Full Version: What remote device do you use?
Pages: 1 2
This was originally going to be "What keyboard do you use?" but why not expand it out a bit. Like others I looked into reviews about keyboards and remotes, but didn't really find anything too Kodi specific, so why not go to the horses mouth. Below is a guide to posting as to keep it informative for others and is by no means exhaustive as to what to post about.
Remote Device: Keyboard / Remote
Media Device: NUC / RPi / FireStick
OS: Windows / Mac / Linux / OpenELEC
Connection type: USB / Bluetooth / Wireless / Combo
Pros: Battery life / method of connectivity / responsiveness / ease of setup / price
Cons: As above
Other: Device internet link / post suggestions/feedback
Name: Logitech K400R White
Media Device: NUC5i5
OS: OpenELEC
Connection type: Wireless
Pros: Good battery life, firm key press with minimal travel, can be stored upright (on top edge), responsive track pad and decent price point.
Cons: PnP support with Linux but no software support as there are some functions that could be greatly utilised, wireless connectivity is reasonable provided that you have direct line of sight of the receiver and not outside of about 5-6m.
Other: http://www.logitech.com/en-au/product/wi...oard-k400r
The follow excludes my workstation where three versions of Kodi are installed, but are only used for Team-Kodi purposes.
Name: Logitech K400 Black
Remote Device: Keyboard/Touchpad
Media Device: N54L
OS: Windows 10 Pro x64
Pros: Excellent battery life, around six months +
Cons: Odd design choice for shortcut keys.
Media Device: N54L
Media Device: Lenovo Q180 (<- Don't ever buy Lenovo)
Name: Logitech K400 Plus Black
Media Device: Minix
OS: Android
Pros: Excellent battery life, only purchased a month a go.
Cons: Hideous yellow colouring
Name: Nvidia Shield Remote
Remote Device: Remote
Media Device: Nvidia SHIELD
OS: Android
Pros: Small, quality build
Cons: Far too few buttons
Name: Virgin Media Tivo Remote
Media Device: Chromebox
OS: OpenELEC
Connection type: Infrared
Pros: Cheap, Controls TV and Openelec, Perfect for Kodi PVR
Cons: None it was designed for STBs
Other: https://www.google.co.uk/search?q=virgin...IViH0TM%3A
Ooh this post is right in my alley, have tried 40+ remotes on Kodi and settled for one that has no cons and is fairly cheap.
Also using
Name: MCE remote (Philips SRM5100 style) on Stream Flirc module
Remote Device: remote
Media Device: Stream FC5
OS: Windows 10
Pros: Battery life, Best button layout of all remotes hands down, fits really well in the hand, cheap, availability, nice firm rubbery buttons with a good soft click, mce style remotes are the to go remotes for Kodi anyways
Cons: none, well not for me but it's IR and some people might not like it, also it's white but available in black as well (Lenovo and other OEMs)
Other: http://www.p4c.philips.com/cgi-bin/dcbin...SRM5100/10
Name: Stream Flirc Infrared module
Remote Device: Infrared receiver
OS: Any with USB
Pros: Full programmability, Responsiveness, Power on from any remote, Ease of setup
Cons: None
Other: https://flirc.tv/flirc-streacom-edition
Highly recommend Flirc + MCE remote, got the setup for 36 euro total and nothing beats it so far.
(2016-02-07, 18:09)stuCONNERS Wrote: [ -> ]Name: Virgin Media Tivo Remote
OS: OpenELEC
That's rather awesome. I had no idea the Tivo remote could be used for that purpose.
Name: Logitech Harmony smart control
Media Device: NUC haswell
OS: OpenELEC/Linux
Pros: Beautiful, easy to hold, every button you could want, battery lasts years
Cons: Little slow at responding compared to shield remote. Not really noticeable though like my old harmony one.
Other: http://cdn.slashgear.com/wp-content/uplo...72_dpi.jpg
OS: Android
Other: http://cdn.slashgear.com/wp-content/uplo...remote.jpg
OS: OpenELEC
Can anyone confirm if this works with Android on a generic Android box? I cannot find a non air mouse, with keyboard that has a Stop button. This appears to have everything one would need if it works with Android
Remote Device: Keyboard / touchpad mouse
Media Device: RPi2
OS: OSMC
Pros: Good battery life, has on/off on back. Push button on back to pair with usb dongle. $24.88 from Wal-Mart.
Cons: Takes a little getting used to the touchpad.
Other: http://www.walmart.com/ip/Blackweb-Wirel...d/44459957 I'd say the bad reviews are from idiots. I've had two of these on different OSMC machines for 3 or 4 months with no problems.
Name: Logitech Harmony 200
Media Device: RPi2
OS: OSMC
Connection type: IR
Pros: Good battery life. Install software on Windows machine, setup the devices and it just works. Got it on sale on Woot, can't remember the price, but it was way less than normal. I use an original XBox dongle, with a cable bought off ebay that has a regular USB end on the other side.
Cons: None that I can think of.
Other: http://www.amazon.com/Logitech-915-00014...005O81U9S/
Name: Logitech Harmony One
Media Device: RPi2
OS: OSMC
Connection type: IR
Pros: Battery life so far is good. Bought it at a thrift shop(yeah for paying $10.00 and another $15.00 for a new battery) and it had the classic battery overheat bulge. Two letter openers stuck under the battery to lift it up high enough to get needlenose pliers under it got the old battery out and a new battery from Amazon fixed that. I've left it off the charging base for days on end, sometimes over a week and no problems.
Other: http://www.amazon.com/Logitech-Harmony-U...B00119T6NQ
Name: OSMC Media Remote
Media Device: RPi2
OS: OSMC
Pros: Not line of sight like IR, so you don't have to aim it at anything. Doesn't use much power, uses standard cr2032 button batteries that can be picked up locally, even at a grocery store if needed. If used with OSMC, needs ZERO setup other than pluging in the USB dongle.
Other: https://osmc.tv/store/product/osmc-remote-control/
Name: Pioneer VSX916 Remote
Media Device: Custom built HTPC/Server
OS: Ubuntu 14.04
Pros: Controls amp, TV and Kodi all from the one remote - has plenty of media buttons to map to Kodi functions
Cons: None
Other: -
Name: Xbox Media Remote
OS: Ubuntu 14.04
Pros: Designed for media control, buttons all backlit
Cons: Old now and buttons getting hard to press !!
Other: -
Media Device: Raspberry Pi B
OS: OpenELEC
Pros: Compact, easy for wife to use !! and cheap.
Cons: Needed some buttons re-mapping to get the best out of it. Eats a battery every two months.
Other: - https://www.amazon.co.uk/New-Remote-Pi-M...+pi+remote
Name: Official Xbox 360 Media Remote (Black)
Media Device: Alienware Alpha
OS: Libreelec
Connection type: IR6/MCE
Pros: Plenty of buttons that are labelled properly for live tv/guide. Easy to use for non kodi users.
Cons: Requires IR receiver and line of sight, somewhat clicky buttons.
Other: https://www.amazon.co.uk/gp/product/B005F28GYU
OS: Android
Connection type: Wireless/Bluetooth
Pros: Small, quality build. Headphone jack, perfect for late at night in bed.
Cons: Far too few buttons, battery doesn't last long enough especially with headphones. Expensive.
Other: https://www.amazon.co.uk/NVIDIA-SHIELD-B...B00XO7AK9M
Media Device: Intel D34010WYK NUC
Pros: Excellent battery life, full function keyboard, used for around a year+
Cons: Range is a bit poor, especially if wall/objects in between. So, using a USB extension cable
Media Device: Dell Inspiron Micro 3050
Pros: Excellent battery life, full function keyboard, used for 6+ months
Cons: Range is a bit lacking, but have keyboard 12-14 ft away from HTPC, so not really an issue
Name: Logitech Harmony Ultimate w/Hub
Remote Device: Universal remote
Media Device: HiMedia Q10 Pro, Intel D34010WYK NUC
OS: Android (former); Windows 10 Pro x64 (latter)
Connection type: Wireless (Bluetooth to hub, which sends IR)
Pros: First class remote, does just about anything you need
Cons: Pricey, and sometimes complicated to program fully to suit needs
Name: Logitech Harmony Smart w/Hub
Media Device: nVidia Shield
OS: Android
Pros: Very good remote, great form factor for holding in hand
Cons: Pricey, and sometimes complicated to program fully to suit needs. Lacks LCD touchscreen, which Ultimate has
Name: Minix A2 Lite
Remote Device: Air-mouse remote w/keyboard on flip-side
Pros: Air-mouse, keyboard, big enough for holding
Cons: No right-click function
Name: Mele f10 deluxe
Remote Device: Keyboard + Remote (yep. both rf and ir)
Media Device: Wetek Core
OS: TB (Linux)
Pros:
has full qwerty keyboard, has ir learning (to control up to 2 additional devices via ir) function, has built-in li-ion battery - charging it once a few months (3-6), has airmouse, but I dont really use that
Cons: none for me
Other: ebay / amazon Wink
Name: Apple Remote (2nd Generation)
Media Device: Mac Mini
OS: Linux
Connection type: IR
Pros: Simple and including long presses does everything I need. Battery lasts for ever. Feels good in hand Wink
Cons: Few buttons relies on good skin navigation design (which is almost a pro) Big Grin
Other: https://en.wikipedia.org/wiki/Apple_Remote
Update For the remote to work under Linux, use atvclient (requires compilation).
Name: Rii mini i6 RF-version with mini usb dongle
Remote Device: mini-keyboard / Remote
Media Device: HTPC
OS: Windows
Connection type: Wireless version
Pros:
++ can learn the IR codes from original remotes (works with my LG TV)
++ more responsive touchpad compared to my old rii mini-keyboard
+ perfect size
+ backlit
Cons:
- problems with distance (? mini usb dongle), so I had to use usb extension. Now it works fine.
- sleep mode: can't wake up instantly, I need to make a long press or 1 extra click. Very annoying =(
- not good battery life compared to my old rii mini-keyboard.
- not reliable on/off switch
Pages: 1 2
