it doesn't work. the coder have to rewrite because site is changed.
you can find this information on his git-hub page.
Peppe
Yes... apparently on kodi 15.2 official repo i can install this 1.0.3 and it's not fully worked.............. wait for a fix
I have watched some anime 5 minutes but for example some search it's not fully working
i have kodi 15.2 on my multimedia box and this plugin is not working as well....
unfortunately also the official APP doesnt work.... so we have to wait a new plugin to be released?
Can you confirm it still does not work?
16:25:01 T:2696 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('data',)
File "C:\Users\Massimo\AppData\Roaming\Kodi\addons\plugin.video.vvvvid\default.py", line 439, in <module>
plugin.run()
File "C:\Users\Massimo\AppData\Roaming\Kodi\addons\script.module.xbmcswift2\lib\xbmcswift2\plugin.py", line 332, in run
items = self._dispatch(self.request.path)
File "C:\Users\Massimo\AppData\Roaming\Kodi\addons\script.module.xbmcswift2\lib\xbmcswift2\plugin.py", line 306, in _dispatch
listitems = view_func(**items)
File "C:\Users\Massimo\AppData\Roaming\Kodi\addons\plugin.video.vvvvid\default.py", line 302, in showAnimeChannels
channels = get_section_channels(MODE_ANIME)
File "C:\Users\Massimo\AppData\Roaming\Kodi\addons\plugin.video.vvvvid\requester.py", line 66, in get_section_channels
channels = data['data']
KeyError: ('data',)
16:25:01 T:8476 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.vvvvid/anime/channels
M
Exactly the same situation in my log.
Peppe
