Next PVR backend, Fire TV 1st version for kodi client. I launched kodi and within a few seconds navigated to TV/Guide. The guide appeared empty for about a second and the application quit. Log uploaded and available at link below.
http://xbmclogs.com/piwbnjc6q
Can you reproduce the crash or did it happen just one time?
Cannot give any guarantees as your log does not contain enough data to be sure, but there are chances that this is fixed in (not yet released) RC3. I merged a fix that might cure the crash you experienced.
Thanks for the response. This is the second time I experienced this issue but it is not every time repeatable. I will report back here if it happens again. Should I enable debugging from here on out to catch some extra information?
yes....enabled debugging so the log will have more info
