard and AEIN MQ6 3.30 as base, not the Jarvis version?
(2016-02-01, 11:24)querty1000 Wrote: [ -> ] (2016-02-01, 05:00)melons2 Wrote: [ -> ]You will be better off using Skin MOD - AEON MQ6 new moded version 3.3.0.1 (Now 3.3.07) same thing but enhanced way past 4.2
TRY THIS!
I am running it with Jarvis........never on Isengard.
Does it work with the new series record dialogs in PVR?
I am sorry, I don't use PVR and can't answer. Give it a try.
I have a weird error on the shield android tv with kodi. If I try to exit kodi with this skin active the box locks up and I have to power cycle. This does not happen with the confluence or mimic skin.
Hello to all,
I've installed kodi Jarvis 16.1 and when i try to install this Aeon MQ6 mod, I have an error message, the same as if this add-on was not compatible.
Can you tell me which method i should use in order to install it correctly ?
Thanks for helping.
