(2020-02-10, 10:27)DanCooper Wrote: [ -> ] (2020-02-10, 09:40)sanjonny Wrote: [ -> ]Since I am now using the wonderful folder scraper option (right click scan for new content) I am wondering if it is possible to automate renaming the tv show when using that.
Settings => Modules => Renamer => Default TV Renaming Patterns => Auto rename files during DB update
Thanks Ill try it out. I know I looked at it but wasnt sure that was it.
(2020-02-09, 19:57)DanCooper Wrote: [ -> ] (2020-02-09, 16:08)crookers13 Wrote: [ -> ]hello
could anyone point me to the link for the latest version please?
the link on the daily build thread takes me to a google drive folder but the latest modified folder seems to be from May 2018.
cheers
The latest build is from 2018-12-09. You can find it on Komplex Google drive.
But I'm nearly done with a new build that fixes the most important bugs like YouTube, TVDb, OFDb and Kodi Interface. So maybe it's better to wait 2-3 days for the hotfix release.
Will the new version allow you to order by differently named/allowed seasons? e.g. like this show which doesn't use season naming?
https://www.thetvdb.com/series/chilling-...of-sabrina
(2020-02-11, 11:17)bornsurvivor Wrote: [ -> ] (2020-02-09, 19:57)DanCooper Wrote: [ -> ] (2020-02-09, 16:08)crookers13 Wrote: [ -> ]hello
cheers
Will the new version allow you to order by differently named/allowed seasons? e.g. like this show which doesn't use season naming? https://www.thetvdb.com/series/chilling-...of-sabrina
Season Naming is already possible, the TMDb scraper also supports scraping. But the Kodi JSON Interface does not allow it to sync as i know (have to check that with the latest Kodi version).
This release will only be a hotfixed version, not the long awaited "new" version. The "new" version has season title fully implemented with a blacklist for generic season title like "Season 1" in all languages. The "hotfixed" version scrapes any season title, also the generic ones with is non-sense.
Edit: Kodi 18.x supports movieset plot and season title sync via JSON. But I've added only movieset plot to the "hotfix" release because Ember saves a generic language dependent title for each season and it's pointless to save that in Kodi. A proper solution comes with the "new" version of Ember.
(2020-02-11, 13:17)DanCooper Wrote: [ -> ] (2020-02-11, 11:17)bornsurvivor Wrote: [ -> ] (2020-02-09, 19:57)DanCooper Wrote: [ -> ]The latest build is from 2018-12-09. You can find it on Komplex Google drive.
DanCooper Hopefully, my last post made sense. I don't think I worded it properly.
What I was wanting was, say for example with that particular show that I am able to scrape by "Parts" instead of "Seasons" as that's the only way to grab the correct metadata for this show and others like it.
I know that the program already does DVD order and Absolute Order but will there be/can you put in Flexible Seasons as the blogpost describes here "https://www.thetvdb.com/blog/something_new" to this hotfix version as metadata won't get scraped properly otherwise with tvdb.
thanks
