Full Version: Kodibuntu No network devices available
Hello
I have just installed Kodibuntu and its saying that its needs a hardware accelerated OpenGL driver so no problem so just update the drivers but the problem I have is Kodibuntu is not detecting the on-board wired network and I don't have wifi on this machine and it just says "No network devices available" I have tried looking on this forum and I can only find how to set up wifi and wifi drivers and Google is no help at all.
The motherboard I am using is ASRock Intel H110M with Intel I219 network chip
Any ideas?
might be a bit complicated if you don't have a internet connection, but you could try to SSH (wiki) in and copy and paste the outputs of:
ifconfig
and
lspci
and maybe
dmesg
to http://pastebin.com and provide the link in here.
If SSH is too complicated for you, try to switch to the desktopmode like explained here: Kodibuntu (wiki)
then open a terminal on the machine and try to store the outputs in a file like:
ifconfig > ifconfig.txt
lspci > lspci.txt
dmesg > dmesg.txt
Then you could use an USB stick to copy the files to a machine, that has an internet connection and pastebin the content this way. If you are there, you could copy the kodi logfile too...the logfile is stored under: ~/.kodi/temp/kodi.log
(2016-02-04, 10:39)David1977 Wrote: [ -> ]Then you could use an USB stick to copy the files to a machine, that has an internet connection and pastebin the content this way. If you are there, you could copy the kodi logfile too...the logfile is stored under: ~/.kodi/temp/kodi.log
Hi David thanks for the reply I could not SSH as the box does not have an IP address the router can see that some thing is there and has a MAC address but no IP so I ran the commands you suggested and these are the results:
ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:105 errors:0 dropped:0 overruns:0 frame:0
          TX packets:105 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:8913 (8.9 KB)  TX bytes:8913 (8.9 KB)
lspci
00:00.0 Host bridge: Intel Corporation Device 190f (rev 07)
00:01.0 PCI bridge: Intel Corporation Device 1901 (rev 07)
00:14.0 USB controller: Intel Corporation Device a12f (rev 31)
00:14.2 Signal processing controller: Intel Corporation Device a131 (rev 31)
00:16.0 Communication controller: Intel Corporation Device a13a (rev 31)
00:17.0 SATA controller: Intel Corporation Device a102 (rev 31)
00:1c.0 PCI bridge: Intel Corporation Device a114 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Device a118 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Device a143 (rev 31)
00:1f.2 Memory controller: Intel Corporation Device a121 (rev 31)
00:1f.3 Audio device: Intel Corporation Device a170 (rev 31)
00:1f.4 SMBus: Intel Corporation Device a123 (rev 31)
00:1f.6 Ethernet controller: Intel Corporation Device 15b8 (rev 31)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1287 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 0e0f (rev a1)
dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.13.0-43-generic ([email protected]) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #72-Ubuntu SMP Mon Dec 8 19:35:06 UTC 2014 (Ubuntu 3.13.0-43.72-generic 3.13.11.11)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-43-generic root=UUID=173292d5-de41-4150-8788-76f973ad940a ro quiet splash vt.handoff=7
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009c7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009c800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000094730fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000094731000-0x0000000094731fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000094732000-0x000000009475bfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000009475c000-0x00000000947abfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000947ac000-0x0000000094d1cfff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000094d1d000-0x0000000096e59fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000096e5a000-0x00000000977b2fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000977b3000-0x0000000097f99fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000097f9a000-0x0000000097ffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000097fff000-0x0000000097ffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000098000000-0x00000000980fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001667fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.8 present.
[    0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./H110M-ITX, BIOS P1.10 10/29/2015
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] No AGP bridge found
[    0.000000] e820: last_pfn = 0x166800 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: write-back
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000000]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000000]   2 base 009C000000 mask 7FFC000000 uncachable
[    0.000000]   3 base 009A000000 mask 7FFE000000 uncachable
[    0.000000]   4 base 0099000000 mask 7FFF000000 uncachable
[    0.000000]   5 base 0098800000 mask 7FFF800000 uncachable
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820: last_pfn = 0x98000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fc620-0x000fc62f] mapped at [ffff8800000fc620]
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff880000096000] 96000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] BRK [0x01fe1000, 0x01fe1fff] PGTABLE
[    0.000000] BRK [0x01fe2000, 0x01fe2fff] PGTABLE
[    0.000000] BRK [0x01fe3000, 0x01fe3fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x166600000-0x1667fffff]
[    0.000000]  [mem 0x166600000-0x1667fffff] page 2M
[    0.000000] BRK [0x01fe4000, 0x01fe4fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x164000000-0x1665fffff]
[    0.000000]  [mem 0x164000000-0x1665fffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x100000000-0x163ffffff]
[    0.000000]  [mem 0x100000000-0x13fffffff] page 1G
[    0.000000]  [mem 0x140000000-0x163ffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0x94730fff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x3fffffff] page 2M
[    0.000000]  [mem 0x40000000-0x7fffffff] page 1G
[    0.000000]  [mem 0x80000000-0x945fffff] page 2M
[    0.000000]  [mem 0x94600000-0x94730fff] page 4k
[    0.000000] init_memory_mapping: [mem 0x9475c000-0x947abfff]
[    0.000000]  [mem 0x9475c000-0x947abfff] page 4k
[    0.000000] init_memory_mapping: [mem 0x94d1d000-0x96e59fff]
[    0.000000]  [mem 0x94d1d000-0x94dfffff] page 4k
[    0.000000]  [mem 0x94e00000-0x96dfffff] page 2M
[    0.000000]  [mem 0x96e00000-0x96e59fff] page 4k
[    0.000000] BRK [0x01fe5000, 0x01fe5fff] PGTABLE
[    0.000000] BRK [0x01fe6000, 0x01fe6fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x97fff000-0x97ffffff]
[    0.000000]  [mem 0x97fff000-0x97ffffff] page 4k
[    0.000000] RAMDISK: [mem 0x349a8000-0x364cbfff]
[    0.000000] ACPI: RSDP 00000000000f05b0 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0000000097f31098 0000AC (v01 ALASKA   A M I  01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0000000097f51f48 00010C (v05 ALASKA   A M I  01072009 AMI  00010013)
[    0.000000] ACPI Error: Gpe0Block - 32-bit FADT register is too long (32 bytes, 256 bits) to convert to GAS struct - 255 bits max, truncating (20131115/tbfadt-202)
[    0.000000] ACPI: DSDT 0000000097f311d8 020D6A (v02 ALASKA   A M I  01072009 INTL 20120913)
[    0.000000] ACPI: FACS 0000000097f99f80 000040
[    0.000000] ACPI: APIC 0000000097f52058 000084 (v03 ALASKA   A M I  01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0000000097f520e0 000044 (v01 ALASKA   A M I  01072009 AMI  00010013)
[    0.000000] ACPI: FIDT 0000000097f52128 00009C (v01 ALASKA   A M I  01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0000000097f521c8 00003C (v01 ALASKA    A M I 01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0000000097f52208 000038 (v01 ALASKA    A M I 01072009 AMI. 0005000B)
[    0.000000] ACPI: SSDT 0000000097f52240 00036D (v01 SataRe SataTabl 00001000 INTL 20120913)
[    0.000000] ACPI: LPIT 0000000097f525b0 000094 (v01 INTEL       SKL 00000000 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0000000097f52648 00002B (v02 INTEL  UsbCTabl 00001000 INTL 20120913)
[    0.000000] ACPI: DBGP 0000000097f52678 000034 (v01 INTEL           00000000 MSFT 0000005F)
[    0.000000] ACPI: DBG2 0000000097f526b0 000054 (v00 INTEL           00000000 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0000000097f52708 0005EF (v02  INTEL xh_rvp08 00000000 INTL 20120913)
[    0.000000] ACPI: AAFT 0000000097f52cf8 00022C (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
[    0.000000] ACPI: SSDT 0000000097f52f28 005212 (v02 SaSsdt  SaSsdt  00003000 INTL 20120913)
[    0.000000] ACPI: UEFI 0000000097f58140 000042 (v01                 00000000      00000000)
[    0.000000] ACPI: SSDT 0000000097f58188 000E58 (v02 CpuRef  CpuSsdt 00003000 INTL 20120913)
[    0.000000] ACPI: DMAR 0000000097f58fe0 000070 (v01 INTEL      SKL  00000001 INTL 00000001)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x00000001667fffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x1667fffff]
[    0.000000]   NODE_DATA [mem 0x1667f8000-0x1667fcfff]
[    0.000000]  [ffffea0000000000-ffffea00059fffff] PMD -> [ffff880161e00000-ffff880165dfffff] on node 0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x00001000-0x00ffffff]
[    0.000000]   DMA32    [mem 0x01000000-0xffffffff]
[    0.000000]   Normal   [mem 0x100000000-0x1667fffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00001000-0x0009bfff]
[    0.000000]   node   0: [mem 0x00100000-0x94730fff]
[    0.000000]   node   0: [mem 0x9475c000-0x947abfff]
[    0.000000]   node   0: [mem 0x94d1d000-0x96e59fff]
[    0.000000]   node   0: [mem 0x97fff000-0x97ffffff]
[    0.000000]   node   0: [mem 0x100000000-0x1667fffff]
[    0.000000] On node 0 totalpages: 1036378
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3995 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 9571 pages used for memmap
[    0.000000]   DMA32 zone: 612543 pages, LIFO batch:31
[    0.000000]   Normal zone: 6560 pages used for memmap
[    0.000000]   Normal zone: 419840 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 136
[    0.000000] PM: Registered nosave memory: [mem 0x0009c000-0x0009cfff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x94731000-0x94731fff]
[    0.000000] PM: Registered nosave memory: [mem 0x94732000-0x9475bfff]
[    0.000000] PM: Registered nosave memory: [mem 0x947ac000-0x94d1cfff]
[    0.000000] PM: Registered nosave memory: [mem 0x96e5a000-0x977b2fff]
[    0.000000] PM: Registered nosave memory: [mem 0x977b3000-0x97f99fff]
[    0.000000] PM: Registered nosave memory: [mem 0x97f9a000-0x97ffefff]
[    0.000000] PM: Registered nosave memory: [mem 0x98000000-0x980fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x98100000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0x98100000-0xdfffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 28 pages/cpu @ffff880166400000 s82304 r8192 d24192 u524288
[    0.000000] pcpu-alloc: s82304 r8192 d24192 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 1020162
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-43-generic root=UUID=173292d5-de41-4150-8788-76f973ad940a ro quiet splash vt.handoff=7
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] xsave: enabled xstate_bv 0x7, cntxt size 0x340
[    0.000000] Checking aperture...
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 3969032K/4145512K available (7383K kernel code, 1144K rwdata, 3408K rodata, 1336K init, 1444K bss, 176480K reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000]     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]     Offload RCU callbacks from all CPUs
[    0.000000]     Offload RCU callbacks from CPUs: 0-3.
[    0.000000] NR_IRQS:16640 nr_irqs:1024 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 16777216 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] hpet clockevent registered
[    0.004000] tsc: Fast TSC calibration failed
[    0.016000] tsc: Unable to calibrate against PIT
[    0.016000] tsc: using HPET reference calibration
[    0.016000] tsc: Detected 3696.038 MHz processor
[    0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 7392.07 BogoMIPS (lpj=14784152)
[    0.000003] pid_max: default: 32768 minimum: 301
[    0.000018] Security Framework initialized
[    0.000029] AppArmor: AppArmor initialized
[    0.000030] Yama: becoming mindful.
[    0.000200] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000942] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001280] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001283] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001405] Initializing cgroup subsys memory
[    0.001409] Initializing cgroup subsys devices
[    0.001410] Initializing cgroup subsys freezer
[    0.001411] Initializing cgroup subsys blkio
[    0.001412] Initializing cgroup subsys perf_event
[    0.001413] Initializing cgroup subsys hugetlb
[    0.001429] CPU: Physical Processor ID: 0
[    0.001429] CPU: Processor Core ID: 0
[    0.001432] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.001432] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.002398] mce: CPU supports 8 MCE banks
[    0.002408] CPU0: Thermal monitoring enabled (TM1)
[    0.002415] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    0.002415] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0
[    0.002415] tlb_flushall_shift: 6
[    0.002648] Freeing SMP alternatives memory: 32K (ffffffff81e6e000 - ffffffff81e76000)
[    0.003256] ACPI: Core revision 20131115
[    0.012447] ACPI Error: [\_SB_.PCI0.XHC_.RHUB.HS11] Namespace lookup failure, AE_NOT_FOUND (20131115/dswload-194)
[    0.012451] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20131115/psobject-222)
[    0.015305] ACPI: All ACPI Tables successfully acquired
[    0.015596] ftrace: allocating 28552 entries in 112 pages
[    0.023234] dmar: Host address width 39
[    0.023235] dmar: DRHD base: 0x000000fed90000 flags: 0x1
[    0.023239] dmar: IOMMU 0: reg_base_addr fed90000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.023240] dmar: RMRR base: 0x00000097555000 end: 0x00000097574fff
[    0.024494] IOAPIC id 2 under DRHD base  0xfed90000 IOMMU 0
[    0.024495] HPET id 0 under DRHD base 0xfed90000
[    0.024495] Your BIOS is broken and requested that x2apic be disabled.
[    0.024495] This will slightly decrease performance.
[    0.024495] Use 'intremap=no_x2apic_optout' to override BIOS request.
[    0.024551] Enabled IRQ remapping in xapic mode
[    0.024552] x2apic not enabled, IRQ remapping is in xapic mode
[    0.028531] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.068206] smpboot: CPU0: Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz (fam: 06, model: 5e, stepping: 03)
[    0.068213] TSC deadline timer enabled
[    0.068223] Performance Events: no PEBS fmt3+, generic architected perfmon, full-width counters, Intel PMU driver.
[    0.068226] ... version:                4
[    0.068226] ... bit width:              48
[    0.068227] ... generic registers:      4
[    0.068227] ... value mask:             0000ffffffffffff
[    0.068228] ... max period:             0000ffffffffffff
[    0.068228] ... fixed-purpose events:   3
[    0.068229] ... event mask:             000000070000000f
[    0.069113] x86: Booting SMP configuration:
[    0.083275] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.069115] .... node  #0, CPUs:      #1 #2 #3
[    0.111639] x86: Booted up 1 node, 4 CPUs
[    0.111642] smpboot: Total of 4 processors activated (29568.30 BogoMIPS)
[    0.114188] devtmpfs: initialized
[    0.115223] EVM: security.selinux
[    0.115224] EVM: security.SMACK64
[    0.115225] EVM: security.ima
[    0.115225] EVM: security.capability
[    0.115247] PM: Registering ACPI NVS region [mem 0x94731000-0x94731fff] (4096 bytes)
[    0.115248] PM: Registering ACPI NVS region [mem 0x977b3000-0x97f99fff] (8286208 bytes)
[    0.115688] pinctrl core: initialized pinctrl subsystem
[    0.115716] regulator-dummy: no parameters
[    0.115802] RTC time:  4:17:09, date: 02/05/16
[    0.115820] NET: Registered protocol family 16
[    0.115868] cpuidle: using governor ladder
[    0.115869] cpuidle: using governor menu
[    0.115890] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.115891] ACPI: bus type PCI registered
[    0.115892] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.115924] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.115926] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.131131] PCI: Using configuration type 1 for base access
[    0.131567] bio: create slab <bio-0> at 0
[    0.131646] ACPI: Added _OSI(Module Device)
[    0.131647] ACPI: Added _OSI(Processor Device)
[    0.131647] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.131648] ACPI: Added _OSI(Processor Aggregator Device)
[    0.142142] ACPI: Executed 21 blocks of module-level executable AML code
[    0.149500] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    0.154197] ACPI: SSDT 000000009754ec18 00037F (v02  PmRef  Cpu0Cst 00003001 INTL 20120913)
[    0.154675] ACPI: Dynamic OEM Table Load:
[    0.154676] ACPI: SSDT           (null) 00037F (v02  PmRef  Cpu0Cst 00003001 INTL 20120913)
[    0.154748] ACPI: SSDT 000000009754f798 000726 (v02  PmRef  Cpu0Ist 00003000 INTL 20120913)
[    0.155243] ACPI: Dynamic OEM Table Load:
[    0.155244] ACPI: SSDT           (null) 000726 (v02  PmRef  Cpu0Ist 00003000 INTL 20120913)
[    0.162550] ACPI: SSDT 000000009754e618 0005AA (v02  PmRef    ApIst 00003000 INTL 20120913)
[    0.163069] ACPI: Dynamic OEM Table Load:
[    0.163070] ACPI: SSDT           (null) 0005AA (v02  PmRef    ApIst 00003000 INTL 20120913)
[    0.166201] ACPI: SSDT 0000000097551c18 000119 (v02  PmRef    ApCst 00003000 INTL 20120913)
[    0.166678] ACPI: Dynamic OEM Table Load:
[    0.166679] ACPI: SSDT           (null) 000119 (v02  PmRef    ApCst 00003000 INTL 20120913)
[    0.171346] ACPI: Interpreter enabled
[    0.171351] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20131115/hwxface-580)
[    0.171356] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131115/hwxface-580)
[    0.171367] ACPI: (supports S0 S3 S4 S5)
[    0.171368] ACPI: Using IOAPIC for interrupt routing
[    0.171407] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.171551] ACPI: No dock devices found.
[    0.174000] ACPI: Power Resource [WRST] (off)
[    0.174151] ACPI: Power Resource [WRST] (off)
[    0.174297] ACPI: Power Resource [WRST] (off)
[    0.174443] ACPI: Power Resource [WRST] (off)
[    0.174587] ACPI: Power Resource [WRST] (off)
[    0.174734] ACPI: Power Resource [WRST] (off)
[    0.174878] ACPI: Power Resource [WRST] (off)
[    0.175027] ACPI: Power Resource [WRST] (off)
[    0.175177] ACPI: Power Resource [WRST] (off)
[    0.175323] ACPI: Power Resource [WRST] (off)
[    0.175470] ACPI: Power Resource [WRST] (off)
[    0.175614] ACPI: Power Resource [WRST] (off)
[    0.175758] ACPI: Power Resource [WRST] (off)
[    0.175903] ACPI: Power Resource [WRST] (off)
[    0.176048] ACPI: Power Resource [WRST] (off)
[    0.176195] ACPI: Power Resource [WRST] (off)
[    0.176339] ACPI: Power Resource [WRST] (off)
[    0.176484] ACPI: Power Resource [WRST] (off)
[    0.176630] ACPI: Power Resource [WRST] (off)
[    0.176774] ACPI: Power Resource [WRST] (off)
[    0.180562] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.180565] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.181637] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.182184] PCI host bridge to bus 0000:00
[    0.182185] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.182186] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
[    0.182188] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
[    0.182189] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.182190] pci_bus 0000:00: root bus resource [mem 0x98800000-0xdfffffff]
[    0.182190] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff]
[    0.182195] pci 0000:00:00.0: [8086:190f] type 00 class 0x060000
[    0.182352] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.182375] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.182422] pci 0000:00:01.0: System wakeup disabled by ACPI
[    0.182525] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[    0.182543] pci 0000:00:14.0: reg 0x10: [mem 0xdf130000-0xdf13ffff 64bit]
[    0.182603] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.182655] pci 0000:00:14.0: System wakeup disabled by ACPI
[    0.182677] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[    0.182694] pci 0000:00:14.2: reg 0x10: [mem 0xdf14e000-0xdf14efff 64bit]
[    0.182823] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[    0.182842] pci 0000:00:16.0: reg 0x10: [mem 0xdf14d000-0xdf14dfff 64bit]
[    0.182906] pci 0000:00:16.0: PME# supported from D3hot
[    0.182991] pci 0000:00:17.0: [8086:a102] type 00 class 0x010601
[    0.183005] pci 0000:00:17.0: reg 0x10: [mem 0xdf148000-0xdf149fff]
[    0.183012] pci 0000:00:17.0: reg 0x14: [mem 0xdf14c000-0xdf14c0ff]
[    0.183018] pci 0000:00:17.0: reg 0x18: [io  0xf050-0xf057]
[    0.183024] pci 0000:00:17.0: reg 0x1c: [io  0xf040-0xf043]
[    0.183031] pci 0000:00:17.0: reg 0x20: [io  0xf020-0xf03f]
[    0.183037] pci 0000:00:17.0: reg 0x24: [mem 0xdf14b000-0xdf14b7ff]
[    0.183074] pci 0000:00:17.0: PME# supported from D3hot
[    0.183142] pci 0000:00:1c.0: [8086:a114] type 01 class 0x060400
[    0.183197] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.183245] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.183282] pci 0000:00:1d.0: [8086:a118] type 01 class 0x060400
[    0.183337] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.183384] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.183423] pci 0000:00:1f.0: [8086:a143] type 00 class 0x060100
[    0.183567] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[    0.183577] pci 0000:00:1f.2: reg 0x10: [mem 0xdf144000-0xdf147fff]
[    0.183681] pci 0000:00:1f.3: [8086:a170] type 00 class 0x040300
[    0.183704] pci 0000:00:1f.3: reg 0x10: [mem 0xdf140000-0xdf143fff 64bit]
[    0.183734] pci 0000:00:1f.3: reg 0x20: [mem 0xdf120000-0xdf12ffff 64bit]
[    0.183779] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.183832] pci 0000:00:1f.3: System wakeup disabled by ACPI
[    0.183853] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[    0.183899] pci 0000:00:1f.4: reg 0x10: [mem 0xdf14a000-0xdf14a0ff 64bit]
[    0.183967] pci 0000:00:1f.4: reg 0x20: [io  0xf000-0xf01f]
[    0.184098] pci 0000:00:1f.6: [8086:15b8] type 00 class 0x020000
[    0.184122] pci 0000:00:1f.6: reg 0x10: [mem 0xdf100000-0xdf11ffff]
[    0.184230] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.184285] pci 0000:00:1f.6: System wakeup disabled by ACPI
[    0.184324] pci 0000:01:00.0: [10de:1287] type 00 class 0x030000
[    0.184330] pci 0000:01:00.0: reg 0x10: [mem 0xde000000-0xdeffffff]
[    0.184337] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xd7ffffff 64bit pref]
[    0.184343] pci 0000:01:00.0: reg 0x1c: [mem 0xd8000000-0xd9ffffff 64bit pref]
[    0.184347] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.184352] pci 0000:01:00.0: reg 0x30: [mem 0xdf000000-0xdf07ffff pref]
[    0.184379] pci 0000:01:00.0: System wakeup disabled by ACPI
[    0.184395] pci 0000:01:00.1: [10de:0e0f] type 00 class 0x040300
[    0.184401] pci 0000:01:00.1: reg 0x10: [mem 0xdf080000-0xdf083fff]
[    0.190105] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.190111] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.190117] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.190126] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xd9ffffff 64bit pref]
[    0.190199] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.190246] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    0.190263] acpi PNP0A08:00: Disabling ASPM (FADT indicates it is unsupported)
[    0.191069] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191102] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.191132] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191163] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191193] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191223] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191253] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191283] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.191612] ACPI: Enabled 5 GPEs in block 00 to 7F
[    0.191616] ACPI: \_SB_.PCI0: notify handler is installed
[    0.191667] Found 1 acpi root devices
[    0.191715] vgaarb: setting as boot device: PCI:0000:01:00.0
[    0.191716] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.191717] vgaarb: loaded
[    0.191717] vgaarb: bridge control possible 0000:01:00.0
[    0.191792] SCSI subsystem initialized
[    0.191817] libata version 3.00 loaded.
[    0.191825] ACPI: bus type USB registered
[    0.191833] usbcore: registered new interface driver usbfs
[    0.191837] usbcore: registered new interface driver hub
[    0.191846] usbcore: registered new device driver usb
[    0.191898] PCI: Using ACPI for IRQ routing
[    0.219821] PCI: pci_cache_line_size set to 64 bytes
[    0.219862] e820: reserve RAM buffer [mem 0x0009c800-0x0009ffff]
[    0.219863] e820: reserve RAM buffer [mem 0x94731000-0x97ffffff]
[    0.219864] e820: reserve RAM buffer [mem 0x947ac000-0x97ffffff]
[    0.219865] e820: reserve RAM buffer [mem 0x96e5a000-0x97ffffff]
[    0.219866] e820: reserve RAM buffer [mem 0x166800000-0x167ffffff]
[    0.219907] NetLabel: Initializing
[    0.219907] NetLabel:  domain hash size = 128
[    0.219908] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.219914] NetLabel:  unlabeled traffic allowed by default
[    0.219977] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.219980] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.222028] Switched to clocksource hpet
[    0.224468] AppArmor: AppArmor Filesystem Enabled
[    0.224476] pnp: PnP ACPI init
[    0.224481] ACPI: bus type PNP registered
[    0.224634] system 00:00: [io  0x0280-0x028f] has been reserved
[    0.224635] system 00:00: [io  0x0290-0x029f] has been reserved
[    0.224636] system 00:00: [io  0x02a0-0x02af] has been reserved
[    0.224637] system 00:00: [io  0x02b0-0x02bf] has been reserved
[    0.224638] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.224671] pnp 00:01: Plug and Play ACPI device, IDs INT0800 (active)
[    0.224710] pnp 00:02: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.224755] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.224771] system 00:04: [io  0x0680-0x069f] has been reserved
[    0.224772] system 00:04: [io  0xffff] has been reserved
[    0.224773] system 00:04: [io  0xffff] has been reserved
[    0.224774] system 00:04: [io  0xffff] has been reserved
[    0.224775] system 00:04: [io  0x1800-0x18fe] could not be reserved
[    0.224776] system 00:04: [io  0x164e-0x164f] has been reserved
[    0.224777] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.224815] system 00:05: [io  0x0800-0x087f] has been reserved
[    0.224816] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.224831] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.224848] system 00:07: [io  0x1854-0x1857] has been reserved
[    0.224849] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.224967] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.224968] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.224969] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.224970] system 00:08: [mem 0xe0000000-0xefffffff] has been reserved
[    0.224971] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.224971] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.224972] system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.224973] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[    0.224974] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.224975] system 00:08: [mem 0xdffc0000-0xdffdffff] has been reserved
[    0.224976] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.224997] system 00:09: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.224998] system 00:09: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.224999] system 00:09: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.225000] system 00:09: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.225001] system 00:09: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.225001] system 00:09: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.225002] system 00:09: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.225003] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.225132] system 00:0a: [io  0xff00-0xfffe] has been reserved
[    0.225133] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.225640] system 00:0b: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.225641] system 00:0b: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.225642] system 00:0b: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.225643] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.226048] pnp: PnP ACPI: found 12 devices
[    0.226049] ACPI: bus type PNP unregistered
[    0.233724] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.233726] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.233728] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.233730] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xd9ffffff 64bit pref]
[    0.233732] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.233739] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    0.233748] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
[    0.233748] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
[    0.233749] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.233750] pci_bus 0000:00: resource 7 [mem 0x98800000-0xdfffffff]
[    0.233751] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff]
[    0.233752] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.233753] pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
[    0.233753] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xd9ffffff 64bit pref]
[    0.233768] NET: Registered protocol family 2
[    0.233860] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.233913] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.233982] TCP: Hash tables configured (established 32768 bind 32768)
[    0.233994] TCP: reno registered
[    0.233998] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.234009] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.234058] NET: Registered protocol family 1
[    0.234406] pci 0000:01:00.0: Video device with shadowed ROM
[    0.234413] PCI: CLS 0 bytes, default 64
[    0.234438] Trying to unpack rootfs image as initramfs...
[    0.503244] Freeing initrd memory: 27792K (ffff8800349a8000 - ffff8800364cc000)
[    0.503272] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.503274] software IO TLB [mem 0x90731000-0x94731000] (64MB) mapped at [ffff880090731000-ffff880094730fff]
[    0.503399] microcode: CPU0 sig=0x506e3, pf=0x2, revision=0x49
[    0.503405] microcode: CPU1 sig=0x506e3, pf=0x2, revision=0x49
[    0.503415] microcode: CPU2 sig=0x506e3, pf=0x2, revision=0x49
[    0.503424] microcode: CPU3 sig=0x506e3, pf=0x2, revision=0x49
[    0.503467] microcode: Microcode Update Driver: v2.00 <[email protected]>, Peter Oruba
[    0.503468] Scanning for low memory corruption every 60 seconds
[    0.503678] Initialise system trusted keyring
[    0.503702] audit: initializing netlink socket (disabled)
[    0.503709] type=2000 audit(1454645829.512:1): initialized
[    0.519843] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.520459] zbud: loaded
[    0.520581] VFS: Disk quotas dquot_6.5.2
[    0.520600] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.520894] fuse init (API version 7.22)
[    0.520957] msgmni has been set to 7806
[    0.520980] Key type big_key registered
[    0.522313] Key type asymmetric registered
[    0.522314] Asymmetric key parser 'x509' registered
[    0.522330] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.522406] io scheduler noop registered
[    0.522407] io scheduler deadline registered (default)
[    0.522423] io scheduler cfq registered
[    0.522547] pcieport 0000:00:01.0: irq 137 for MSI/MSI-X
[    0.522643] pcieport 0000:00:1c.0: irq 138 for MSI/MSI-X
[    0.522744] pcieport 0000:00:1d.0: irq 139 for MSI/MSI-X
[    0.522789] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    0.522790] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    0.522791] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[    0.522793] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[    0.522800] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[    0.522803] pcie_pme 0000:00:1c.0:pcie01: service driver pcie_pme loaded
[    0.522811] pcieport 0000:00:1d.0: Signaling PME through PCIe PME interrupt
[    0.522813] pcie_pme 0000:00:1d.0:pcie01: service driver pcie_pme loaded
[    0.522818] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.522824] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.522840] vesafb: mode is 640x480x32, linelength=2560, pages=0
[    0.522840] vesafb: scrolling: redraw
[    0.522841] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.522923] vesafb: framebuffer at 0xd9000000, mapped to 0xffffc90010780000, using 1216k, total 1216k
[    0.540076] Console: switching to colour frame buffer device 80x30
[    0.557224] fb0: VESA VGA frame buffer device
[    0.557231] intel_idle: does not run on family 6 model 94
[    0.557234] ipmi message handler version 39.2
[    0.557276] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input0
[    0.557278] ACPI: Sleep Button [SLPB]
[    0.557291] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
[    0.557292] ACPI: Power Button [PWRB]
[    0.557304] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.557305] ACPI: Power Button [PWRF]
[    0.557468] Monitor-Mwait will be used to enter C-1 state
[    0.557490] Monitor-Mwait will be used to enter C-2 state
[    0.557527] Monitor-Mwait will be used to enter C-3 state
[    0.557562] ACPI: acpi_idle registered with cpuidle
[    0.558403] GHES: HEST is not enabled!
[    0.558527] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.560386] Linux agpgart interface v0.103
[    0.561468] brd: module loaded
[    0.562096] loop: module loaded
[    0.562286] libphy: Fixed MDIO Bus: probed
[    0.562321] tun: Universal TUN/TAP device driver, 1.6
[    0.562322] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[    0.562372] PPP generic driver version 2.4.2
[    0.562427] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.562431] ehci-pci: EHCI PCI platform driver
[    0.562436] ehci-platform: EHCI generic platform driver
[    0.562439] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.562439] ohci-pci: OHCI PCI platform driver
[    0.562442] ohci-platform: OHCI generic platform driver
[    0.562445] uhci_hcd: USB Universal Host Controller Interface driver
[    0.562537] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.562540] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.562628] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.562643] xhci_hcd 0000:00:14.0: irq 140 for MSI/MSI-X
[    0.562681] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.562682] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.562683] usb usb1: Product: xHCI Host Controller
[    0.562684] usb usb1: Manufacturer: Linux 3.13.0-43-generic xhci_hcd
[    0.562684] usb usb1: SerialNumber: 0000:00:14.0
[    0.562763] hub 1-0:1.0: USB hub found
[    0.562774] hub 1-0:1.0: 10 ports detected
[    0.566246] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.566248] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.566268] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    0.566269] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.566269] usb usb2: Product: xHCI Host Controller
[    0.566270] usb usb2: Manufacturer: Linux 3.13.0-43-generic xhci_hcd
[    0.566271] usb usb2: SerialNumber: 0000:00:14.0
[    0.566344] hub 2-0:1.0: USB hub found
[    0.566352] hub 2-0:1.0: 4 ports detected
[    0.574099] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.577359] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.577374] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.577564] mousedev: PS/2 mouse device common for all mice
[    0.577902] rtc_cmos 00:06: RTC can wake from S4
[    0.578263] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[    0.578343] rtc_cmos 00:06: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.578373] device-mapper: uevent: version 1.0.3
[    0.578493] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: [email protected]
[    0.578496] ledtrig-cpu: registered to indicate activity on CPUs
[    0.578543] TCP: cubic registered
[    0.578579] NET: Registered protocol family 10
[    0.578658] NET: Registered protocol family 17
[    0.578664] Key type dns_resolver registered
[    0.579048] Loading compiled-in X.509 certificates
[    0.579497] Loaded X.509 cert 'Magrathea: Glacier signing key: 55ab2fe28ed5c60df9587150d1734c920ea7b818'
[    0.579502] registered taskstats version 1
[    0.581244] Key type trusted registered
[    0.582781] Key type encrypted registered
[    0.584205] AppArmor: AppArmor sha1 policy hashing enabled
[    0.584207] IMA: No TPM chip found, activating TPM-bypass!
[    0.584534] regulator-dummy: disabling
[    0.584740]   Magic number: 4:490:261
[    0.584763] acpi device:6d: hash matches
[    0.584948] rtc_cmos 00:06: setting system clock to 2016-02-05 04:17:09 UTC (1454645829)
[    0.585561] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.585561] EDD information not available.
[    0.585582] PM: Hibernation image not present or could not be loaded.
[    0.586133] Freeing unused kernel memory: 1336K (ffffffff81d20000 - ffffffff81e6e000)
[    0.586134] Write protecting the kernel read-only data: 12288k
[    0.587217] Freeing unused kernel memory: 796K (ffff880001739000 - ffff880001800000)
[    0.588034] Freeing unused kernel memory: 688K (ffff880001b54000 - ffff880001c00000)
[    0.595556] systemd-udevd[116]: starting version 204
[    0.616483] ahci 0000:00:17.0: version 3.0
[    0.616619] ahci 0000:00:17.0: irq 141 for MSI/MSI-X
[    0.616696] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[    0.616698] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds apst
[    0.646368] scsi0 : ahci
[    0.646571] scsi1 : ahci
[    0.646772] scsi2 : ahci
[    0.646966] scsi3 : ahci
[    0.647010] ata1: SATA max UDMA/133 abar [email protected] port 0xdf14b100 irq 141
[    0.647012] ata2: SATA max UDMA/133 abar [email protected] port 0xdf14b180 irq 141
[    0.647014] ata3: SATA max UDMA/133 abar [email protected] port 0xdf14b200 irq 141
[    0.647017] ata4: SATA max UDMA/133 abar [email protected] port 0xdf14b280 irq 141
[    0.966248] ata3: SATA link down (SStatus 4 SControl 300)
[    0.966265] ata2: SATA link down (SStatus 4 SControl 300)
[    0.966303] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.974196] ata4: SATA link down (SStatus 4 SControl 300)
[    1.002299] ata1.00: ATA-8: ST500LT012-1DG142, 0001SDM1, max UDMA/133
[    1.002301] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[    1.132847] ata1.00: configured for UDMA/133
[    1.133099] scsi 0:0:0:0: Direct-Access     ATA      ST500LT012-1DG14 0001 PQ: 0 ANSI: 5
[    1.133243] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[    1.133245] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.133258] sd 0:0:0:0: [sda] Write Protect is off
[    1.133260] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.133266] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.133522] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.193163]  sda: sda1 sda2 < sda5 >
[    1.193619] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.501929] tsc: Refined TSC clocksource calibration: 3696.000 MHz
[    2.502141] Switched to clocksource tsc
[    3.709325] raid6: sse2x1   13092 MB/s
[    3.777306] raid6: sse2x2   16205 MB/s
[    3.845294] raid6: sse2x4   16963 MB/s
[    3.913279] raid6: avx2x1   26113 MB/s
[    3.981266] raid6: avx2x2   29867 MB/s
[    4.049251] raid6: avx2x4   30825 MB/s
[    4.049252] raid6: using algorithm avx2x4 (30825 MB/s)
[    4.049253] raid6: using avx2x2 recovery algorithm
[    4.049870] xor: automatically using best checksumming function:
[    4.089243]    avx       : 32507.000 MB/sec
[    4.095088] bio: create slab <bio-1> at 1
[    4.095210] Btrfs loaded
[    4.300059] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    4.408623] random: nonblocking pool is initialized
[    6.678579] Adding 4144124k swap on /dev/sda5.  Priority:-1 extents:1 across:4144124k FS
[    7.058328] systemd-udevd[364]: starting version 204
[    7.565478] lp: driver loaded but no devices found
[    7.588047] ppdev: user-space parallel port driver
[    8.816913] [drm] Initialized drm 1.1.0 20060810
[    9.072868] snd_hda_intel 0000:00:1f.3: irq 142 for MSI/MSI-X
[    9.113794] SKU: Nid=0x1d sku_cfg=0x4024c601
[    9.113795] SKU: port_connectivity=0x1
[    9.113796] SKU: enable_pcbeep=0x0
[    9.113797] SKU: check_sum=0x00000004
[    9.113797] SKU: customization=0x000000c6
[    9.113798] SKU: external_amp=0x0
[    9.113798] SKU: platform_type=0x0
[    9.113798] SKU: swap=0x0
[    9.113799] SKU: override=0x1
[    9.114042] autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    9.114043]    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    9.114043]    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    9.114044]    mono: mono_out=0x0
[    9.114044]    inputs:
[    9.114045]      Front Mic=0x19
[    9.114046]      Rear Mic=0x18
[    9.114046]      Line=0x1a
[    9.114047] realtek: No valid SSID, checking pincfg 0x4024c601 for NID 0x1d
[    9.114047] realtek: Enabling init ASM_ID=0xc601 CODEC_ID=10ec0892
[    9.123400] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    9.123445] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    9.123478] input: HDA Intel Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    9.123508] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    9.123539] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    9.123700] hda_intel: Disabling MSI
[    9.123703] hda-intel 0000:01:00.1: Handle VGA-switcheroo audio client
[    9.123725] hda-intel 0000:01:00.1: Disabling 64bit DMA
[    9.127001] hda-intel 0000:01:00.1: Enable delay in RIRB handling
[    9.288174] device-mapper: multipath: version 1.6.0 loaded
[    9.540193] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[    9.540241] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[   10.246984] nvidia: module license 'NVIDIA' taints kernel.
[   10.246986] Disabling lock debugging due to kernel taint
[   10.250148] nvidia: module verification failed: signature and/or  required key missing - tainting kernel
[   10.252735] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=none
[   10.252756] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1287)
[   10.252756] NVRM: installed in this system is not supported by the 304.125
[   10.252756] NVRM: NVIDIA Linux driver release.  Please see 'Appendix
[   10.252756] NVRM: A - Supported NVIDIA GPU Products' in this release's
[   10.252756] NVRM: README, available on the Linux driver download page
[   10.252756] NVRM: at www.nvidia.com.
[   10.252781] nvidia: probe of 0000:01:00.0 failed with error -1
[   10.252971] NVRM: The NVIDIA probe routine failed for 1 device(s).
[   10.252972] NVRM: None of the NVIDIA graphics adapters were initialized!
[   10.252973] [drm] Module unloaded
[   10.390463] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[   10.547892] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   11.092712] FS-Cache: Loaded
[   11.195649] RPC: Registered named UNIX socket transport module.
[   11.195651] RPC: Registered udp transport module.
[   11.195652] RPC: Registered tcp transport module.
[   11.195653] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.274491] init: failsafe main process (694) killed by TERM signal
[   11.384538] FS-Cache: Netfs 'nfs' registered for caching
[   11.522157] Installing knfsd (copyright (C) 1996 [email protected]).
[   14.648797] Bluetooth: Core ver 2.17
[   14.648817] NET: Registered protocol family 31
[   14.648818] Bluetooth: HCI device and connection manager initialized
[   14.648826] Bluetooth: HCI socket layer initialized
[   14.648829] Bluetooth: L2CAP socket layer initialized
[   14.648831] Bluetooth: SCO socket layer initialized
[   14.779666] Bluetooth: RFCOMM TTY layer initialized
[   14.779677] Bluetooth: RFCOMM socket layer initialized
[   14.779680] Bluetooth: RFCOMM ver 1.11
[   14.922554] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.922556] Bluetooth: BNEP filters: protocol multicast
[   14.922564] Bluetooth: BNEP socket layer initialized
[   14.992309] init: cups main process (987) killed by HUP signal
[   14.992316] init: cups main process ended, respawning
[   15.079846] lirc_dev: IR Remote Control driver registered, major 251
[   16.112983] init: kodibuntu-wait (lightdm) main process (928) killed by TERM signal
[   16.113159] init: kodibuntu-wait (ubiquity) main process (933) killed by TERM signal
[   17.860485] init: samba-ad-dc main process (1094) terminated with status 1
[   25.116485] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=none,decodes=none:owns=none
[   25.116507] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1287)
[   25.116507] NVRM: installed in this system is not supported by the 304.125
[   25.116507] NVRM: NVIDIA Linux driver release.  Please see 'Appendix
[   25.116507] NVRM: A - Supported NVIDIA GPU Products' in this release's
[   25.116507] NVRM: README, available on the Linux driver download page
[   25.116507] NVRM: at www.nvidia.com.
[   25.116534] nvidia: probe of 0000:01:00.0 failed with error -1
[   25.116690] NVRM: The NVIDIA probe routine failed for 1 device(s).
[   25.116691] NVRM: None of the NVIDIA graphics adapters were initialized!
[   25.116692] [drm] Module unloaded
[   25.117190] systemd-udevd[1221]: Failed to apply ACL on /dev/dri/card0: No such file or directory
[   25.147045] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=none,decodes=none:owns=none
[   25.147067] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1287)
[   25.147067] NVRM: installed in this system is not supported by the 304.125
[   25.147067] NVRM: NVIDIA Linux driver release.  Please see 'Appendix
[   25.147067] NVRM: A - Supported NVIDIA GPU Products' in this release's
[   25.147067] NVRM: README, available on the Linux driver download page
[   25.147067] NVRM: at www.nvidia.com.
[   25.147099] nvidia: probe of 0000:01:00.0 failed with error -1
[   25.147400] systemd-udevd[1221]: Failed to apply ACL on /dev/dri/card0: No such file or directory
[   25.147465] NVRM: The NVIDIA probe routine failed for 1 device(s).
[   25.147467] NVRM: None of the NVIDIA graphics adapters were initialized!
[   25.147468] [drm] Module unloaded
[   25.972395] init: plymouth-upstart-bridge main process ended, respawning
[   25.975210] init: plymouth-upstart-bridge main process (1232) terminated with status 1
[   25.975216] init: plymouth-upstart-bridge main process ended, respawning
[   44.718157] traps: notification-da[1454] trap int3 ip:7eff42f7cc13 sp:7fff4c412060 error:0
[   51.164056] usb 1-9: new full-speed USB device number 2 using xhci_hcd
[   51.183119] usb 1-9: New USB device found, idVendor=1532, idProduct=001c
[   51.183121] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   51.183122] usb 1-9: Product: Razer Abyssus
[   51.183123] usb 1-9: Manufacturer: Razer
[   51.328602] hidraw: raw HID events driver (C) Jiri Kosina
[   51.331336] usbcore: registered new interface driver usbhid
[   51.331337] usbhid: USB HID core driver
[   51.339108] input: Razer  Razer Abyssus as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input13
[   51.339176] hid-generic 0003:1532:001C.0001: input,hidraw0: USB HID v1.11 Mouse [Razer  Razer Abyssus] on usb-0000:00:14.0-9/input0
[  138.910202] usb 1-8: new low-speed USB device number 3 using xhci_hcd
[  138.932269] usb 1-8: New USB device found, idVendor=099a, idProduct=5000
[  138.932277] usb 1-8: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  138.932282] usb 1-8: Product: USB Keyboard
[  138.932537] usb 1-8: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[  138.932546] usb 1-8: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[  138.936097] input: USB Keyboard  as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input14
[  138.936410] hid-generic 0003:099A:5000.0002: input,hidraw1: USB HID v1.00 Keyboard [USB Keyboard ] on usb-0000:00:14.0-8/input0
[  138.940503] input: USB Keyboard  as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/input/input15
[  138.940805] hid-generic 0003:099A:5000.0003: input,hidraw2: USB HID v1.00 Device [USB Keyboard ] on usb-0000:00:14.0-8/input1
[/quote]
This is a shot in the dark, but you are running a very old linux kernel on a very new motherboard/ethernet device. Kernel 3.19.6 (or whatever the last 14.04.3 kernel uses) might work better. Download the 3 .deb files to a USB drive to get them onto the KodiBuntu box then install. The Googles can show you how to do that.
Hay all David1977 did post some thing and I got it in an email but it did not show up here so I though I should share this encase any one else had the same issue. I tried updating the kernel but no luck it seems that Kodibuntu is so out of date its just not going to work with new hardware so I followed the link in David1977 post and when I started the install for Lubuntu the network worked from the get go so this looks like the root for me Big Grin
Thanks for all your help Smile
Quote:Yes, KodiBuntu is shipped with this...updating it might help...
Go to:
http://kernel.ubuntu.com/~kernel-ppa/mai...9.3-vivid/
and download those:
linux-headers-3.19.3-031903-generic_3.19.3-031903.201503261036_amd64.deb
linux-headers-3.19.3-031903_3.19.3-031903.201503261036_all.deb
linux-image-3.19.3-031903-generic_3.19.3-031903.201503261036_amd64.deb
copy them to your kodibuntu system using an USB stick. Therefore create a folder:
mkdir ~/kernel3.19.3
and put the files in there
after that, switch to that folder:
cd ~/kernel3.19.3
and do this:
sudo dpkg -i *deb
If this is too complicated, you could try to build your "own" kodibuntu (which is not as hard as it sounds like Wink ). See here:
247152 (thread)... (visit the thread to read more..)
lol....I removed the post, because I wasn't sure, if this is correct. But glad it works for you Wink
