Full Version: Boblight problem half working
hi all !
long time since i didn't use my boblight setup, so i've decided to put it on again!
so far connexion are ok, i use 2x25 ws2801 strand
i use a arduino uno with this code:
// Arduino "bridge" code between host computer and WS2801-based digital
// RGB LED pixels (e.g. Adafruit product ID #322).  Intended for use
// with USB-native boards such as Teensy or Adafruit 32u4 Breakout;
// works on normal serial Arduinos, but throughput is severely limited.
// LED data is streamed, not buffered, making this suitable for larger
// installations (e.g. video wall, etc.) than could otherwise be held
// in the Arduino's limited RAM.
// Some effort is put into avoiding buffer underruns (where the output
// side becomes starved of data).  The WS2801 latch protocol, being
// delay-based, could be inadvertently triggered if the USB bus or CPU
// is swamped with other tasks.  This code buffers incoming serial data
// and introduces intentional pauses if there's a threat of the buffer
// draining prematurely.  The cost of this complexity is somewhat
// reduced throughput, the gain is that most visual glitches are
// avoided (though ultimately a function of the load on the USB bus and
// host CPU, and out of our control).
// LED data and clock lines are connected to the Arduino's SPI output.
// On traditional Arduino boards, SPI data out is digital pin 11 and
// clock is digital pin 13.  On both Teensy and the 32u4 Breakout,
// data out is pin B2, clock is B1.  LEDs should be externally
// powered -- trying to run any more than just a few off the Arduino's
// 5V line is generally a Bad Idea.  LED ground should also be
// connected to Arduino ground.
//   This file is part of Adalight.
//   Adalight is free software: you can redistribute it and/or modify
//   it under the terms of the GNU Lesser General Public License as
//   published by the Free Software Foundation, either version 3 of
//   the License, or (at your option) any later version.
//   Adalight is distributed in the hope that it will be useful,
//   but WITHOUT ANY WARRANTY; without even the implied warranty of
//   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//   GNU Lesser General Public License for more details.
//   You should have received a copy of the GNU Lesser General Public
//   License along with Adalight.  If not, see
//   <http://www.gnu.org/licenses/>.
#include <SPI.h>
// LED pin for Adafruit 32u4 Breakout Board:
//#define LED_DDR  DDRE
//#define LED_PORT PORTE
//#define LED_PIN  _BV(PORTE6)
// LED pin for Teensy:
//#define LED_DDR  DDRD
//#define LED_PORT PORTD
//#define LED_PIN  _BV(PORTD6)
// LED pin for Arduino:
#define LED_DDR  DDRB
#define LED_PORT PORTB
#define LED_PIN  _BV(PORTB5)
// A 'magic word' (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch).  You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided -- fewer false positives.  The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55).  LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
static const uint8_t magic[] = {'A','d','a'};
#define MAGICSIZE  sizeof(magic)
#define HEADERSIZE (MAGICSIZE + 3)
#define MODE_HEADER 0
#define MODE_HOLD   1
#define MODE_DATA   2
// If no serial data is received for a while, the LEDs are shut off
// automatically.  This avoids the annoying "stuck pixel" look when
// quitting LED display programs on the host computer.
static const unsigned long serialTimeout = 15000; // 15 seconds
void setup()
  // Dirty trick: the circular buffer for serial data is 256 bytes,
  // and the "in" and "out" indices are unsigned 8-bit types -- this
  // much simplifies the cases where in/out need to "wrap around" the
  // beginning/end of the buffer.  Otherwise there'd be a ton of bit-
  // masking and/or conditional code every time one of these indices
  // needs to change, slowing things down tremendously.
  uint8_t
    buffer[256],
    indexIn       = 0,
    indexOut      = 0,
    mode          = MODE_HEADER,
    hi, lo, chk, i, spiFlag;
  int16_t
    bytesBuffered = 0,
    hold          = 0,
    c;
  int32_t
    bytesRemaining;
  unsigned long
    startTime,
    lastByteTime,
    lastAckTime,
    t;
  LED_DDR  |=  LED_PIN; // Enable output for LED
  LED_PORT &= ~LED_PIN; // LED off
  Serial.begin(115200); // Teensy/32u4 disregards baud rate; is OK!
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SPI_MODE0);
  SPI.setClockDivider(SPI_CLOCK_DIV16); // 1 MHz max, else flicker
  // Issue test pattern to LEDs on startup.  This helps verify that
  // wiring between the Arduino and LEDs is correct.  Not knowing the
  // actual number of LEDs connected, this sets all of them (well, up
  // to the first 25,000, so as not to be TOO time consuming) to red,
  // green, blue, then off.  Once you're confident everything is working
  // end-to-end, it's OK to comment this out and reprogram the Arduino.
  uint8_t testcolor[] = { 0, 0, 0, 255, 0, 0 };
  for(char n=3; n>=0; n--) {
    for(c=0; c<25000; c++) {
      for(i=0; i<3; i++) {
        for(SPDR = testcolor[n + i]; !(SPSR & _BV(SPIF)); );
    delay(1); // One millisecond pause = latch
  Serial.print("Ada\n"); // Send ACK string to host
  startTime    = micros();
  lastByteTime = lastAckTime = millis();
  // loop() is avoided as even that small bit of function overhead
  // has a measurable impact on this code's overall throughput.
  for(;;) {
    // Implementation is a simple finite-state machine.
    // Regardless of mode, check for serial input each time:
    t = millis();
    if((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) {
      buffer[indexIn++] = c;
      bytesBuffered++;
      lastByteTime = lastAckTime = t; // Reset timeout counters
    } else {
      // No data received.  If this persists, send an ACK packet
      // to host once every second to alert it to our presence.
      if((t - lastAckTime) > 1000) {
        lastAckTime = t; // Reset counter
      // If no data received for an extended time, turn off all LEDs.
      if((t - lastByteTime) > serialTimeout) {
        for(c=0; c<32767; c++) {
          for(SPDR=0; !(SPSR & _BV(SPIF)); );
        lastByteTime = t; // Reset counter
    switch(mode) {
     case MODE_HEADER:
      // In header-seeking mode.  Is there enough data to check?
      if(bytesBuffered >= HEADERSIZE) {
        // Indeed.  Check for a 'magic word' match.
        for(i=0; (i<MAGICSIZE) && (buffer[indexOut++] == magic[i++]););
        if(i == MAGICSIZE) {
          // Magic word matches.  Now how about the checksum?
          hi  = buffer[indexOut++];
          lo  = buffer[indexOut++];
          chk = buffer[indexOut++];
          if(chk == (hi ^ lo ^ 0x55)) {
            // Checksum looks valid.  Get 16-bit LED count, add 1
            // (# LEDs is always > 0) and multiply by 3 for R,G,B.
            bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
            bytesBuffered -= 3;
            spiFlag        = 0;         // No data out yet
            mode           = MODE_HOLD; // Proceed to latch wait mode
          } else {
            // Checksum didn't match; search resumes after magic word.
            indexOut  -= 3; // Rewind
        } // else no header match.  Resume at first mismatched byte.
        bytesBuffered -= i;
      break;
     case MODE_HOLD:
      // Ostensibly "waiting for the latch from the prior frame
      // to complete" mode, but may also revert to this mode when
      // underrun prevention necessitates a delay.
      if((micros() - startTime) < hold) break; // Still holding; keep buffering
      // Latch/delay complete.  Advance to data-issuing mode...
      mode      = MODE_DATA; // ...and fall through (no break):
     case MODE_DATA:
      while(spiFlag && !(SPSR & _BV(SPIF))); // Wait for prior byte
      if(bytesRemaining > 0) {
        if(bytesBuffered > 0) {
          SPDR = buffer[indexOut++];   // Issue next byte
          bytesBuffered--;
          bytesRemaining--;
          spiFlag = 1;
        // If serial buffer is threatening to underrun, start
        // introducing progressively longer pauses to allow more
        // data to arrive (up to a point).
        if((bytesBuffered < 32) && (bytesRemaining > bytesBuffered)) {
          hold      = 100 + (32 - bytesBuffered) * 10;
          mode      = MODE_HOLD;
      } else {
        // End of data -- issue latch:
        hold       = 1000;        // Latch duration = 1000 uS
        LED_PORT  |= LED_PIN;     // LED on
        mode       = MODE_HEADER; // Begin next header search
    } // end switch
  } // end for(;;)
void loop()
  // Not used.  See note in setup() function.
at this time, when i power on the arduino the 50 leds show RGB on startup, so wiring is ok.
i use a asrock ion330 as htpc with openelec, I've installed boblight demon and kodi boblight addons.
here is my boblight conf file:
[global]
timeout         20
interface       127.0.0.1
port            19333
interpolation   on
proportional    100.0
saturation      1.5
value           1.2
valuerange      0.0 1.0
use             yes
method          average
threshold       10
[device]
name            ambilight
type            atmo
output          /dev/ttyACM0
rate            115200
channels        150
interval        20000
prefix          41 64 61 00 18 4D
[color]
name            red
rgb             FF0000
gamma           1.0
adjust          1.0
blacklevel      0.0
[color]
name            green
rgb             00FF00
gamma           1.0
adjust          1.0
blacklevel      0.0
[color]
name            blue
rgb             0000FF
gamma           1.0
adjust          1.0
blacklevel      0.0
[light]
name    Right_9
color    red        ambilight 1
color    green    ambilight 2
color    blue    ambilight 3
hscan    85 100
vscan    88.88 100
[light]
name    Right_8
color    red        ambilight 4
color    green    ambilight 5
color    blue    ambilight 6
hscan    85 100
vscan    77.77 88.88
[light]
name    Right_7
color    red        ambilight 7
color    green    ambilight 8
color    blue    ambilight 9
hscan    85 100
vscan    66.66 77.77
[light]
name    Right_6
color    red        ambilight 10
color    green    ambilight 11
color    blue    ambilight 12
hscan    85 100
vscan    55.55 66.66
[light]
name    Right_5
color    red        ambilight 13
color    green    ambilight 14
color    blue    ambilight 15
hscan    85 100
vscan    44.44 55.55
[light]
name    Right_4
color    red        ambilight 16
color    green    ambilight 17
color    blue    ambilight 18
hscan    85 100
vscan    33.33 44.44
[light]
name    Right_3
color    red        ambilight 19
color    green    ambilight 20
color    blue    ambilight 21
hscan    85 100
vscan    22.22 33.33
[light]
name    Right_2
color    red        ambilight 22
color    green    ambilight 23
color    blue    ambilight 24
hscan    85 100
vscan    11.11 22.22
[light]
name    Right_1
color    red        ambilight 25
color    green    ambilight 26
color    blue    ambilight 27
hscan    85 100
vscan    0 11.11
[light]
name    Top_16
color    red        ambilight 28
color    green    ambilight 29
color    blue    ambilight 30
hscan    93.75 100
vscan    0 15
[light]
name    Top_15
color    red        ambilight 31
color    green    ambilight 32
color    blue    ambilight 33
hscan    87.5 93.75
vscan    0 15
[light]
name    Top_14
color    red        ambilight 34
color    green    ambilight 35
color    blue    ambilight 36
hscan    81.25 87.5
vscan    0 15
[light]
name    Top_13
color    red        ambilight 37
color    green    ambilight 38
color    blue    ambilight 39
hscan    75 81.25
vscan    0 15
[light]
name    Top_12
color    red        ambilight 40
color    green    ambilight 41
color    blue    ambilight 42
hscan    68.75 75
vscan    0 15
[light]
name    Top_11
color    red        ambilight 43
color    green    ambilight 44
color    blue    ambilight 45
hscan    62.5 68.75
vscan    0 15
[light]
name    Top_10
color    red        ambilight 46
color    green    ambilight 47
color    blue    ambilight 48
hscan    56.25 62.5
vscan    0 15
[light]
name    Top_9
color    red        ambilight 49
color    green    ambilight 50
color    blue    ambilight 51
hscan    50 56.25
vscan    0 15
[light]
name    Top_8
color    red        ambilight 52
color    green    ambilight 53
color    blue    ambilight 54
hscan    43.75 50
vscan    0 15
[light]
name    Top_7
color    red        ambilight 55
color    green    ambilight 56
color    blue    ambilight 57
hscan    37.5 43.75
vscan    0 15
[light]
name    Top_6
color    red        ambilight 58
color    green    ambilight 59
color    blue    ambilight 60
hscan    31.25 37.5
vscan    0 15
[light]
name    Top_5
color    red        ambilight 61
color    green    ambilight 62
color    blue    ambilight 63
hscan    25 31.25
vscan    0 15
[light]
name    Top_4
color    red        ambilight 64
color    green    ambilight 65
color    blue    ambilight 66
hscan    18.75 25
vscan    0 15
[light]
name    Top_3
color    red        ambilight 67
color    green    ambilight 68
color    blue    ambilight 69
hscan    12.5 18.75
vscan    0 15
[light]
name    Top_2
color    red        ambilight 70
color    green    ambilight 71
color    blue    ambilight 72
hscan    6.25 12.5
vscan    0 15
[light]
name    Top_1
color    red        ambilight 73
color    green    ambilight 74
color    blue    ambilight 75
hscan    0 6.25
vscan    0 15
[light]
name    Left_1
color    red        ambilight 76
color    green    ambilight 77
color    blue    ambilight 78
hscan    0 15
vscan    0 11.11
[light]
name    Left_2
color    red        ambilight 79
color    green    ambilight 80
color    blue    ambilight 81
hscan    0 15
vscan    11.11 22.22
[light]
name    Left_3
color    red        ambilight 82
color    green    ambilight 83
color    blue    ambilight 84
hscan    0 15
vscan    22.22 33.33
[light]
name    Left_4
color    red        ambilight 85
color    green    ambilight 86
color    blue    ambilight 87
hscan    0 15
vscan    33.33 44.44
[light]
name    Left_5
color    red        ambilight 88
color    green    ambilight 89
color    blue    ambilight 90
hscan    0 15
vscan    44.44 55.55
[light]
name    Left_6
color    red        ambilight 91
color    green    ambilight 92
color    blue    ambilight 93
hscan    0 15
vscan    55.55 66.66
[light]
name    Left_7
color    red        ambilight 94
color    green    ambilight 95
color    blue    ambilight 96
hscan    0 15
vscan    66.66 77.77
[light]
name    Left_8
color    red        ambilight 97
color    green    ambilight 98
color    blue    ambilight 99
hscan    0 15
vscan    77.77 88.88
[light]
name    Left_9
color    red        ambilight 100
color    green    ambilight 101
color    blue    ambilight 102
hscan    0 15
vscan    88.88 100
[light]
name    Bottom_1
color    red        ambilight 103
color    green    ambilight 104
color    blue    ambilight 105
hscan    0 6.25
vscan    0 15
[light]
name    Bottom_2
color    red        ambilight 106
color    green    ambilight 107
color    blue    ambilight 108
hscan    6.25 12.5
vscan    0 15
[light]
name    Bottom_3
color    red        ambilight 109
color    green    ambilight 110
color    blue    ambilight 111
hscan    12.5 18.75
vscan    0 15
[light]
name    Bottom_4
color    red        ambilight 112
color    green    ambilight 113
color    blue    ambilight 114
hscan    18.75 25
vscan    0 15
[light]
name    Bottom_5
color    red        ambilight 115
color    green    ambilight 116
color    blue    ambilight 117
hscan    25 31.25
vscan    0 15
[light]
name    Bottom_6
color    red        ambilight 118
color    green    ambilight 119
color    blue    ambilight 120
hscan    31.25 37.5
vscan    0 15
[light]
name    Bottom_7
color    red        ambilight 121
color    green    ambilight 122
color    blue    ambilight 123
hscan    37.5 43.75
vscan    0 15
[light]
name    Bottom_8
color    red        ambilight 124
color    green    ambilight 125
color    blue    ambilight 126
hscan    43.75 50
vscan    0 15
[light]
name    Bottom_9
color    red        ambilight 127
color    green    ambilight 128
color    blue    ambilight 129
hscan    50 56.25
vscan    0 15
[light]
name    Bottom_10
color    red        ambilight 130
color    green    ambilight 131
color    blue    ambilight 132
hscan    56.25 62.5
vscan    0 15
[light]
name    Bottom_11
color    red        ambilight 133
color    green    ambilight 134
color    blue    ambilight 135
hscan    62.5 68.75
vscan    0 15
[light]
name    Bottom_12
color    red        ambilight 136
color    green    ambilight 137
color    blue    ambilight 138
hscan    68.7 75
vscan    0 15
[light]
name    Bottom_13
color    red        ambilight 139
color    green    ambilight 140
color    blue    ambilight 141
hscan    75 81.25
vscan    0 15
[light]
name    Bottom_14
color    red        ambilight 142
color    green    ambilight 143
color    blue    ambilight 144
hscan    81.25 87.5
vscan    0 15
[light]
name    Bottom_15
color    red        ambilight 145
color    green    ambilight 146
color    blue    ambilight 147
hscan    87.5 93.75
vscan    0 15
[light]
name    Bottom_16
color    red        ambilight 148
color    green    ambilight 149
color    blue    ambilight 150
hscan    93.75 100
vscan    0 15
after a restart, all seem to work, for the 25 first leds ...
i've tried some other conf file, changing prefix, etc.
nothing seems to make it work, if i launch a video, it's working, on half screen.
i can't figure out what i've missed here, and hope someone can point me to it .
thx.
