Full Version: HDHomeRun Missing Some Channels
I installed the add-on for HDHomeRun Prime, and while it is working, it does not list any of the channels between 800 and the audio channels, which start at 900.
Is there any way to configure/add the channels? I can watch them through WMC or the HDHomeRun Viewer, but not in Kodi.
I'm running Win7 if it matters.
Thread moved to the HDHomeRun section
Chances are that those channels are drm protected. You can confirm by going to the hdhomerun Ip address in your browser and looking at the Channel list.
No, the channels are not protected. They work just fine in the HDHomerun Viewer and in anything else I run.
(2016-02-09, 01:37)BuckeyeInMI Wrote: [ -> ]No, the channels are not protected. They work just fine in the HDHomerun Viewer and in anything else I run.
okay...
  1. find ip address of hdhomerun
  2. open web browser and go to hdhomerun ip address : ex http://10.11.1.5
  3. click "channel lineup"
  4. look for [drm] tag next to channels
  5. compare channels that are missing in kodi to ones with the [drm] tag
  6. understand that hdhomerun view and kodi are two different applications and what works in one will not always work in the other
