Version 1.200
Fix for Save Settings if Blank Items.
Fixes for DDC when slow to later check connection possible.
More DDC logic fixes
Add Checkbox box to disable nowPlaying MediaIcons
Installer registry changes to mark Frontview+.exe as HPIDPIAWARE
Add nosplashscreen CmdLine argument option to disable splashscreen (run Frontview.exe nosplashscreen - to disable splash)
Changes for DisplayScreen to enable better support for unusual screen setups/Virtual Desktops (rewriting the DisplayScreen code)
Add Option to NOT show MediaIcons on NowPlaying Screen
Now Shows MediaIcons on TV NowPlaying screen
Fix for TV NowPlaying Title size issues
Changed MediaIcons to slightly darker versions
Remove wyUpdate Code (may revisit later)
Version 1.199 Beta
Change to remote Version numbers Emby - just use first 3 digits (eg. 3.1 etc)
Addition of DDC/CI Monitor Settings Control:
Under DDC/Amp in Settings - will only work with monitors that support DDC (and unsure re USB Monitors)
Allows FrontView to control the monitor settings directly (same as adjusting monitor menu settings)
Enables FrontView to completely lower brightness and contrast during playback - avoiding a blank yet still 'bright' screen
Add MediaIcons to NowPlaying Movie Screen:
Very limited screen real estate. Happy to take suggestions for placement
Todo: Add checkbox to remove displaying icons
Fix to Disable MediaIcons in NowPlaying Popup MovieDetails Screen
https://github.com/Ghawken/FrontView/releases
