Full Version: Multiple hangs while trying to clean the video library
Hello,
Just updated to Jarvis RC2 and I get constant hangs when trying to clean the video library:
Here are some of the repeating error messages I see in the system log:
2016. 02. 03. 15:10:45,474 com.apple.xpc.launchd[1]: (org.xbmc.kodi.56032[12248]) Service exited due to signal: Killed: 9
2016. 02. 03. 15:10:50,030 Kodi[12265]: CPSGetCurrentProcess(): This call is deprecated and should not be called anymore.
2016. 02. 03. 15:10:50,030 Kodi[12265]: set_foreground_operation_state(): This call is deprecated and should not be called anymore.
2016. 02. 03. 15:10:50,285 Kodi[12265]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.11.3. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
2016. 02. 03. 15:10:50,285 Kodi[12265]: 0   CarbonCore                          0x00007fff8ae46c9b ___Gestalt_SystemVersion_block_invoke + 113
2016. 02. 03. 15:10:50,285 Kodi[12265]: 1   libdispatch.dylib                   0x00007fff9b8f633f _dispatch_client_callout + 8
2016. 02. 03. 15:10:50,285 Kodi[12265]: 2   libdispatch.dylib                   0x00007fff9b8f6237 dispatch_once_f + 67
2016. 02. 03. 15:10:50,285 Kodi[12265]: 3   CarbonCore                          0x00007fff8add2b47 _Gestalt_SystemVersion + 987
2016. 02. 03. 15:10:50,285 Kodi[12265]: 4   CarbonCore                          0x00007fff8add1ddb Gestalt + 139
2016. 02. 03. 15:10:50,286 Kodi[12265]: 5   libSDL-1.2.0.dylib                  0x0000000109c91e38 QZ_VideoInit + 152
2016. 02. 03. 15:10:50,286 Kodi[12265]: 6   libSDL-1.2.0.dylib                  0x0000000109c8246d SDL_VideoInit + 973
2016. 02. 03. 15:10:51,333 WindowServer[150]: disable_update_timeout: UI updates were forcibly disabled by application "Kodi" for over 1.00 seconds. Server has re-enabled them.
2016. 02. 03. 15:10:51,961 Kodi[12265]: NEPTUNE_LOG_CONFIG not found in 'Info.plist'
2016. 02. 03. 15:10:51,988 WindowServer[150]: common_reenable_update: UI updates were finally reenabled by application "Kodi" after 1.67 seconds [0.60fps] (server forcibly re-enabled them after 1.02 seconds [1.00fps])
2016. 02. 03. 15:10:52,543 spindump[265]: Saved hang report for Kodi version 16.0.rc2 (Git-20160128-46175d6) to /Library/Logs/DiagnosticReports/Kodi_2016-02-03-151052_Adi-MacBook-Pro.hang
Where can I upload the hang report?
Thank you!
