Is there a place I can find your latest build @
wrxtasy ? A github or something else .
Coming from rb build I only need to add the .nocompat and it will work without drawing my data ?
Away from my LE compiler machine for a while thousands of KM's from home. Post #1548 of this thread has all the current release details.
Hello
i need help.
Just tried to move from raybuntu build kb19 to wrxtasy as per post #1548 (including the nocompat tip). Everything went well but TvHeadEnd doesn't want to load.
Shared library failed to load as per
00:52:30.745 T:545608634592 ERROR: Unable to load /storage/.kodi/addons/pvr.hts/pvr.hts.so.3.4.27, reason: /storage/.kodi/addons/pvr.hts/pvr.hts.so.3.4.27: wrong ELF class: ELFCLASS32
I guess this is 32/64bits related but even when removing the client rebooting and then reinstalling the error remains the same.
What can I do ?
(2018-01-11, 02:01)jotenakis Wrote: [ -> ]
this is ok, I needed to clean the app cache
rm -rf /storage/.kodi/addons/packages
Now it works
Now I have switched to wrxtasy I can no longer ssh access my device. libreelec root password is not working. Why ?
(2018-01-12, 22:44)wrxtasy Wrote: [ -> ]Try Password - le
Failed too
"le" (no quotes) or you're making a typo when entering it. ;-)
What a pity : just found out wrxtasy build does not auto switch my TV framerate to 24fps when required whereas it is supposed to do so and rb build does... 😓
What can I do ?
To be more precise : 24fps movie auto switch is ok. 23,976fps movie auto switch not working.
My gui resolution is 1920x1080p/50fps (same behaviour when 60fps set).
(2018-01-13, 20:19)jotenakis Wrote: [ -> ]To be more precise : 24fps movie auto switch is ok. 23,976fps movie auto switch not working.
With GUI set to 24fps, when playing a 23.976 movie TV framerate is switched to 25fps...
Query- will the Odroid C2 support hdmi 2.0a, with audio pass through for kodi via Libreelec - HDR UHD 4K Dolby Vision, Atmos DTS-X etc - have a NAS box with 4k videos and a good surround sound system
wrxtasy is this possible
According to hardkernel, it is HDMI 2.0
It supports passthrough audio over HDMI.
HDR not supported AFAIK.
Try looking at post 2 in this thread.
The C2 is an AML S905, refer to the chart in the following thread:
Choosing a S905 / S905X / S905D / S905W / S912 box guide
@jotenakis, there has been no changes regarding refresh switching. It all works same as it always has done, the only addition is 720p content will force a Kodi resolution switch downward to actually output at 720p so a 1080p/4K TV can do the picture upscaling.
