The following does not work at all in an include using parameters:
<include name=" ... " condition="Container.Content( ... )">
<param name=" ... " value=" ... " />
</include>
Whereas the following does work:
<include condition="Container.Content( .. )"> ... </include>
Other conditions seem to work OK on includes using parameters:
<include name=" ... " condition="Skin.HasSetting( ... )">
</include>
<include name=" ... " condition="SubString( ... , ... )">
</include>
Does anyone have any thoughts?
And they worked in Isengard?
(2016-02-09, 09:10)Hitcher Wrote: [ -> ]And they worked in Isengard?
I don't know. Actually I guess not as I believe that Container.Content() as a boolean condition was introduced in Jarvis?
I have tried the following, which also doesn't work:
<include name=" ... " condition="SubString(Container.Content, ... )">
</include>
For now, rather than using, for example:
<include name=" ... " condition="Container.Content(movies)">
</include>
I am using:
<include name=" ... " condition="SubString(Container.FolderPath,movies)">
</include>
I imagine that these in most, if not all cases, are interchangeable.
(2016-02-09, 10:39)dnairb Wrote: [ -> ]I have just seen this: http://forum.kodi.tv/showthread.php?tid=259305 which may be the culprit.
(i.e. commented out lines <!-- --> could be breaking the include)
I will check later today.
I can confirm that removing all xml comments (<!-- ... -->) from both the include and the control containing a call to the include does not fix this issue.
So it seems that the implementation of the Container.Content() boolean condition is broken.
You can't use Container.Content for an include because the content will only be known after the xml file is loaded, especially with plugins.
(2016-02-09, 23:21)marcelveldt Wrote: [ -> ]You can't use Container.Content for an include because the content will only be known after the xml file is loaded, especially with plugins.
Hmm. If so, why does "Container.Folderpath, ..." work? (post #4 above)
My include is invoked within a page, rather than to load a page.
I guess because the path needs to be know to open the window whereas the content isn't know until the path is loaded.
(2016-02-10, 00:07)dnairb Wrote: [ -> ]Hmm. If so, why does "Container.Folderpath, ..." work? (post #4 above)
(2016-02-10, 00:47)Hitcher Wrote: [ -> ]I guess because the path needs to be know to open the window whereas the content isn't know until the path is loaded.
Hmm. OK, I guess.
My includes now do what I intended, using "Container.Folderpath, ..." Thank you for listening...
