2016-04-03, 20:13
2016-04-04, 09:37
thx... wil check that.
FYI:
Just merged some biiig changes into devel... so it might be quite unstable the next days... especially the update datasources...
FYI:
2016-04-14, 19:09
ok, the new and improved "update datasources" has been quite finished (for movies and TV shows)
It should at least work as before, but with improved speed (less I/O) and some additional tweaks/fixes.
Please report any issue you find
2016-04-17, 10:52
When updating the data sources unfortunately System directories are read
(System Volume Information; $recycle).
2016-04-18, 08:45
With latest nightly, Updating data sources is mind blowingly fast! Kudos!!
Edit: On the other hand, filtering episodes seem to hang the application. I will test it more.
2016-04-20, 10:38
(2016-04-17, 10:52)spike13 Wrote: [ -> ]When updating the data sources unfortunately System directories are readThanks, should be already fixed.
Missed a check in the root datasource dir
2016-04-24, 18:07
2.8 latest build won't scrape any episodes.
Edit: Try scraping "That '70s show" please.. I am getting this -
Quote:03:45:43.158 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=UNKNOWN_CAUSE, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/73787/all/en.xml
2016-04-26, 08:30
hmm... works here.
It seems, there's a network problem for you;
TMDB did not receive a valid webpage of that show (with an <id> in it) ResponseCode 0?!?
Are you using a proxy or so?
Did this log message occur asap, or after some time (timeout?)
2016-04-27, 04:47
(2016-04-26, 08:30)myron Wrote: [ -> ]hmm... works here.
Not using any proxy and log message appears instantaneously. No timeout!
2016-05-02, 07:05
Any plans of adding the ability to download subtitles for TV shows too?
2016-05-02, 07:32
this will be implemented as far as we have enough resources
2016-05-02, 16:45
(2016-05-02, 07:32)mlaggner Wrote: [ -> ]this will be implemented as far as we have enough resources
cool.. kudos for adding sub support for movies btw. A unique feature I think and so very helpful!
2016-05-11, 15:45
@akya subs scraping for TV shows should be in the nightly build today (settings for the scraper will be in the build tomorrow)
2016-05-12, 19:12
2016-05-23, 04:56
When I sort movies by Date added / Descending, Not watched movies appear first irrespective of the date they were added.
