(2017-07-09, 13:20)tehax Wrote: [ -> ]No, i still have all time the same tv cannel logo as fanart. Nothing changed.
Good.
Means nothing has been broken with live tv by the update.
It's because there is no fanart sent by Kodi for live tv just a thumb - so Frontview uses this twice.
Glenn
Could try new new version 1.267
Probably will be the same - but checks for fanart from PVR sources (I haven't got any that send it) but if there will use it
Sent from my iPhone
(2017-07-10, 17:35)tehax Wrote: [ -> ]No change. May you can add to use tv show name instead of channel name which shows twice.
https://imgur.com/a/os3uS
If it is sent then yes should be possible to change.
Can you send log using PVR and can check what is sent?
(2017-07-11, 17:18)tehax Wrote: [ -> ]Here is a log.
https://pastebin.com/nYGbNv8C
Thanks - but sorry need trace debug on as well (a doesn't seem to be here) to get details of what is sent at playback start for pvr.
Log is to big for pastebin. Send you a PM.
Windows 7 updated last night (this morning). Frontview won't start now. I uninstalled and reinstalled latest version (1.267). No dice.
(2017-07-12, 18:06)douggoodwin Wrote: [ -> ]Windows 7 updated last night (this morning). Frontview won't start now. I uninstalled and reinstalled latest version (1.267). No dice.
That's no good. It's Iikely unrelated I suspect - may be some security setting. But a log will sort out... as my ESP skills are temporality lacking...
Can I have a debug and trace log. (Can turn on in settings.xml file in %appdtata% Frontview+ if needed to)
(2017-07-12, 17:42)tehax Wrote: [ -> ]Log is to big for pastebin. Send you a PM.
?To big for PM as haven't received.
(2017-07-12, 23:23)GlennNZ Wrote: [ -> ] (2017-07-12, 17:42)tehax Wrote: [ -> ]Log is to big for pastebin. Send you a PM.
Please do not send logs in PM's. It plays havoc with the forum database.
Post to a pastebin. There are other pastebin sites that allow larger files. A google search will quickly find them. Also, restart kodi once you enable debugging. This will clear out the previous entries.
Wherever they go - do need logs otherwise nothing is changing....
Glenn
New version up:
1.269
All going well fix for Windows 7
And trial attempt at using showname in PVR if available
At GitHub
Glenn
Sent from my iPhone
(2017-07-16, 13:15)tehax Wrote: [ -> ]Showname do not work for me with PVR Client ServerWMC.
https://pastebin.com/ugZSmhdT
It is probably because they are not sent by the PVR client
But again - need a trace and debug log to find out what is sent. (Included one is debug only - again)
