2016-10-24, 00:02
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
2016-10-25, 02:19
Hi, just purchased the C2, installed libreelec 7.1.0 using Oct.tar found in one of the posts here. Everything works fine until I browse to my movie share which has about 300 movies and it crashes and reboots everytime !
I have 3 other Kodi (all 16.1) machines (2 x windows, 1 android) using sames shares and all working fine.
Log gives no useful info .. any suggestions as to whats going wrong here ?
edit: also tried 7.90 and same problem exists .. I'm stumped .
edit2: I'm convinced it's related to the artwork as before I populate the database it seems to browse fine.
2016-10-25, 04:18
I got my odroid c2 today from hardkernel. Is anyone running the Krypton beta build? Curious to hear from anyone who is, any big issues or is it mostly workable?
Also for latest builds, does anyone have the github shortcut? The odroid.com site is down and I think that's where I wrxtasy had them linked.
Damn odroid.com has been down for hours...... does this happen often?
2016-10-25, 05:07
Not sure what has happened to the Odroid forums, they have been offline for the last 12 hours at least, and yes it is very unusual.
LibreELEC-Odroid_C2.aarch64-7.1.0.Aug.img.zip
LibreELEC-Odroid_C2.aarch64-7.1.0.DDR.Clock.tar
The easy C2 setup Mini Guide:
1) Download the LibreELEC USB-SD Creator App from HERE
2) Choose Odroid C2 > Local Image File > LibreELEC-Odroid_C2.aarch64-7.1.0.Aug.img.zip
3) Choose your mSD card and "Write" it. Eject > Insert into the C2.
4) Make sure you select both SSH and SMB connect options on the setup screens when LE first runs.
5) If an Update is needed use an appropriate .tar update file, and from a PC, follow the instructions found HERE
6) Enjoy !
@Mr.A
Reboots, sounds like a power supply issue, especially when two different versions of Kodi are having the same problems. 2.5" Hard Drives need to be run from a powered USB Hub. No ARM based device - RPi's, WeTeks, C2's etc can supply enough USB power reliably.
Or you have .zip's or .rar's in the directory along with your media files, those files may be causing problems when Kodi tries to interrogate them.
6) Enjoy !
@Mr.A
2016-10-25, 05:50
Thankyou!
2016-10-25, 13:35
(2016-10-25, 04:03)nickr Wrote: [ -> ]debug log (wiki)
10:30:37 T:547469139968 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:30:37 T:547469139968 NOTICE: -----------------------------------------------------------------------
10:30:37 T:547469139968 NOTICE: Starting Kodi (16.1 Git:c327c53). Platform: Linux ARM 64-bit
10:30:37 T:547469139968 NOTICE: Using Release Kodi x64 build
10:30:37 T:547469139968 NOTICE: Kodi compiled Aug 16 2016 by GCC 5.3.0 for Linux ARM 64-bit version 3.14.65 (200257)
10:30:37 T:547469139968 NOTICE: Running on LibreELEC (WRXTASY) - Version: 7.1.0 7.0, kernel: Linux unknown CPU family 64-bit version 3.14.65
10:30:37 T:547469139968 NOTICE: FFmpeg version: 2.8.6
10:30:37 T:547469139968 NOTICE: 4 CPU cores available
10:30:37 T:547469139968 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
10:30:37 T:547469139968 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
10:30:37 T:547469139968 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
10:30:37 T:547469139968 NOTICE: special://home/ is mapped to: /storage/.kodi
10:30:37 T:547469139968 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
10:30:37 T:547469139968 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
10:30:37 T:547469139968 NOTICE: Local hostname: oDroidLE
10:30:37 T:547469139968 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
10:30:37 T:547469139968 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
10:30:37 T:547469139968 NOTICE: load settings...
10:30:38 T:547469139968 NOTICE: Found 2 Lists of Devices
10:30:38 T:547469139968 NOTICE: Enumerated ALSA devices:
10:30:38 T:547469139968 NOTICE: Device 1
10:30:38 T:547469139968 NOTICE: m_deviceName : default
10:30:38 T:547469139968 NOTICE: m_displayName : Default (AML-M8AUDIO S/PDIF)
10:30:38 T:547469139968 NOTICE: m_displayNameExtra:
10:30:38 T:547469139968 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
10:30:38 T:547469139968 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
10:30:38 T:547469139968 NOTICE: m_sampleRates : 44100,48000,88200,96000,176400,192000
10:30:38 T:547469139968 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE
10:30:38 T:547469139968 NOTICE: Enumerated PULSE devices:
10:30:38 T:547469139968 NOTICE: m_deviceName : Default
10:30:38 T:547469139968 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
10:30:38 T:547469139968 NOTICE: m_deviceType : AE_DEVTYPE_PCM
10:30:38 T:547469139968 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
10:30:38 T:547469139968 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
10:30:38 T:547469139968 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
10:30:38 T:547469139968 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>20</clienttimeout>
</samba>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>157286400</cachemembuffersize>
<readbufferfactor>20</readbufferfactor>
</network>
<pvr>
<minvideocachelevel>10</minvideocachelevel>
<minaudiocachelevel>15</minaudiocachelevel>
</pvr>
</advancedsettings>
10:30:38 T:547469139968 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:30:38 T:547469139968 NOTICE: Default DVD Player: dvdplayer
10:30:38 T:547469139968 NOTICE: Default Video Player: dvdplayer
10:30:38 T:547469139968 NOTICE: Default Audio Player: paplayer
10:30:38 T:547469139968 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:30:38 T:547469139968 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:30:38 T:547469139968 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:30:38 T:547469139968 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:30:38 T:547469139968 NOTICE: Loaded playercorefactory configuration
10:30:38 T:547469139968 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:30:38 T:547469139968 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:30:38 T:547469139968 NOTICE: LoadFromXML - unable to load:/storage/.kodi/userdata/wakeonlan.xml
10:30:38 T:547460739296 WARNING: CActiveAE::StateMachine - signal: 3 from port: OutputControlPort not handled for state: 2
10:30:38 T:547469139968 NOTICE: Running database version Addons20
10:30:38 T:547469139968 NOTICE: ADDONS: Using repository repository.xbmc.org
10:30:38 T:547469139968 NOTICE: ADDONS: Using repository repository.libreelec.tv
10:30:38 T:547469139968 ERROR: AML: no rw on /sys/class/ppmgr/ppmgr_3d_mode
10:30:38 T:547469139968 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic
10:30:38 T:547469139968 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480i @ 60.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576i @ 50.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
10:30:38 T:547469139968 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
10:30:38 T:547469139968 NOTICE: Found ([email protected]) at 22, setting to RES_DESKTOP at 16
10:30:38 T:547469139968 NOTICE: Checking resolution 16
10:30:38 T:547469139968 NOTICE: CEGLNativeTypeAmlogic::SetNativeResolution to [email protected]
10:30:38 T:547469139968 NOTICE: CEGLNativeTypeAmlogic::SetDisplayResolution to 1080p60hz
10:30:38 T:547469139968 NOTICE: CEGLNativeTypeAmlogic::DealWithScale Set native size resolution 1920x1080
10:30:38 T:547469139968 NOTICE: GL_VENDOR = ARM
10:30:38 T:547469139968 NOTICE: GL_RENDERER = Mali-450 MP
10:30:38 T:547469139968 NOTICE: GL_VERSION = OpenGL ES 2.0
10:30:38 T:547469139968 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
10:30:38 T:547469139968 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
10:30:39 T:547469139968 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
10:30:39 T:547469139968 NOTICE: Running database version Addons20
10:30:39 T:547469139968 NOTICE: Running database version ViewModes6
10:30:39 T:547469139968 NOTICE: Running database version Textures13
10:30:39 T:547469139968 NOTICE: Running database version MyMusic56
10:30:39 T:547469139968 NOTICE: Running database version MyVideos99
10:30:39 T:547469139968 NOTICE: Running database version TV29
10:30:39 T:547469139968 NOTICE: Running database version Epg11
10:30:39 T:547469139968 NOTICE: start dvd mediatype detection
10:30:40 T:547469139968 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:30:40 T:547469139968 NOTICE: ActiveAE DSP - starting
10:30:40 T:547469139968 NOTICE: initialize done
10:30:40 T:547469139968 NOTICE: Running the application...
11:15:27 T:547469139968 NOTICE: starting zeroconf publishing
11:15:27 T:547469139968 NOTICE: WebServer: Started the webserver
11:15:27 T:547469139968 NOTICE: starting upnp client
11:15:27 T:546417144032 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
11:15:27 T:546417144032 NOTICE: UDP: Listening on port 9777
11:15:27 T:546853351648 NOTICE: ## LibreELEC Addon ## 0.7.3
11:15:27 T:546853351648 WARNING: CSkinInfo: failed to load skin settings
11:15:28 T:547115688160 ERROR: CecLogMessage - Write: write failed !
11:15:29 T:546816938208 ERROR: Previous line repeats 1 times.
11:15:29 T:546816938208 ERROR: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/b/b153bd90.jpg
11:17:19 T:547469139968 ERROR: Unable to activate the previous window
2016-10-25, 16:19
What Skin are we using here ?
2016-10-25, 22:25
(2016-10-25, 16:19)wrxtasy Wrote: [ -> ]What Skin are we using here ?
Confluence .. this is a fresh install with nothing added but sources.
2016-10-26, 07:02
Is the LibreELEC-Odroid_C2.aarch64-7.1.0.DDR.Clock.tar build the latest build? Is it possible to include dates in future builds to help us keep track?
2016-10-26, 10:04
(2016-10-25, 22:25)Mr.A Wrote: [ -> ]Fresh installs do not have this problem, otherwise the forum would be overrun with such problems.(2016-10-25, 16:19)wrxtasy Wrote: [ -> ]What Skin are we using here ?
You have either:
- bad scraping data, leading to this corrupt b153bd90.jpg file
- a corrupted flash of the mSD card or eMMC
- unreliable power supply issues
- unreliable mSD / eMMC card, leading to corrupted data.
I'm yet to see a .jpg crash and reboot a properly working Kodi device.
@Jdiesel, yes that is the latest release, trust me. I'm now on a monthly release cycle, so in the Oct LE 7.1 thread, you usually just download the latest .tar in there. All the rest in other threads are tests .tar's built on top of Each monthly release.
2016-10-26, 22:58
(2016-10-26, 10:04)wrxtasy Wrote: [ -> ](2016-10-25, 22:25)Mr.A Wrote: [ -> ]Fresh installs do not have this problem, otherwise the forum would be overrun with such problems.(2016-10-25, 16:19)wrxtasy Wrote: [ -> ]What Skin are we using here ?
You have either:
Thanks for that, I had already eliminated most of these but after reading your post, decided to change the power supply .. seems to be working now !
2016-10-28, 18:06
I had a similar issue. The C2 worked fine for a while then locked up. I tried a new mSD and even wiped the old mSD then I checked the power adapter and was like DUH. It's been great ever since.
Sent from my SM-N920V
2016-10-28, 19:08
I have got two usb power supply units here. One from an old Samsung phone and one from an old iPhone. First I started with the samsung psu and had these reboot errors. After some advices here in this thread I changed to the iPhone psu. Since that I didn't had any unexpected reboots.
Greetings Hoppel
Greetings Hoppel
2016-10-29, 02:11
Is here anybody else with such an "adjust display refresh rate" issue?
https://forum.libreelec.tv/thread-1497-p...l#pid17411
It doesn't matter if I set it up to "on start / stop" or "always". I am at a resolution of 1920x1080p and a refresh rate of 50Hz under "system - video output" by default.
Greetings Hoppel
Greetings Hoppel
