Full Version: music video add on
Hello
when I am installing KODI I get this message that says TheAudioDB.com music video add on is incompatible or has been marked broken would you like to disable it in your system YES or NO? which do I chose
and in case it matters I am running windows 10 I also noticed when I unzipped the file that it didn't seem to be installing
You can choose "yes", because it has been disabled, so even if you pick "no" you will not get any results when you use the scraper.
http://forum.kodi.tv/showthread.php?tid=...pid2175323
