2016-02-03, 09:45
Hi guys, I'm using Kodi on a Philips Android TV and i was wondering how can substitute the thumbnails folder which by default is on the internal storage on the tv (which has only 500 MB of usable storage left) to an USB stick.
I have found this on the kodi wiki, but i don't know what might be the correct syntax of the current path and the new path which the existing and new thumbs would be copied/stored
Main page: Path substitution
Path substitution is another advancedsettings.xml tag. If you simply need more space for Kodi's files but don't wish to limit the image quality then you can use path subs to relocate the images to another drive. The cached images in the Thumbnails folder takes up the most amount of space of all the different Kodi files, so using pathsubs on that folder alone is often all you need to do. It's even possible to use a network file share path, but it is recommended that you use another local drive, if possible, for performance reasons.
If you have not made an advancedsettings.xml file before, see the example in the above section #Limit the size of cached images.
Note: If you have an existing advancedsettings.xml file, make sure the <pathsubstitution></pathsubstitution> tags are between the main <advancedsettings></advancedsettings> tags.
<advancedsettings>
<pathsubstitution>
<substitute>
<from>special://profile/Thumbnails/</from>
<to>smb://10.0.0.3/Thumbnails/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
<advancedsettings>
<pathsubstitution>
<substitute>
</substitute>
</pathsubstitution>
</advancedsettings>
