Okay thanks Dan, that makes sense.
(2018-02-01, 14:49)Bjur Wrote: [ -> ] An extra question. How do I get movies in Sets to appear right in Plex (it works in Kodi) and can you get votes also in Plex from Ember?
I use this
https://forums.plex.tv/discussion/38402/...library/p1 for Plex it'll grab the collection name from the nfo, with the new collections
update you might be able to the edit the code from the nfo importer to grab the overview for the collection too and add it to the collections summary on Plex
I'm having an issue where TV Shows stop scraping name & info. The images scrape fine. This seems to happen sometimes and corrects itself. Any ideas?
(2018-02-04, 20:49)McButton Wrote: [ -> ]I'm having an issue where TV Shows stop scraping name & info. The images scrape fine. This seems to happen sometimes and corrects itself. Any ideas?
No, I'm not a fortune teller ...
It should have been English. I haven't changed it.
I'm currently doing a fresh install to see if something messed up. It's been a while.
UPDATE: I did a fresh install and only added the 1 folder. It scraped fine. I somehow messed something up with my original. All is good now. Weird, but working.
(2018-01-07, 01:14)brunosso Wrote: [ -> ]Any info on fixing trakt.tv sync?
Dan sorry to bother you... but there is a possibility to fix trakt.tv sync!?
(2018-01-26, 01:29)DanCooper Wrote: [ -> ] (2018-01-25, 23:48)abescalamis Wrote: [ -> ]I wanted to know if the there is a way for ember to add the language code of the subtitles, like .es.srt and .eng.srt?
No. Atm only "forced" will be recognized and flagged.
Do you have plans to add this for the future? it will be awesome if you do! I have been searching for days and there is no tool capable of doing this!, the only one that I found is Fileboot and is not too user-friendly for that because you need to do some script for it, I haven't tried because I don't want to mess up my library.
I've been using EMM for some time to generate nfo files for MediaPortal.
I recently updated EMM as it wasn't scraping movie data anymore.
The EMM 1.4.8.0 Alpha 23.3 I installed is quite a bit different from 1.3.0.2.
I have single folders that each hold the movie and poster for that folder. The folder, movie, and poster are all named with the movie name.
From what I've read, I need to create a separate folder for all the posters but I can't figure out how to get EMM to use the jpgs in that separate folder.
Are there directions somewhere or can someone tell me how to configure the Settings>Movies>Files>Expert or otherwise to make this work?
PS. I'm a novice when it comes to all these settings.
(2018-02-06, 01:27)MePoEmberMM Wrote: [ -> ]Hi,
First, upgrade to the latest build:
https://forum.kodi.tv/showthread.php?tid=316733
Keep any/all artwork located next to the movie. Go to expert naming options and put in: <filename>
Then you need to reload all movies, Tools->Reload All Movies
Awesome! I'm looking forward to getting this working.
Thank you Fail$tyle420
I downloaded and tried builds 0a789f7 and 0f9b806 of 1.4.90 but I'm getting a version incompatibility error.
I suspect this is because these builds are for 64 bit PCs?
I'm running Windows 7 32 bit. It's that or maybe the fact that I have several installs of EmberMM in separate folders on my C: drive.
Is there a way to tell what builds work on a 32 bit PC?
