Hi everyone. Very new to this and struggling quite a bit but keen to learn. Could any one tell me how to disable/remove from my TV SHOWS menu the latest added episodes.All i want as a background is an uninterupted image.Thanks
To answer your question - go into skin settings > Home menu items and disable the widget set linked to the tv shows menu.
But...
CCM is a bit of a dead-end. It is / was a brilliant skin, but it hasn't been updated since Helix (v14). It would make sense to switch to Xonfluence if you're running v15, as Helly has based this on CCM and when you update Kodi the skin will continue to work properly.
Your better off to use Xonfluence on 15.2.
How do i set my own images up as background image for moviess/tv shows/ sport.etc.I found it easy with ccm but cant get them on xonfluence.I have the images that i want to use saved to Dropbox .
