(2018-02-07, 20:03)Poland Wrote: [ -> ]probably the MQ 7 does not work a movie series.Media Menager supports Disc Art ?? I asked where he gets the disk graphics from? From what website? Fanart tv?
You see 3 discs Hobbit ?? I see that the Matrix displays 3 disks. What would make a hobbit display three disks simultaneously in the collection
It is showing EACH movie disc. 3 movies = 3 discs. Nothing to do with the SET/COLLECTION.
(2018-02-07, 19:38)T-bird_se Wrote: [ -> ] (2018-02-07, 19:05)Poland Wrote: [ -> ]here I moved the conversation to the problem. Three disks have disappeared, I have been working for a few years, now not
https://forum.kodi.tv/showthread.php?tid=153502&page=33
Neither Ember or MSAA supports discs for movie set, and very few skins supports it
So what skin are you using now and what did you use when it was functioning?
Ember supports DiscArt for movie sets, just enable it in the "Kodi Interface Defaults". But as the settings title say: this images can only be synced with the Kodi Interface, not with MSAA.
But I think Poland's problem is another...
Hello
I got a TV show that has two episodes per video file, is there any tip to scrap this or I shouldn't even touch it because when I try to scrap I just make a mess of it. "I really hate getting cartoon shows, I always encounter this type of problems with them"
The video files are named like this
The Amazing World of Gumball - S01E01-E02 - The Responsible & The DVD (1080p WEB-DL x265 HEVC 10bit AAC 2.0 RCVR).mkv
Use "SxxExxExx", e.g. "The Simpsons - S01E01E02.mkv".
You can find all information in the Kodi wiki. Search "Kodi wiki episode file naming" on google for more information.
xml:
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format profile : E-AC-3+Atmos / E-AC-3
Codec ID : A_EAC3
Duration : 58 min 2 s
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 15 objects / 6 channels
Channel positions : 15 objects / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 186 MiB (2%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Gets detected as
xml:
<audio>
<bitrate>448</bitrate>
<channels>1</channels>
<codec>eac3</codec>
<language>eng</language>
<longlanguage>English</longlanguage>
</audio>
komplex Can you send me a short sample of this file?
Should probably add another one of
these for TrueHD+Atmos
xml:
Audio #1
Format : TrueHD
Format profile : TrueHD+Atmos / TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Maximum bit rate : 5 022 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
It should give
xml:
<audio>
<channels>8</channels>
<codec>truehd_atmos</codec>
</audio>
But instead gives
xml:
<audio>
<codec>truehd</codec>
</audio>
Why is your program downloading a story in German ?, I set Poland. some of the films have a story in German
you will not answer? Why does the story of the film be taken in German. I have a language set for Polish
(2018-02-11, 10:14)Poland Wrote: [ -> ]Why is your program downloading a story in German ?, I set Poland. some of the films have a story in German
This can only be for two reasons:
- you've enabled a german scraper like OFDB or Moviepilot
- the movie is not set to polish
Hello Friends.Explain to me.I have a mistake in several series of films .
1.Main view of the series of the German plot
2.When I enter a single movie, there is a plot of my Poland
