Full Version: Nightly build / Developer thread
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Hello...
Thank you !
Hello,
Recently the genres are no longer written in FR, despite the choice FR.
Thank you in advance.
Thx. Already found the problematic code.
(Genres are not translated at all currently)
Thank you so much !
is it possible to change <source> to <videosource> instead??
Media compannion use <videosource>UHD Blu-ray</videosource>
(2019-03-28, 11:45)Atomixo Wrote: [ -> ]is it possible to change <source> to <videosource> instead??
Unfortunately there are no conventions for Media Manager internally used tags.
But it would be great and collaborative if the Media Manager maintainer could agree.
(2019-03-25, 19:30)myron Wrote: [ -> ]Thx. Already found the problematic code.
Hello,
I just rewrote all the NFOs and redid my database Kodi thinking that it was resolved in the last version, because I have genres that are translated and others not ... Big Grin
Sorry and thanks in advance
Window dialog sizing issues?
Scrape, edit, etc. and various dialog boxes have the title bar pop off the top of the screen/monitor.
Using a laptop with additional monitor. Minimizing taskbar brings title bar back into view, but reoccurs on next instance.
Toggling "Store window sizes/locations" under Misc. settings appear to have no effect.
Wasn't an issue in 2._ versions until I took 3._ out for a spin.
If it's inappropriate to post this here or if the issue has already been addressed, my apologies.
Otherwise, keep up the fabulous work.
we've switched to let the system draw the window decorations, maybe this issue is from there?
which resolution do you have on your laptop (inbuilt screen and external one)
Hello
I love the clean unwanted files option (nightly v4).
Could you please add a filter or ignore the BDMV directories?
In Filter > Enable filtering > Filter presets is empty
- files from VIDEO_TS, BDMV, HVDVD_TS will be ignored with the next version
- You have to define your own filter presets (just set up any filter and then press the save button)
(2020-09-15, 12:42)mlaggner Wrote: [ -> ]- files from VIDEO_TS, BDMV, HVDVD_TS will be ignored with the next version
* fix: ignore files from disc folder for "clean unwanted files"
works. Thank you
I will try the filer now. I thought I had to select one from the drop box.
*update*  I was looking for my list being sorted on date added. I guess I was looking at the wrong place or misunderstood filtering
The sync option to kodi are broken
Would it be possible to update the MediaInfo output in v4 - the "Video bitrate" section shows instead the "Overall bit rate".  The overall bit rate is actually the combined audio+video streams bitrates in the entire file, rather than just relating to the video stream.
In below example, video bitrate is 25.0 Mb/s, but shown in TMM as 26.7 Mb/s.
Cheers,
-jj-
General
Unique ID                                : 42980537085731811330851908669629328711 (0x2055C0164701C33D470505E5F11CED47)
Complete name                            : \\TOWER2\disk14\Share\movies\last embrace (1979)\last embrace (1979).mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 19.0 GiB
Duration                                 : 1 h 41 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 26.7 Mb/s
Encoded date                             : UTC 2020-09-17 21:52:58
Writing application                      : MakeMKV v1.15.2 win(x64-release)
Writing library                          : libmakemkv v1.15.2 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings                          : CABAC / 3 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 3 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate mode                            : Variable
Bit rate                                 : 25.0 Mb/s
Maximum bit rate                         : 40.0 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Standard                                 : NTSC
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.503
Stream size                              : 17.8 GiB (94%)
Writing library                          : x264pro - Adobe CS Exporter Plug-in
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=25000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Language                                 : English
Default                                  : No
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Original source medium                   : Blu-ray
Audio
ID in the original source medium         : 4352 (0x1100)
Format                                   : DTS XLL
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-HD Master Audio
Codec ID                                 : A_DTS
Bit rate                                 : 1 684 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossless
Stream size                              : 1.20 GiB (6%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter 01
00:07:29.782                             : en:Chapter 02
00:16:36.954                             : en:Chapter 03
00:26:04.854                             : en:Chapter 04
00:35:43.057                             : en:Chapter 05
00:41:54.762                             : en:Chapter 06
00:49:07.402                             : en:Chapter 07
01:02:14.063                             : en:Chapter 08
01:07:34.550                             : en:Chapter 09
01:15:29.024                             : en:Chapter 10
01:24:50.752                             : en:Chapter 11
01:31:59.013                             : en:Chapter 12
Bought a V4 license and playing with the latest V4 nightly version, I came across the following. When using the new universal TV show scraper the episode thumbs are not found/downloaded.
Have all boxes on "TVDB" except both ratings, those are on "IMDB".
When changing the scraper back to TMDB it works, could it have something to do with the option "Fallback language...." which is not available when using the universal scraper?
