(2019-12-21, 22:56)oggie62 Wrote: [ -> ]Hi all......I have been using EMM for many years and apart from an issue with regex, I never had problems. Recently I added a TV Show and when I tried scraping it, EMM didn't find it. I assumed it was corrupted so I tried adding another.....with same result. Next I left-clicked it to select TVDB from the list....and it was greyed out. Any idea what's going on ? Many thanks in advance.
I'll probably be corrected but from what I know TVDB is not working right now with Ember. (TVDB people changed things at their end). Try disabling TVDB and use the other providers instead.
I was looking to change all my poster images from <filename>.ext to poster.ext. Is their a way EMM can handle this, I have about 4000 movies in their own folders so manually will suck haha.
(2019-12-23, 10:25)FlashPan Wrote: [ -> ] (2019-12-21, 22:56)oggie62 Wrote: [ -> ]Hi all......I have been using EMM for many years and apart from an issue with regex, I never had problems. Recently I added a TV Show and when I tried scraping it, EMM didn't find it. I assumed it was corrupted so I tried adding another.....with same result. Next I left-clicked it to select TVDB from the list....and it was greyed out. Any idea what's going on ? Many thanks in advance.
Hi....thanks for reply which I tried but made no difference. I thought of re-installing Ember but I am afraid it wouldn't scrape anything....at least now the older stuff has already been scraped.
(2019-12-25, 17:22)oggie62 Wrote: [ -> ] (2019-12-23, 10:25)FlashPan Wrote: [ -> ] (2019-12-21, 22:56)oggie62 Wrote: [ -> ]Hi all......I have been using EMM for many years and apart from an issue with regex, I never had problems. Recently I added a TV Show and when I tried scraping it, EMM didn't find it. I assumed it was corrupted so I tried adding another.....with same result. Next I left-clicked it to select TVDB from the list....and it was greyed out. Any idea what's going on ? Many thanks in advance.
Search the thread for TVDB and download the updated dll and put on the modules folder from install directory.
Hi
Using v1.4.90 x64 and noticed an issue that's not shown up before.
As I watch movies, I update the watched status. This is now not showing up consistantly.
The watched status is still in the nfo file under '<playcount>1</playcount>'. It's also showing up in the 'Edit Movie' dialogue. However, it's not showing up on the main screen.
Some screenshots below:
Cheers
P.S. Thanks for all your work over the years - great software.
(2020-01-04, 03:25)Dr2Sweet Wrote: [ -> ] (2016-02-10, 21:01)DanCooper Wrote: [ -> ]Please don't install Ember under "C:\Program Files", unless you know how to fix the access rights.
Please use this thread for discussions about self-compiled versions or official alpha releases.
Daily Builds: LinkEmber Media Manager 1.4.8.0 Alpha 23.3 x64 - 2017-03-07Ember Media Manager 1.4.8.0 Alpha 23.3 x86 - 2017-03-07
Commits (Changelog): Link
hello Dan, i have been using ember media manager for years. lost my hard drive, i have downloaded what i believe to be the latest build from this git hub site
https://github.com/DanCooper/Ember-MM-Ne...82d1e90bf3
but i cant seem to get to the install process after unzipping the files. do you have a link to a tutorial on the steps i am unable to figure out? do i need an api key? or am i to find an original older version to install and update with?
That's the source code and i don't think that's what you want. Grab the latest build (1 year old, sort by date) from komplex' Goggle drive:
Link
(2019-12-28, 14:20)fred_gaou Wrote: [ -> ]Search the thread for TVDB and download the updated dll and pt on the modules folder from install directory.
Sorry for the daft question : where will I find the updated dll ?
(2020-01-06, 18:01)oggie62 Wrote: [ -> ] (2020-01-06, 11:04)Cheadstina Wrote: [ -> ]Link to the updated DLL post that fixes TVDB integration:
https://forum.kodi.tv/showthread.php?tid...pid2903180
Thanks for the reply, but it didn't work. If I left-click on a TV show, IMDB, TMDB and TVDB are all greyed out - see image : https://ibb.co/3S3rm4N
This tv show isn't scraped, so there is no TVDb ID and Ember can't create a Link to open the webpage. But this has nothing to do with the bug's on the TVDb API...
(2020-01-06, 18:24)DanCooper Wrote: [ -> ] (2020-01-06, 18:01)oggie62 Wrote: [ -> ] (2020-01-06, 11:04)Cheadstina Wrote: [ -> ]Link to the updated DLL post that fixes TVDB integration:
Why isn't it scraped ? Anyhow, it's on IMDB....but that's not the point. It happens to any tv show. While with movies everything seems fine
Hello,
scrapping TV Show data is also not working for me. I tested these scenario.
Notes:
1. when I enabled a scrapper all other are disabled
2. I only scrapped the nfo using the "Forced Best Match" command.
Results:
IMDB : no nfo data saved, no error message
TMDB : no nfo data saved, no error message
Tracktv : didn't test as they require to create an account.
TVDB : no nfo data saved, EMM crashes with cryptic instance object error message
then I installed the
tvdb.dll (20191129)
TVDB : no nfo data saved, no error message
tvdb.dll (20191125)
Is there a fix coming in the short time?
is Tracktv a worthy scrapper?
