2016-03-14, 00:11
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176
2016-03-14, 00:16
(2016-03-14, 00:11)dirtydesaster Wrote: [ -> ]can I skip the profile-dialog?
http://abload.de/img/unbenannt9zy8v.png
https://github.com/DanCooper/Ember-MM-Ne...d1487de94c
2016-03-14, 10:29
(2016-03-13, 19:00)T-bird_se Wrote: [ -> ]Found a bug for clearart, logos ... then it's a stacked movie, saying not found, syncing from context menu in file list
Log snippet included
Quote:2016-03-13 17:39:47.4104;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_UpdateInfo_Movie.MoveNext;7;TRACE;"[APIKodi] [Lilleman] UpdateMovieInfo: ""Sagan om ringen: Härskarringen"" | Start syncing process...";
2016-03-13 17:39:47.7848;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_26_SearchMovie.MoveNext;15;WARN;"[APIKodi] [Lilleman] SearchMovie: ""\\Diskstation\xbmc\Film\Sagan om Ringen\Sagan om ringen - Härskarringen (2001)\Sagan om ringen - Härskarringen (2001).bluray.cd1.mkv"" | NOT found in host database!";
2016-03-13 17:39:47.7848;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_UpdateInfo_Movie.MoveNext;15;TRACE;"[APIKodi] [Lilleman] UpdateMovieInfo: ""Sagan om ringen: Härskarringen"" | NOT found in database, scan directory on host...";
2016-03-13 17:39:47.7848;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_41_VideoLibrary_ScanPath.MoveNext;15;TRACE;"[APIKodi] [Lilleman] ScanVideoPath: ""smb://DISKSTATION/XBMC/Film/Sagan om Ringen/Sagan om ringen - Härskarringen (2001)"" | Start scanning process...";
2016-03-13 17:39:48.2684;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_45_IsScanningVideo.MoveNext;15;TRACE;[APIKodi] [Lilleman] IsScanningVideo: True;
2016-03-13 17:39:49.5164;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_45_IsScanningVideo.MoveNext;15;TRACE;[APIKodi] [Lilleman] IsScanningVideo: False;
2016-03-13 17:39:49.7348;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_26_SearchMovie.MoveNext;15;WARN;"[APIKodi] [Lilleman] SearchMovie: ""\\Diskstation\xbmc\Film\Sagan om Ringen\Sagan om ringen - Härskarringen (2001)\Sagan om ringen - Härskarringen (2001).bluray.cd1.mkv"" | NOT found in host database!";
2016-03-13 17:39:49.7348;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_UpdateInfo_Movie.MoveNext;15;ERROR;"[APIKodi] [Lilleman] UpdateMovieInfo: ""Sagan om ringen: Härskarringen"" | NOT found on host! Abort!";
2016-03-13 17:39:49.7348;generic.Interface.Kodi.KodiInterface;generic.Interface.Kodi.KodiInterface+VB$StateMachine_74_GenericRunCallBack.MoveNext;1;WARN;[KodiInterface] [Lilleman] RunGeneric Movie Update | Sync Failed: Sagan om ringen: Härskarringen;
2016-03-13 17:39:49.7348;EmberAPI.ModulesManager;EmberAPI.ModulesManager.RunGeneric;1;TRACE;[ModulesManager] [RunGeneric] [Start] <Notification>;
2016-03-13 17:39:49.7504;EmberAPI.ModulesManager;EmberAPI.ModulesManager.RunGeneric;1;TRACE;[ModulesManager] [RunGeneric] Run generic module <Notifications>;
2016-03-13 17:40:09.3753;Ember_Media_Manager.frmMain;Ember_Media_Manager.frmMain.frmMain_FormClosed;1;INFO;====Ember Media Manager exiting====;
We can't sync multi part videos. Kodi save that with a strange path/file name in database. But we are working on a solution.
2016-03-14, 12:11
(2016-03-14, 10:29)DanCooper Wrote: [ -> ](2016-03-13, 19:00)T-bird_se Wrote: [ -> ]Found a bug for clearart, logos ... then it's a stacked movie, saying not found, syncing from context menu in file list
Should be fixed in Alpha 12: Commit and Commit
2016-03-14, 17:51
2016-03-14, 18:16
(2016-03-10, 07:48)orbtwin Wrote: [ -> ](2016-03-10, 01:03)DanCooper Wrote: [ -> ](2016-03-09, 00:38)orbtwin Wrote: [ -> ]i can't mark a show as watched.
all season and episodes are marked as watched so
If you have watched a tv show, do you not watched all episodes??
EDIT:
(2016-03-10, 00:28)T-bird_se Wrote: [ -> ]I seen the same
Importing library to Ember and just one show get the view mark but all seasons an episodes are marked as viewed
If I try to mark it as unseen all marks is gone as expected, but if I try to set it as seen again it's back to not mark the show itself
Oh, now i understand the problem Yes, it's a bug in tvshow view with calculating. Will be fixed in next alpha.
EDIT: I hope it will be fixed in next alpha
thanks again for the answer.
i explained bad
Also fixed for Alpha 12: Commit
2016-03-14, 23:20
Is there a way to increase the "directory/file.name" past the 256 character limit? Ran into this problem on the initial scrape of my TV directory. I am really not looking forward to finding a way to truncate.
2016-03-14, 23:38
Could you please the Greek flag to appear properly... ( i have movies with greek audio and subtitle and a ? appears instead of flag) can you check this?
2016-03-15, 00:09
(2016-03-14, 23:20)Hecatonchieres Wrote: [ -> ]Is there a way to increase the "directory/file.name" past the 256 character limit? Ran into this problem on the initial scrape of my TV directory. I am really not looking forward to finding a way to truncate.
Nope, the .NET API supports only 256/260 characters like Windows Explorer. There is an Unicode-API in Windows that we can, but I don't want use that atm. I've no experience whit that and scared to save data in a path that a "noob" user no longer can use to save new files inside this folder with Explorer.
2016-03-15, 00:13
(2016-03-14, 23:38)solamnic Wrote: [ -> ]Could you please the Greek flag to appear properly... ( i have movies with greek audio and subtitle and a ? appears instead of flag) can you check this?
I think that problem is already posted in our bug tracker. Please tell me which "LongLanguage" and "Language" is saved in NFO.
You can fix your Languages.xml to fix that issue. Simply modify the "Alpha2" or "Alpha3" to the correct value like this:
<Language>
<Alpha2>el</Alpha2>
<Alpha3>ell</Alpha3>
<Name>Modern Greek</Name>
</Language>
2016-03-15, 08:47
(2016-03-15, 00:13)DanCooper Wrote: [ -> ](2016-03-14, 23:38)solamnic Wrote: [ -> ]Could you please the Greek flag to appear properly... ( i have movies with greek audio and subtitle and a ? appears instead of flag) can you check this?
Code:<Language>
<Alpha2>el</Alpha2>
</Language>
Checking language.xml has correct the above values
here is part of nfo file (that displays Greek language as gre not el, or ell)
<streamdetails>
<video>
<aspect>1.778</aspect>
<codec>h264</codec>
<durationinseconds>5286</durationinseconds>
<height>1080</height>
<scantype>progressive</scantype>
<width>1920</width>
</video>
<audio>
<channels>8</channels>
<codec>dtshd_ma</codec>
<language>eng</language>
</audio>
<audio>
<channels>6</channels>
<codec>ac3</codec>
<language>gre</language>
</audio>
<subtitle>
</subtitle>
<subtitle>
</subtitle>
</streamdetails>
</fileinfo>
</movie>
2016-03-15, 10:55
(2016-03-15, 08:47)solamnic Wrote: [ -> ](2016-03-15, 00:13)DanCooper Wrote: [ -> ](2016-03-14, 23:38)solamnic Wrote: [ -> ]Could you please the Greek flag to appear properly... ( i have movies with greek audio and subtitle and a ? appears instead of flag) can you check this?
Code:<Language>
<Alpha2>el</Alpha2>
</Language>
Code:<streamdetails>
<video>
<codec>h264</codec>
<width>1920</width>
</video>
<audio>
</audio>
<audio>
<codec>ac3</codec>
</audio>
<subtitle>
</subtitle>
<subtitle>
</subtitle>
</streamdetails>
</fileinfo>
</movie>
It's a little bit tricky....
MediaInfo use "gre" as Alpha3 code
The Language.xml use "ell" as Alpha3 and "el" as Alpha2.
The flag image calls "el.png".
"B" (bibliographic)
"T" (terminology)
In comparing to german Alpha codes, "de" and "deu" is correct:
I would say that MediaInfo set the wrong language code and you have to change that manually in our Metadata Editor. Than the country flag will be displayed.
Alternative you add this new node to the Languages.xml and copy the flag "el.png" also to "gr.png":
<Language>
<Alpha2>gr</Alpha2>
<Alpha3>gre</Alpha3>
<Name>Greek</Name>
</Language>
2016-03-15, 11:51
i did the added the node in languages.xml also copied the flag to gr.png..
and everything is ok...
please add it to the next release of ember
2016-03-15, 12:37
also i have many nfo's that produce errors with ember (object not referrence .... etc) but they are accepted by kodi
<?xml version='1.0' encoding='utf-8'?>
<!--YAMJ XML Generated by YANFOE Movies Edition (1.0) - 11/10/2012 00:22:11-->
<movie>
<id>tt0126029</id>
<id moviedb="tmdb">808</id>
<title>Shrek</title>
<year>2001</year>
<releasedate>07-09-2001</releasedate>
<rating>7</rating>
<votes>1743</votes>
<outline>It ain't easy bein' green -- especially if you're a likable (albeit smelly) ogre named Shrek. On a mission to retrieve a gorgeous princess from the clutches of a fire-breathing dragon, Shrek teams up with an unlikely compatriot -- a wisecracking donkey.</outline>
<plot>It ain't easy bein' green -- especially if you're a likable (albeit smelly) ogre named Shrek. On a mission to retrieve a gorgeous princess from the clutches of a fire-breathing dragon, Shrek teams up with an unlikely compatriot -- a wisecracking donkey.</plot>
<tagline>The greatest fairy tale never told.</tagline>
<mpaa>U</mpaa>
<certification>Malaysia:U / Portugal:M/4 / Iceland:L / South Korea:All / South Africa:A / South Africa:PG / Argentina:Atp / Australia:PG / Brazil:Livre / Chile:TE / Finland:K-7 / France:U / Germany:o.Al. / Hong Kong:I / Ireland:G / Netherlands:MG6 / Peru:PT / Philippines:G / Singapore:G / Spain:T / Sweden:7 / Switzerland:7 / Switzerland:7 / UK:U / USA:PG / Greece:K / Norway:7 / Canada:F / Canada:PG / Canada:G</certification>
<company>DreamWorks Animation</company>
<language>English</language>
<set>Shrek Collection</set>
<videosource>BluRay</videosource>
<videooutput>720p 24Hz</videooutput>
<originaltitle>Shrek</originaltitle>
<top250>0</top250>
<playcount>0</playcount>
<tmdbid>808</tmdbid>
<sorttitle></sorttitle>
<trailer>http://www.youtube.com/watch?v=W37DlG1i61s</trailer>
<watched>false</watched>
<runtime>90</runtime>
<credits>William Steig</credits>
<credits>Ted Elliott</credits>
<credits>Terry Rossio</credits>
<credits>Joe Stillman</credits>
<credits>Roger S.H. Schulman</credits>
<director>Vicky Jenson</director>
<studio>DreamWorks SKG</studio>
<studio>Pacific Data Images (PDI)</studio>
<studio>DreamWorks Animation</studio>
<genre>Adventure</genre>
<genre>Animation</genre>
<genre>Comedy</genre>
<genre>Family</genre>
<genre>Fantasy</genre>
<country>United States of America</country>
<thumb preview="http://image.tmdb.org/t/p/w342/140ewbWv8qHStD3mlBDvvGd0Zvu.jpg">http://image.tmdb.org/t/p/original/140ewbWv8qHStD3mlBDvvGd0Zvu.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/yC5fpfO9auj9fJ0UYA5MvbRnxHd.jpg">http://image.tmdb.org/t/p/original/yC5fpfO9auj9fJ0UYA5MvbRnxHd.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/4ybHCYMyUUaO2xjB80zh4KjkKsl.jpg">http://image.tmdb.org/t/p/original/4ybHCYMyUUaO2xjB80zh4KjkKsl.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/cGjhCcYhTGWxXlDJMWrK2lUa5PZ.jpg">http://image.tmdb.org/t/p/original/cGjhCcYhTGWxXlDJMWrK2lUa5PZ.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/sMDUEnVJNR2uhtlpXBvyxdE7AM5.jpg">http://image.tmdb.org/t/p/original/sMDUEnVJNR2uhtlpXBvyxdE7AM5.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/c7FFzG19gDZ3LfEltOn2oYuVGS0.jpg">http://image.tmdb.org/t/p/original/c7FFzG19gDZ3LfEltOn2oYuVGS0.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/xqdO57TJ19Gig9FQ6muUP3NtlQI.jpg">http://image.tmdb.org/t/p/original/xqdO57TJ19Gig9FQ6muUP3NtlQI.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/r5xh3IjUSYphyU4RkvZVzYV5rYO.jpg">http://image.tmdb.org/t/p/original/r5xh3IjUSYphyU4RkvZVzYV5rYO.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/jf6mwHe0ieI27RfwE7Vp1ikJuuO.jpg">http://image.tmdb.org/t/p/original/jf6mwHe0ieI27RfwE7Vp1ikJuuO.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/i8v9fbgehOeEHvF6znB1vGrKqDT.jpg">http://image.tmdb.org/t/p/original/i8v9fbgehOeEHvF6znB1vGrKqDT.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/7Oi9GwWatrvf5vTUgQRR7e9A8lM.jpg">http://image.tmdb.org/t/p/original/7Oi9GwWatrvf5vTUgQRR7e9A8lM.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/agDOQeEhdBVUE5XCQbI7kXc9vFW.jpg">http://image.tmdb.org/t/p/original/agDOQeEhdBVUE5XCQbI7kXc9vFW.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/m4FSTv9IR696DT1pikRIvQVGycD.jpg">http://image.tmdb.org/t/p/original/m4FSTv9IR696DT1pikRIvQVGycD.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/elIjJS4JcnmJavvCVM9JXpWsyet.jpg">http://image.tmdb.org/t/p/original/elIjJS4JcnmJavvCVM9JXpWsyet.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/vgoxjAqbIsoukByuDV8psXPb4U0.jpg">http://image.tmdb.org/t/p/original/vgoxjAqbIsoukByuDV8psXPb4U0.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/7WvZmbrnn6S5b0sVY3Yllmn5X0z.jpg">http://image.tmdb.org/t/p/original/7WvZmbrnn6S5b0sVY3Yllmn5X0z.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/aN8MhHTOstg8kuLnMjeiKSIraKM.jpg">http://image.tmdb.org/t/p/original/aN8MhHTOstg8kuLnMjeiKSIraKM.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/n78K1bTOrRBWOlOHRKv6vUnQnpF.jpg">http://image.tmdb.org/t/p/original/n78K1bTOrRBWOlOHRKv6vUnQnpF.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/lh0yryxEPiiwqStP9coBPCuiCrT.jpg">http://image.tmdb.org/t/p/original/lh0yryxEPiiwqStP9coBPCuiCrT.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/nREfX7RKJ208Gj1egGL3rC9EGr1.jpg">http://image.tmdb.org/t/p/original/nREfX7RKJ208Gj1egGL3rC9EGr1.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/t0PsVzYL7Rm8MJZQCDGqweAeMvZ.jpg">http://image.tmdb.org/t/p/original/t0PsVzYL7Rm8MJZQCDGqweAeMvZ.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/zpfCAjbtuehlPs7X0aGT8kv8EBK.jpg">http://image.tmdb.org/t/p/original/zpfCAjbtuehlPs7X0aGT8kv8EBK.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/1tqvTnUm9VabIQXeHxVJCCrdlZ6.jpg">http://image.tmdb.org/t/p/original/1tqvTnUm9VabIQXeHxVJCCrdlZ6.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/uw3KPLQwRcePPPUkxFN9vdC7aEo.jpg">http://image.tmdb.org/t/p/original/uw3KPLQwRcePPPUkxFN9vdC7aEo.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/elqg57hodBUD0D5SoflxlLOlkp3.jpg">http://image.tmdb.org/t/p/original/elqg57hodBUD0D5SoflxlLOlkp3.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/f9CZd5pSiHX63Aqp6TXldE6Cetp.jpg">http://image.tmdb.org/t/p/original/f9CZd5pSiHX63Aqp6TXldE6Cetp.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/OgdluFPui5xSNiPEa68xvCeWMW.jpg">http://image.tmdb.org/t/p/original/OgdluFPui5xSNiPEa68xvCeWMW.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/PqDpPZwPEszATI5PMXBmAcKNZA.jpg">http://image.tmdb.org/t/p/original/PqDpPZwPEszATI5PMXBmAcKNZA.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/4Ip4WiAh5Rr0aJlyLm5xbnEbDJh.jpg">http://image.tmdb.org/t/p/original/4Ip4WiAh5Rr0aJlyLm5xbnEbDJh.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/qku5gyeGrB7y6k1SjWvDvOGB4Ho.jpg">http://image.tmdb.org/t/p/original/qku5gyeGrB7y6k1SjWvDvOGB4Ho.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/meQspJeM0BaoeElPPiOHOEoI4LY.jpg">http://image.tmdb.org/t/p/original/meQspJeM0BaoeElPPiOHOEoI4LY.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/o8Yw4NmRgTvcDCOZZaF93WhyNNS.jpg">http://image.tmdb.org/t/p/original/o8Yw4NmRgTvcDCOZZaF93WhyNNS.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/v06jCWcnaiPf8Z9mF2CYiSFjJE6.jpg">http://image.tmdb.org/t/p/original/v06jCWcnaiPf8Z9mF2CYiSFjJE6.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/iMBaxERRhkNqne8PF6d3po5lzHl.jpg">http://image.tmdb.org/t/p/original/iMBaxERRhkNqne8PF6d3po5lzHl.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/syuTAIL0f5Ndh78uSRHKWiD5uRz.jpg">http://image.tmdb.org/t/p/original/syuTAIL0f5Ndh78uSRHKWiD5uRz.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/3sUeNnycXvCCsHotjjMgGCngl7a.jpg">http://image.tmdb.org/t/p/original/3sUeNnycXvCCsHotjjMgGCngl7a.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/96ASIhpS9WjuHW74KTH4KjdfmGC.jpg">http://image.tmdb.org/t/p/original/96ASIhpS9WjuHW74KTH4KjdfmGC.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/smg8A2nIEFB27eSmaSbIGXDyoPA.jpg">http://image.tmdb.org/t/p/original/smg8A2nIEFB27eSmaSbIGXDyoPA.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/6UtnnBlZlqmllGdbctTfg0WtSTS.jpg">http://image.tmdb.org/t/p/original/6UtnnBlZlqmllGdbctTfg0WtSTS.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/2PlCeh0kXWCChrc3mRH2pkt0MLQ.jpg">http://image.tmdb.org/t/p/original/2PlCeh0kXWCChrc3mRH2pkt0MLQ.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/cSSZIkPQENCMIAttQKkYbyYxOv6.jpg">http://image.tmdb.org/t/p/original/cSSZIkPQENCMIAttQKkYbyYxOv6.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/bG8p7yk9lxwv9hlfWqmGbPe23bG.jpg">http://image.tmdb.org/t/p/original/bG8p7yk9lxwv9hlfWqmGbPe23bG.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w342/mSPQWl516L7F1GcYtuVVAdQq5i5.jpg">http://image.tmdb.org/t/p/original/mSPQWl516L7F1GcYtuVVAdQq5i5.jpg</thumb>
<fanart>
<thumb preview="http://image.tmdb.org/t/p/w780/wBG4kHfhwm3bLwKUFNRByXXv4r2.jpg">http://image.tmdb.org/t/p/original/wBG4kHfhwm3bLwKUFNRByXXv4r2.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/uP2MIdOPzSkOeouhT7xu10TNEL2.jpg">http://image.tmdb.org/t/p/original/uP2MIdOPzSkOeouhT7xu10TNEL2.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/3l5CxSDIcWdtYne8m3BQDGOxFcl.jpg">http://image.tmdb.org/t/p/original/3l5CxSDIcWdtYne8m3BQDGOxFcl.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/rpEPlKeVdQkX7oVojXATvgHlSzP.jpg">http://image.tmdb.org/t/p/original/rpEPlKeVdQkX7oVojXATvgHlSzP.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/9bebtcFnkkjIHWodFPCbYkSx1mq.jpg">http://image.tmdb.org/t/p/original/9bebtcFnkkjIHWodFPCbYkSx1mq.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/52uYvs0JMlWjIcAvL0Pr8yZfrBm.jpg">http://image.tmdb.org/t/p/original/52uYvs0JMlWjIcAvL0Pr8yZfrBm.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/s3RmLACsT0sWKfiUkPvWHIcDnrt.jpg">http://image.tmdb.org/t/p/original/s3RmLACsT0sWKfiUkPvWHIcDnrt.jpg</thumb>
<thumb preview="http://image.tmdb.org/t/p/w780/iDBZ7JsHbCKCYL3MUBjJctOWnTp.jpg">http://image.tmdb.org/t/p/original/iDBZ7JsHbCKCYL3MUBjJctOWnTp.jpg</thumb>
</fanart>
<actor>
<name>Mike Myers</name>
<role>Shrek (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/sa8MMxXZrHgQ85hTAP11WS4N3ik.jpg</thumb>
</actor>
<actor>
<name>Eddie Murphy</name>
<role>Donkey (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/bsi706zdqs0KAPdOsqz6AkLNcFF.jpg</thumb>
</actor>
<actor>
<name>Cameron Diaz</name>
<role>Princess Fiona (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/ahFkUN9Sm8oF1txUHE5JcJ95Ere.jpg</thumb>
</actor>
<actor>
<name>John Lithgow</name>
<role>Lord Farquaad (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/uquz3dZ0fs0lAK57lCXwxaslVkb.jpg</thumb>
</actor>
<actor>
<name>Vincent Cassel</name>
<role>Monsieur Hood (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/yTTyX7xziiMibm0nzcH5z6xxLLv.jpg</thumb>
</actor>
<actor>
<name>Peter Dennis</name>
<role>Ogre Hunter (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/9fNNPSTxuoVgsdJwQVmWUx9EDLT.jpg</thumb>
</actor>
<actor>
<name>Clive Pearse</name>
<thumb>http://image.tmdb.org/t/p/original/dO8RhoEjfRzdWfNARRo1XaFLQOm.jpg</thumb>
</actor>
<actor>
<name>Jim Cummings</name>
<role>Captain of Guards (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/i9frXvIJsGtoFikBEFVqE7uN8Bq.jpg</thumb>
</actor>
<actor>
<name>Bobby Block</name>
<role>Baby Bear (voice)</role>
</actor>
<actor>
<name>Chris Miller</name>
<role>Geppetto / Magic Mirror (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/3nwwLDbRaTQHp26cuDNw1KRgCZd.jpg</thumb>
</actor>
<actor>
<name>Cody Cameron</name>
<role>Pinocchio / Three Pigs (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/tEVQtTHkBPuqUzER8mvDyy6NaVO.jpg</thumb>
</actor>
<actor>
<name>Kathleen Freeman</name>
<role>Old Woman (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/heWbPEh1WTVS0fdv6QU61N9AuaX.jpg</thumb>
</actor>
<actor>
<name>Conrad Vernon</name>
<role>Gingerbread Man (voice)</role>
<thumb>http://image.tmdb.org/t/p/original/kSyVrs8NtLoQhfBXFBhnTWzC7Vm.jpg</thumb>
</actor>
<fileinfo>
<streamdetails>
<video>
<codec>h264</codec>
<durationinseconds>5408</durationinseconds>
<width>1920</width>
</video>
<audio>
<codec>truehd</codec>
</audio>
<audio>
<codec>ac3</codec>
</audio>
<audio>
<codec>ac3</codec>
</audio>
<subtitle>
</subtitle>
<subtitle>
</subtitle>
<subtitle>
</subtitle>
<subtitle>
</subtitle>
<subtitle>
<language></language>
<file>Shrek.2001.1080p.srt</file>
</subtitle>
</streamdetails>
</fileinfo>
</movie>
2016-03-15, 13:12
also please add Set field on main movie window (when editing) or a window next to metadata (when editing movie )
