2016-02-05, 13:20
2016-06-30, 21:20
Same problem here, is there a solution?
2016-07-23, 17:39
This is STILL broken in Krypton Alpha 2 - please, please, please could someone take a look at this so we can hopefully get it fixed for the Krypton general release.
I've put the debug log at http://pastebin.com/jmTqax4H
This was Kodi starting with an empty video DB, adding the ftp source with "|auth=tls" on the end, scanning in the files, then doing a "Clean DB". Again, it pops up a box asking me what I want to do with the unavailable source (keep or remove). Again, it works ok if I don't use "|auth=tls" but this is insecure.
Also, I get the same issue using an https source with "|auth=anysafe" or "|auth=digest" on the end. It has to be a bug in the clean library code with how it handles the "|auth=xxx" on the end of the path.
2016-11-02, 17:35
No fix? :/
