2018-03-01, 20:10
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176
2018-03-07, 16:28
Hello all, i was using EMM for years without problems, yesterday i was upgrading version 1.4.7.2 to 1.4.8 everything was ok with the upgrade, but when i enter to EMM settings are gone
i was looking in profile/default an saw 5 .emm files (database files i think)
and the last two files are Myvideos43.emm with 146,432 bytes and Myvideos43.emm_tmp 14,262,272 bytes so i think something went wrong upgrading database and thats why i have a smaller .emm file and bigger .emm_temp file
So, anyone know what can i do to fix this error? I also have a backup of the version 1.4.7.2 files, and tested and worked fine
thanks in advanced temuy
PSorry for me english still learning
2018-03-07, 17:07
(2018-03-07, 16:28)temuy Wrote: [ -> ]Hello all, i was using EMM for years without problems, yesterday i was upgrading version 1.4.7.2 to 1.4.8 everything was ok with the upgrade, but when i enter to EMM settings are goneFirst, you should use the latest daily build: Link
*.emm_tmp will be build while Ember tries to upgrade your database. If Ember get an error while upgrading, a new database will be created. That's the small MyVideos43.emm. To old one which Ember upgrades from is still there and has a lower number then 43.
Please delete MyVideos43.emm and also MyVideos43.emm_tmp, install the latest daily build and try it again. If the database upgrade on the first start also ends in an empty database then post the latest log (.\Ember Media Manager\Logs) on http://pastebin.com so I can look what's the problem in your old database.
2018-03-07, 18:07
(2018-03-07, 17:07)DanCooper Wrote: [ -> ]Thank you very much for your fast reply, i tried with the lastest build but same result, here is the complete log https://pastebin.com/rL8WTXw9(2018-03-07, 16:28)temuy Wrote: [ -> ]Hello all, i was using EMM for years without problems, yesterday i was upgrading version 1.4.7.2 to 1.4.8 everything was ok with the upgrade, but when i enter to EMM settings are goneFirst, you should use the latest daily build: Link
I think the error is here with the moviesource table or something like that
2018-03-07 12:30:24.7910 EmberAPI.Database EmberAPI.Database.bwPatchDB_DoWork 5 ERROR "bwPatchDB_DoWork Unable to open media database connection." "EXCEPTION OCCURRED:System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database
- no such table: moviesource
Best Regards
temuy
2018-03-07, 18:43
(2018-03-07, 18:07)temuy Wrote: [ -> ]Looks like a bug. Can you upload your MyVideo24.emm (I think that should be the latest version of your database) to Dropbox or something similar and send me a link per PN?(2018-03-07, 17:07)DanCooper Wrote: [ -> ]Thank you very much for your fast reply, i tried with the lastest build but same result, here is the complete log https://pastebin.com/rL8WTXw9(2018-03-07, 16:28)temuy Wrote: [ -> ]Hello all, i was using EMM for years without problems, yesterday i was upgrading version 1.4.7.2 to 1.4.8 everything was ok with the upgrade, but when i enter to EMM settings are goneFirst, you should use the latest daily build: Link
Best Regards
temuy
2018-03-07, 19:07
(2018-03-07, 18:43)DanCooper Wrote: [ -> ]@DanCooper He is a new user so he can't use PM or mail(2018-03-07, 18:07)temuy Wrote: [ -> ]Looks like a bug. Can you upload your MyVideo24.emm (I think that should be the latest version of your database) to Dropbox or something similar and send me a link per PN?(2018-03-07, 17:07)DanCooper Wrote: [ -> ]First, you should use the latest daily build: LinkThank you very much for your fast reply, i tried with the lastest build but same result, here is the complete log https://pastebin.com/rL8WTXw9
Best Regards
temuy
2018-03-07, 19:09
(2018-03-07, 18:43)DanCooper Wrote: [ -> ]Sure np(2018-03-07, 18:07)temuy Wrote: [ -> ]Looks like a bug. Can you upload your MyVideo24.emm (I think that should be the latest version of your database) to Dropbox or something similar and send me a link per PN?(2018-03-07, 17:07)DanCooper Wrote: [ -> ]First, you should use the latest daily build: LinkThank you very much for your fast reply, i tried with the lastest build but same result, here is the complete log https://pastebin.com/rL8WTXw9
Best Regards
temuy
https://dropfile.to/oge2mve
Edit: didnt see the link was by PM, anyway in 23 hours the file will be delete
2018-03-07, 20:44
(2018-03-07, 19:09)temuy Wrote: [ -> ]Ok, that was a little challenge..(2018-03-07, 18:43)DanCooper Wrote: [ -> ]Sure np(2018-03-07, 18:07)temuy Wrote: [ -> ] Thank you very much for your fast reply, i tried with the lastest build but same result, here is the complete log https://pastebin.com/rL8WTXw9Looks like a bug. Can you upload your MyVideo24.emm (I think that should be the latest version of your database) to Dropbox or something similar and send me a link per PN?
Best Regards
temuy
The issue was that you've used the same name (MKV) for more than one movie source. That ended in duplicate entries while replacing the source name into source ID in the movie table.
Since many version is no longer possible to add multiple sources with the same name, but it looks like that it was possible in older versions.
I've fixed your old database and changed the source name of one source to "MKV-L" and fixed all entries from this source in the table "movie". The update of your "MyVideos24.emm" works now in my development environment.
Please rename your file "MyVideos24.emm" to something like "MyVideos24.emm_old", delete all never version if they are still there, copy this fixed DB back to your profiles folder and try another run.
2018-03-07, 21:58
(2018-03-07, 20:44)DanCooper Wrote: [ -> ]Oh very nice, the dropbox link point to a library.rar and i cant find the database there, is that the right file?(2018-03-07, 19:09)temuy Wrote: [ -> ]Ok, that was a little challenge..(2018-03-07, 18:43)DanCooper Wrote: [ -> ]Looks like a bug. Can you upload your MyVideo24.emm (I think that should be the latest version of your database) to Dropbox or something similar and send me a link per PN?Sure np
2018-03-07, 22:01
(2018-03-07, 21:58)temuy Wrote: [ -> ]Yes, that was the wrong one. Link is now fixed.(2018-03-07, 20:44)DanCooper Wrote: [ -> ]Oh very nice, the dropbox link point to a library.rar and i cant find the database there, is that the right file?(2018-03-07, 19:09)temuy Wrote: [ -> ]Sure npOk, that was a little challenge..
2018-03-08, 14:20
(2018-03-07, 22:01)DanCooper Wrote: [ -> ]Yes that fix it, ty very much for your incredible suppport, i will make a small donation when i transfer some money to my paypal account(2018-03-07, 21:58)temuy Wrote: [ -> ]Yes, that was the wrong one. Link is now fixed.(2018-03-07, 20:44)DanCooper Wrote: [ -> ]Ok, that was a little challenge..Oh very nice, the dropbox link point to a library.rar and i cant find the database there, is that the right file?
thanks one more time
2018-03-10, 01:02
using the version 1.4.90.
When i use the renamer to rename a file that have the special character : in the IMDB name the program is replacing the : by a -
ex:
1.Asterix & Obelix: In Britain
2.Asterix.&.Obelix -.In.Britain.2012.1080P.H264
my settings for files pattern is : $T{.$Y}{.$R}{.$V}{.$S}{.$H}$X.$!
Steve
ex:
Steve
2018-03-10, 10:09
: is not a valid character for file name in windows, so it must be replaced by the renamer
Don't think it's a setting to what the replacement character to use, it default's to -
2018-03-11, 23:05
(2018-03-10, 01:02)slappy Wrote: [ -> ]Hi,A ":" will always be replaced by a "SPACE-" because ":" is not allowed in a file name. It is always replaced if there are characters at the end that are invalid for file names or directories. But you can add "$?:??" to the pattern to replace a ":" by "nothing" before that final check has been run.
ex:
Steve
2018-03-20, 20:50
Hi Dan,
I was using an older built(0f9b806) & everything was scraping perfectly, see picture:
I now installed the latest build (93ce5d7), rescraped the movie & this is what I got:
Is there a setting I need to change or where did things go wrong?
PS: I installed the old version again & it scraped fine again.
Your help is appreciated
