2016-02-04, 08:34
Hi
i did a lot of search and find that it should be possible to solve my problem but i need help, so hope guys that you can help me :-)
my episodes of doctor who are cut in parts and the naming is as follow :
series/Doctor who/Saison 01/01 Episode 1 - An Unearthly Child/
01x01 (01) - An Unearthly Child
01x01 (02) - The Cave Of Skulls
01x01 (03) - The Forest Of Fear
01x01 (04) - The Firemaker
The problem is that kodi recognize the 4th parts as the first part. and named it all the same ...
From my research i found that i should rename to match the pattern for multipart episode except that i would (if possible) avoid this solution
And i found that it's possible to customize how the recognition works but i'm lost there with the regex...
so my question is : Should i customise the tvshowmatching or the tvmultipartmatching ??
could you help me about the regex ?
i saw tvmultipartmatching and i understand that i need to create the file etc
but i'm lost to create the regex
hope you can help :-)
regards
bob
regards
bob
